Robert
Recently, there is a new projector UNIC T1 projector attracting the eyes of many projection industry people. UNIC T1 projector is the first mini projector using LCOS display technology.
1. Introduction of UNIC T1 projector
Using LCOS display technology, the resolution is 1280 * 720dpi, the light source is LED, the brightness is only 35ANSI lumens
In terms of performance, the UNIC T1 projector does not support auto-focus and requires manual adjustment, but supports electronic keystone correction with a correction range of plus or minus 15 degrees; it has a built-in 3000 mA lithium battery that supports unplugged work, and due to the advantages of LCOS technology, the UNIC T1 projector model is very compact and easy to carry and use; it also supports wireless screen projection and is equipped with HDMI, TYPE-C, 3mm audio and USB ports. C, 3.5mm audio and USB ports.
2. LCOS display technology introduction
UNIC T1 projector is the first mini LCOS projector. LCOS display technology is the organic combination of LCD and CMOS integrated circuit reflective new display technology, LCOS as a new display device has a large screen, high brightness, high resolution, power-saving and many other advantages.
3. UNIC T1 projector review
UNIC T1 is smaller than I thought, very convenient to carry out, the operation is also quite simple, you can use it with plugging in. There are USB ports, headphone holes, etc., the function is relatively complete, and it can be used without a network when camping.
