Vamvo Portable Projector vs Oddsea Mini Projector vs AKIYO Mini Projector: Which is Worth it for Gaming?
Barend Ray
Active member
Vamvo Portable Projector​
Oddsea Mini Projector​
AKIYO Mini Projector​
$89.99​
$69.99​
$55.99​
Home Cinema​
Home Cinema, Gaming, Party, Kids Watch Cartoon​
Indoor/Outdoor​
Adaptor, User Manual, projector, HDMI Cable​
Power Cord, User Manual, HDMI Cable, Remote Control​
Projector Stand​
Wireless Screen Mirroring: 1080P support, connects via WiFi for iOS/Android/Win10 devices.
Versatile Connectivity: HDMI, USB, audio inputs; compatible with laptops, smartphones, gaming consoles, TV sticks.
Recent Upgrade: 2025 model, 1080P resolution, enhanced color reproduction for detailed images.
Portable and Lightweight: Dimensions 7"x5.5"x3", weight 1.52 lbs, easy to carry.
Wired Screen Mirroring: Connect via data cable for easy screen mirroring.
Limitations: Not recommended for PPT/business, specific streaming restrictions for Netflix/Prime Video. Long-life technical support available.
Design: Compact, lightweight, dimensions 5.51”x3.78”x2.13”, weight 0.75 lb
Screen Synchronization: Wireless via WiFi, compatible with iPhone/Android
Device Connectivity: HDMI, USB, 3.5mm Audio port, supports TV Stick, Gaming Console, Macbook, Laptop, smartphone, USB stick
Resolution: Supports 1080p (native 800*480p)
Image Quality: Clear and bright with vivid colors in dark environments
Usage: Ideal for home cinema, outdoor activities, travel, camping
Target Audience: Budget-friendly option for entry-level users, great gift idea for kids
Projection Size: Up to 170 inches (50-80 inches recommended)
Connection Method: P2P Direct Connection, NO WiFi Required
WiFi and Bluetooth: 5G/2.4G dual-screen WiFi, Bluetooth 5.2
Resolution: Native 720P (1280*720), Full HD 1080P Supported
Brightness and Contrast Ratio: 200 ANSI Lumens, 2000:1
Size and Weight: 5.35*4.33*2.28 in, 420 grams
Keystone Correction: ±50° electronic vertical keystone
Zoom Function: 50% zoom via remote control
Projection Size and Distance: 32-120 in, optimal distance 3.28-9.84 feet
Input Interfaces: HDMI, USB, 3.5mm audio output
Compatibility: Android/iOS/Windows 10, PC, Fire Stick, PS5
Warranty: 2-year warranty, 24H support available
Unboxing Experience​
Vamvo Portable Projector:​
The Vamvo Mini Projector has a sleek, compact design that is both modern and appealing. Its lightweight build makes it incredibly portable, allowing for easy transportation to different locations, whether it’s for a movie night at a friend’s house or a cozy setup at home. The overall aesthetic is simple yet functional, fitting seamlessly into any entertainment setup without taking up too much space.
Oddsea Mini Projector:​
When I first unboxed the projector, I was pleasantly surprised by its compact and lightweight design, which makes it incredibly portable. The sleek appearance coupled with a sturdy build gives it a modern look that fits well in both casual and formal settings. The included carrying case is a nice touch, providing protection and making it easy to transport. Overall, the projector has a visually appealing design that doesn’t compromise on functionality.
AKIYO Mini Projector:​
The mini projector has a compact and lightweight design that makes it incredibly portable. Its sleek appearance fits well in both indoor and outdoor settings, adding a modern touch without being cumbersome. I was pleasantly surprised by how well it blends in with my other devices, and its small size allows for easy storage when not in use. Additionally, the included tripod is a thoughtful addition that enhances its stability during use, making setup quick and hassle-free.
30 Inches - 170 Inches​
32 Inches - 120 Inches​
1 Meters - 5 Meters​
3.5 Feet - 16 Feet​
0.6 Meters - 4 Meters​
At least 1000:1​
5000:1​
1920*1080 Pixels​
1920*1080 Pixels​
1920*1080 Pixels​
1280 x 720​
2000 lumen​
5500 Lumen​
Not Specified​
The viewing experience with this projector has been nothing short of impressive, especially considering its budget-friendly price. The picture quality is sharp and vibrant, providing a clear image even in less-than-ideal lighting conditions. I’ve used it for movies, gaming, and presentations, and it has consistently delivered excellent performance, with colors appearing accurate and engaging. The built-in speaker, while not the best, offers surprisingly decent sound for casual viewing.
The viewing experience exceeded my expectations, especially considering the price point. The picture quality is vibrant and sharp, delivering a cinematic feel during movie nights. I found that it performed exceptionally well in dark environments, with colors popping and details clear. Even in moderately lit rooms, the visuals were still quite good, although they shine best in complete darkness. The sound quality from the built-in speakers was impressive, providing enough volume for larger spaces without the need for additional speakers.
The viewing experience was quite impressive, especially in dimmer settings where the 1080P output truly shines. The picture quality exceeded my expectations for a projector in this price range, providing sharp and clear images that made movie nights enjoyable. However, I did notice some light artifacts typical of projectors at this level, and the sound from the built-in speakers was decent but not powerful enough for larger spaces. For optimal audio, I recommend connecting to external Bluetooth speakers, which significantly enhance the experience.
