Top 5 Best Portable Mini Projectors for 2024: Size Doesn’t Compromise Performance
Hisense C2 Ultra 4K UHD Triple Color RGB Laser Portable Mini Projector​
ParameterValue
Item Weight13.9 Pounds
Item Dimensions L x W x H11.3"L x 9.7"W x 9.7"H
Maximum Throw Distance9.96 Meters
Light Source Operating Life25000 Hours
Maximum Image Size300 Inches
Voltage120 Volts
Minimum Image Size65 Inches
Hardware ConnectivityBluetooth, Ethernet, HDMI, USB 3.0
Control MethodVoice
Minimum Throw Distance1.29 Meters
Mounting TypeTabletop Mount
Brightness3000 Lumen
Wattage180 watts
Controller TypeRemote Control, App Control, Button Control, Voice Control
Compatible DevicesLaptop, Gaming Console, Tablet, Smartphone, Speaker
Additional Features65" - 300", Designed for XBOX, Trichrom Triple Laser Light Source, High Refresh Rate 240Hz, AutoMagic Adjustment System
Connectivity TechnologyBluetooth, Wi-Fi, USB, Ethernet, HDMI
Native Resolution3840 x 2160
Display Resolution Maximum3840 x 2160 Pixels
Display TypeLaser
Form FactorPortable
Price$2497.97
Review:
The projector truly offers excellent value, especially for those seeking premium features without breaking the bank. The user interface is intuitive, providing a range of customization options for picture settings, allowing you to fine-tune the image to your liking. The backlit remote is a standout feature, especially useful for low-light environments, enhancing the overall user experience.
The picture quality is exceptional—bright, with vivid colors, and edge-to-edge clarity. Even at 150", the image remains crisp and clear, showcasing the projector’s ability to handle large-screen projections without losing sharpness or detail. If you're looking for a projector that delivers both premium performance and value for money, the Hisense C2 is highly recommended.
KODAK Luma 150 Ultra Mini Pocket Pico Projector​
ParameterValue
Item Weight16 ounces
Item Dimensions L x W x H3.9"L x 3.9"W x 0.89"H
Contrast Ratio3500:1
Maximum Throw Distance8.5 Feet
Light Source Operating Life3000 Hours
Maximum Image Size150 Inches
Lamp Wattage1 Watts
Voltage15 Volts (AC)
Minimum Image Size80 Inches
Hardware ConnectivityBluetooth, USB, HDMI
Control MethodApp
Minimum Throw Distance6 Feet
Mounting TypeWall Mount
Brightness60 Ansi lumen
ColorSilver
Wattage5 watts
Controller Typeandroid, vera, ios
Compatible DevicesiPhone, PC, Smartphone, MAC, Android
Additional FeaturesPortable
Connectivity TechnologyUSB
Native Resolution1920 x 1080
Display Resolution Maximum1920 x 1080
Display TypeRGB
Form FactorPocket
Price$219.99
Review:
This projector is a fantastic travel companion, thanks to its compact, pocketable size and lightweight design. The fact that it doesn't require an external controller means one less thing to carry around or lose. It’s equipped with a small tripod hole at the bottom, making setup easy wherever you are.
While the sound isn’t amazing, it’s decent for casual viewing, and the aux input gives you the option to connect external speakers if needed. The battery life is solid, and the ability to charge via micro USB is super convenient—no need to carry a separate charger, just use the one for other devices. Though USB-C would be a nice touch, micro USB is still widely used and convenient.
As for the picture quality, it’s impressive for the size—while it won’t match your larger LG projector, it's more than enough for on-the-go use. For the price, it's one of the best options for a portable projector that meets your needs, with solid video quality, ease of use, and portability.
