Vamvo Portable Projector vs Ohdil Mini Projector vs AKIYO Mini Projector: Which Offers Better USB Compatibility?
Bellmeister
Vamvo Portable Projector​
Ohdil Mini Projector​
AKIYO Mini Projector​
$89.99​
$29.99​
$55.99​
Home Cinema​
Office, Education, Home Cinema, Gaming, Business​
Indoor/Outdoor​
Adaptor, User Manual, projector, HDMI Cable​
1 x Projector Manual, 1 x Hdmi Cable, 1 x Power Adapter, 1 x Smart Projector, 1 x Remote Control (Batteries not included)​
Projector Stand​
Connectivity: HDMI, USB, audio inputs; supports laptops, smartphones, gaming consoles, TV sticks, USB sticks
Wireless Screen Mirroring: 1080P support; connects via WiFi for iOS, Android, Win10 devices
Wired Screen Mirroring: Connects with data cable for easy mirroring
Resolution: 1080P
Color Reproduction: Latest technology for true and colorful viewing
Size: 7" x 5.5" x 3"
Weight: 1.52 lbs
Use Case: Home theater projector; not recommended for PPT or business presentations
Streaming Limitations: Netflix, Prime Video accessible via laptops, TV sticks, Roku only
Support: Long-life technical support available
Product Type: Portable Movie Projector
Dimensions: 5.63 * 3.78 * 2.28 inches
Weight: 0.75 pounds
Power Supply: DC power, mobile phone charger, car charger, Micro-USB (5V / 2A support)
Connectivity: WiFi, HDMI, Audio, USB
Screen Mirroring Compatibility: Android, iPhone, Windows
Projection Resolution: Supports 1920*1080P; Native resolution 800*480
Screen Size Range: 22-170 inches
Audio: Built-in HIFI stereo speakers, reduced fan noise by 80%
Compatibility: Supports Roku sticks, Fire TV sticks, gaming consoles, PCs, smartphones, laptops, DVD players, USB memory sticks
Included Accessories: Smart projector, manual, remote control (batteries not included), power adapter
Connection Type: P2P Direct Connection, No WiFi Required
WiFi/Bluetooth: 5G/2.4G Dual-screen WiFi, Bluetooth 5.2
Resolution: Native 720P (1280*720), Full HD 1080P Supported
Brightness/Contrast: 200 ANSI Brightness, 2000:1 Contrast Ratio
Size/Weight: Dimensions: 5.35*4.33*2.28 in, Weight: 420 grams
Keystone Correction: ±50° Electronic Vertical Keystone Correction
Zoom Function: 50% Zoom
Projection Size: 32-120 inches, Optimal Distance: 3.28-9.84 feet
Input Interfaces: HDMI, USB, 3.5mm audio output
Warranty: 2-year warranty
Support: 24H service response via Amazon
Notes: Limited support for copyrighted video playback via mobile phone mirroring.
Unboxing Experience​
Vamvo Portable Projector:​
The Mini Projector boasts a compact and lightweight design that makes it highly portable and easy to store. Its sleek look is appealing, and the overall build quality feels solid for a device in this price range. At first glance, it seems like a practical addition to any entertainment setup, offering an impressive blend of aesthetics and functionality.
Ohdil Mini Projector:​
The Ohdil Mini Projector sports a sleek red and black design that feels modern and stylish, reminiscent of high-tech gadgets. Its compact size, roughly the dimensions of a large paperback book, makes it highly portable and visually appealing, especially in the vibrant colors available. The projector comes packaged in an attractive gift box, making it a suitable present for anyone, from kids to adults. While the plastic finish gives it a somewhat less premium feel, it is durable enough for everyday use.
AKIYO Mini Projector:​
The mini projector boasts a compact and lightweight design that makes it incredibly portable. Its aesthetic is modern and unobtrusive, making it an excellent addition to any room. I appreciate that it comes with a tripod, providing stability during use, especially when set up on a tabletop. The overall impression is that this projector is designed for easy handling and versatility, fitting seamlessly into various environments, whether for indoor movie nights or outdoor gatherings.