Built-In Speaker, Portable, Lightweight​
Lightweight​
AVC​
AVC​
AVC​
3 Watts​
55000 Hours​
Button Control​
App​
App​
TYPE-C, USB, HDMI
Wi-Fi, USB, HDMI
Wireless​
Smartphone, Tablet, Laptop, Television, Gaming Console​
TV Stick​
24 watts​
38 Watt-hours​
Mount Type​
Tabletop Mount​
Ceiling / Table/ Wall Mount, Front / Rear Mount​
Tabletop Mount​
17.32"L x 16.14"W x 15.57"H​
5.35"L x 4.33"W x 2.28"H​
Setting up the Vamvo Mini Projector was a breeze. I found the user interface to be intuitive, allowing me to connect various devices effortlessly. The included HDMI cable made it easy to link my laptop, while the wireless iOS/Android mirroring feature allowed me to connect my phone without needing extra devices. Overall, the setup process was straightforward, making it accessible for users of all tech levels.
Setting up the projector was remarkably straightforward. The instructions were concise and easy to follow, which allowed me to get it running in no time. I appreciated the user-friendly interface that made navigation simple, even for someone who isn’t very tech-savvy. Connecting it to various devices was hassle-free, whether through HDMI or wireless options, making it versatile for different viewing scenarios. The remote control that comes with it is a great addition, enhancing the overall user experience.
Setting up the projector was a breeze. I simply connected my devices using the provided HDMI cable and got started without needing to consult the manual extensively. The compatibility with various devices, including iOS, Android, laptops, and gaming consoles, was straightforward. However, I did encounter some initial hiccups with external drives, which required formatting to FAT32 to work properly. Once that was resolved, I appreciated the ease of connecting via HDMI and the reliable performance of screen mirroring from my phone and tablet.
• Compact and lightweight design
• Impressive picture quality for its size and price
• Versatile connectivity options (HDMI, wireless mirroring)
• Good built-in speaker quality relative to size
• Fan noise may be noticeable during quiet scenes
• Built-in speakers could be improved for better sound experience
• Limited brightness in well-lit environments
• No adjustable legs for projection leveling
My experience with the Vamvo Mini Projector has exceeded my expectations, especially given its affordability. It has transformed my home entertainment setup, allowing for fun movie nights and gaming sessions with friends and family. The combination of its portability, ease of use, and solid performance makes it a fantastic choice for anyone looking for a budget-friendly projector. I wholeheartedly recommend it for anyone seeking a reliable and enjoyable viewing solution!
• Easy to set up and use
• Compact and portable design
• Good picture quality and vibrant colors
• Built-in speakers offer decent sound
• User-friendly interface and remote control
• Best performance in dark environments
• Some connectivity issues with certain devices
• Limited functionality with streaming apps like Netflix
Overall, I am extremely satisfied with this projector and would highly recommend it to anyone in search of an affordable yet high-quality option. It has made my movie nights more enjoyable and provided a unique way to watch content, whether indoors or outdoors. Despite some minor challenges with connectivity and brightness in well-lit rooms, the benefits far outweigh any drawbacks. This projector is a fantastic investment for both casual viewers and cinephiles alike.
• Impressive picture quality in dim lighting
• Simple setup and compatibility with various devices
• Good customer service experience
• Useful digital zoom feature
• Occasional connectivity issues with WiFi and Bluetooth
• Inconsistent playback with certain video file types
• Built-in speakers lack power and quality
• Can overheat after extended use
Overall, the mini projector is a solid investment for anyone seeking a budget-friendly alternative to traditional TVs. It offers excellent picture quality, is easy to set up, and is versatile enough for both indoor and outdoor use. While there are some minor drawbacks, particularly regarding audio and connectivity, the projector's performance and customer service support make it a worthwhile purchase. I would recommend it to anyone looking for a compact and efficient projection solution, particularly for casual viewing and family movie nights.
I love the Vamvo Portable Projector! Super easy to use—didn’t even need the manual (who reads those, right?). The picture quality is awesome, it’s lightweight, and doesn’t take up much room. Just plugged in my Fire Stick, and I was all set!
Just got the Oddsea Mini Projector and I’m so stoked! Been hunting for a projector forever and finally took the plunge. Movie nights are gonna be epic! I even mirrored my phone and played Pokemon on my wall—so cool! Super easy to set up and it comes with a sweet carrying case. Best gadget ever!
Got my Oddsea Mini Projector early and I've tried it out a bunch of times. It's a great deal! The colors are super bright, the built-in speakers are loud enough for a big room, and it comes with a remote which makes it easy to use. Totally recommend it!
goalweiser
AKIYO Mini Projector is awesome! I connected my phone and laptop with zero issues. Super easy to set up too. Movie nights have been a blast! 😊
Hellopi314
Got the AKIYO Mini Projector and it works great! Had a little issue when I lost the power cord, so I hit up customer service to ask about a replacement. They were super quick to respond and even sent me a free one! Just got it yesterday and I’m really happy. Awesome support!