22 Inches - 170 Inches​
32 Inches - 120 Inches​
1 Meters - 5 Meters​
3.3 Feet - 16 Feet​
0.6 Meters - 4 Meters​
At least 1000:1​
1000:1 Pixels​
5000:1​
1920*1080 Pixels​
1920 x 1080 Pixels​
1920*1080 Pixels​
1280 x 720​
2000 lumen​
1000 Lumen​
5500 Lumen​
LED​
1080P Full HD enhancement technology​
Not Specified​
My viewing experience has been delightful, with the projector delivering sharp and vibrant picture quality, even in less-than-ideal lighting conditions. It excels at turning movie nights into an immersive experience by projecting content onto a wall, making it feel like a personal cinema. While the sound from the built-in speakers is decent, pairing it with an external Bluetooth speaker enhances the audio quality significantly. However, it works best in darker rooms to maximize picture clarity and brightness.
The viewing experience can be quite good, depending on the environment. In a dark room, the picture quality is decent, with a maximum projection size of up to 170 inches. However, the brightness level is on the lower side, which means that the projector struggles in well-lit areas or during outdoor use without complete darkness. The ability to manually adjust the focus is a plus, but the overall image sharpness may leave some viewers wanting more. The built-in speaker is adequate for casual use, but for a more immersive experience, external speakers are recommended.
The viewing experience has been largely positive, especially in dimmer settings where the 1080P image clarity truly shines. The picture remains sharp, even when the projector is set up at an angle, though I did notice some unevenness in the image when not perfectly leveled. Audio quality is decent, but I found it best to connect external Bluetooth speakers for an enhanced experience, as the built-in speakers are somewhat lacking in volume. Streaming content was generally smooth, but I did encounter occasional lag when using Wi-Fi, which made a direct HDMI connection preferable for uninterrupted viewing.
Built-In Speaker, Portable, Lightweight​
Built-In Speaker, Outdoor / Indoor Portable, Mini Projector for All Smartphone, Portable,Zoom 50%-100%, Wi-Fi ,HDMI ,Screen Mirroring ,Maximum 170" projection ,HD 1080P Supported​
AVC​
AVC​
AVC​
3 Watts​
55000 Hours​
iOS,Android​
Button Control​
App​
App​
TYPE-C, USB, HDMI
Wi-Fi, HDMI
Wireless​
Smartphone, Tablet, Laptop, Television, Gaming Console​
38 Watt-hours​
Mount Type​
Tabletop Mount​
Floor Mount/Ceiling Mount/Tabletop Mount/Tripod Mount/Wall Mount​
Tabletop Mount​
5.63"L x 3.78"W x 2.28"H​
5.35"L x 4.33"W x 2.28"H​
Setting up the projector was an incredibly straightforward process. I was able to connect it to my devices without any hassle, thanks to the multiple input options, including HDMI and wireless capabilities for iOS and Android devices. The remote control is intuitive, featuring quick-access buttons that simplify navigation for users of all ages. Overall, the setup experience was smooth and user-friendly, which is a significant advantage for anyone who may not be tech-savvy.
Setting up the Ohdil Mini Projector was a mixed experience. While the initial power-on and language selection was straightforward, the instructions provided were basic and required some trial and error to fully understand all the features. The projector supports multiple connection methods, including HDMI, USB, Wi-Fi, and screen mirroring, which adds to its versatility. However, using the remote control is necessary for navigating the menu effectively, as the onboard controls are not very intuitive.
Setting up the projector was a breeze; I was able to connect my devices without any hassle. It supports a variety of connections, including HDMI, USB, and wireless connectivity for screen mirroring from both iOS and Android devices. I particularly enjoyed the convenience of using my iPad for casting, and the user manual was straightforward, though I found I hardly needed it. However, I did encounter some initial issues with external drives, which required a bit of troubleshooting to ensure compatibility.
• Excellent picture quality for the price, with vibrant colors and good sharpness.
• User-friendly setup with multiple connectivity options, including wireless mirroring.
• Portable and lightweight, making it easy to transport.
• Built-in speaker is surprisingly good for its size, providing decent sound quality.
• Affordable option, especially for casual home entertainment.
• Fan noise can be noticeable but not overly disruptive.
• Picture brightness may suffer in well-lit environments.
• Lack of true wireless Bluetooth connectivity for screen mirroring can be inconvenient.
• Audio quality from the built-in speakers may require enhancement with external speakers.
The Mini Projector has proven to be an excellent investment, particularly for its price under $100. It has exceeded my expectations in terms of performance and ease of use. It’s ideal for movie nights, presentations, and casual gaming, providing a surprisingly immersive experience. While it isn't without some minor drawbacks, such as fan noise and brightness limitations in well-lit rooms, the overall value and enjoyment it brings to my entertainment setup make it highly recommendable for anyone seeking a budget-friendly projection solution.
• Extremely compact and portable, ideal for travel.
• Supports various connection options, including HDMI and USB.
• Easy to set up with a straightforward menu system.
• Good image quality for the price in dark environments.
• Versatile power options, including USB power capability.
• Dimmer brightness, requiring a dark room for optimal viewing.
• Onboard controls are not user-friendly; the remote is necessary.
• Built-in speakers are lacking in volume and quality.
• Limited ability to project at angles; no adjustable feet or kickstands.
• Some connectivity issues with specific apps due to DRM restrictions.
The Ohdil Mini Projector is an impressive entry-level device that offers decent image quality and multiple connectivity options at an affordable price. While it shines in compactness and ease of use, it does have limitations regarding brightness and sound quality. This projector is best suited for casual viewing in dark environments, making it a great choice for movie nights or portable presentations. For those seeking a high-quality cinematic experience, investing in a more robust model might be advisable. Overall, it’s a solid option for light, portable use, earning a respectable three to four stars in my book.
• Excellent picture quality, especially in low light.
• Easy to set up and connect to various devices.
• Great portability and compact design.
• Comes with a tripod for added stability.
• Solid customer service experience.
• Inconsistent wireless streaming performance can lead to lag.
• Built-in speakers may require an external audio solution for better sound.
• Brightness adjustment is unavailable, making dark scenes hard to view.
• Occasional issues with playback from USB drives.
Overall, I’m quite satisfied with this mini projector. It offers impressive features and performance for its price point, making it an excellent choice for anyone looking for a budget-friendly solution for movie nights or presentations. While there are some minor limitations, particularly with brightness and audio quality, the positives far outweigh the negatives. I would recommend this projector to anyone seeking a compact, versatile option for their entertainment needs, especially if you can utilize it in darker environments.
GreatKangaroo
Vamvo Portable Projector is decent for the money! Sound isn't great, the interface could use some work, and I wish the feet had adjustments to level it out. But hey, the picture quality is pretty solid for the price! Overall, not too shabby!
Happy7User
Vamvo Portable Projector is awesome! Great picture and super bright. Used it for outdoor movie nights and it was a hit. Super easy to use and move around!
goalweiser
Ohdil Mini Projector? I was skeptical at first, but wow, it's awesome! The picture quality blew me away. The downsides? You can't change the screen size and the volume could be louder. But for real, it's pretty great and it doesn’t overheat!
Roy_Knable
Check out the Ohdil Mini Projector! It's super portable and lets you stream wirelessly, so you can enjoy bright, clear images wherever you are. Perfect for movie nights at home or quick presentations on the go!
pricelesslambo
AKIYO Mini Projector is awesome! The sound and picture are great! After a few months, the picture stopped working, but customer service was super helpful and sent a replacement fast! They were friendly and quick to respond. I totally recommend this product and company!
Hellopi314
The AKIYO Mini Projector is super compact and has a killer picture! I was really impressed with the sound too, but I’ll probably stick to my Bluetooth speakers for movie nights. Oh, and it even comes with a tripod, which is a cool bonus!
OneTimeSE
AKIYO Mini Projector works great! Had an issue with my lost power cord, reached out to customer service, and they were super quick to help. They sent me a free replacement, which just arrived, and I'm really happy with it. Awesome support!