HP projector CC500 3in1 projector​
ParameterValue
Item Weight6 Pounds
Item Dimensions L x W x H7"L x 5.5"W x 8"H
Maximum Throw Distance2 Meters
Light Source Operating Life20000 Hours
Maximum Image Size80 Inches
Lamp Wattage10 Watts
Voltage100 Volts
Video EncodingAVC
Hardware ConnectivityUSB 2.0
Control MethodRemote
Minimum Throw Distance1.2 Meters
Brightness600 Lumen
ColorWhite
Wattage50 watts
Controller TypeButton Control
Compatible DevicesTelevision, Smartphone
Additional FeaturesFull HD 1080p
Connectivity TechnologyWi-Fi, HDMI
Display Resolution Maximum1920 x 1080 Pixels Per Inch
Display TypeLED
Form FactorPortable
Price$397.65
Review:
Wow, I’m honestly blown away by this projector! It’s like having a movie theater right in my living room – the picture is crystal clear, and the brightness is just perfect for any time of day. It’s packed with features and super easy to set up. Seriously, it's like a mini cinema in a box, and I’m loving it!
However, the sound could use a little more punch, but it’s not a dealbreaker. The real headache is I misplaced the remote (the projector one, not the Roku) and can’t find a replacement anywhere. Apparently, the only way to get one is by buying a whole new projector – which is just... not ideal. Also, the projector refuses to connect to Wi-Fi now, which is really frustrating. Feels like it’s sitting there, wasted! Still, for the price, this is definitely a solid buy if you can avoid these hiccups!
Epson EpiqVision Mini EF22 Portable Smart Laser Projector​
ParameterValue
Item Weight6.8 Pounds
Item Dimensions L x W x H9.3"L x 7.5"W x 7.5"H
Maximum Throw Distance3.32 Feet
Minimum Image Size30 Inches
Hardware ConnectivityUSB 2.0 Type A, HDMI
Minimum Throw Distance1 Feet
Brightness1000 Lumen
ColorQuartz Rose
Wattage115 watts
Additional FeaturesBuilt-In Speaker, Portable, Lightweight, Built-In Wi-Fi
Connectivity TechnologyWi-Fi, USB, HDMI
Display TypeLaser
Form FactorPortable
Price$999.99
Review:
This projector is a great choice for both home and business use, especially if you’re setting it up in a fixed spot, like a corporate meeting room. It’s mounted on a swivel, so portability is a bit tricky—though you could fit it in a carry-on if needed.
The 1,000 lumens in this projector perform well in a dark room, offering a nice image up to about 120", but it's not going to compete with brighter environments. It will need some light control to maintain quality in a living room with more ambient light. The contrast is typical for an LCD projector, so don’t expect OLED-level blacks, but it’s still solid for regular viewing.
BenQ GS50 Outdoor 4K Supported Portable Projector​
ParameterValue
Item Weight5.07 Pounds
Item Dimensions L x W x H5.75"L x 7.32"W x 6.06"H
Contrast Ratio100000:1
Maximum Throw Distance9.8 Feet
Light Source Operating Life30000 Hours
Maximum Image Size112 Inches
Voltage240 Volts
Vertical Keystone Correction120 Inches
Video EncodingMPEG-4
Picture Quality Enhancement TechnologyDLP
Hardware ConnectivityBluetooth, USB Type C, HDMI, 3.5mm Audio, 802.11 ac/b/g/n
Control MethodApp
Minimum Throw Distance2.64 Feet
Brightness500 Lumen
ColorGreen
Wattage65 watts
Additional FeaturesBuilt-In Speaker, Dust-Proof, Portable, Auto Focus, Wi-Fi Ready
Connectivity TechnologyHDMI
Display TypeLED
Form FactorPortable
Price$599
Review:
This outdoor projector really shines when it comes to providing an immersive viewing experience! The 1080p resolution delivers crisp, clear images that make movies and shows feel lifelike, even outdoors. The extra bass Bluetooth speaker is a fantastic bonus, enhancing the sound quality and making it feel like you're watching in a proper theater.
Although the display may not technically be classified as HD, it still provides a much better viewing experience than many other projectors marketed as "HD" or "FHD." The clarity and brightness of the image are excellent, especially for outdoor settings.
Setup is seamless, and it works well with wireless devices, making it easy to project content from platforms like YouTube or Tablo TV. This is a big win over more clunky devices like Echo for streaming video. One minor drawback is that the QS01 dongle isn’t available separately, which could be useful for some users, but this projector still offers a solid all-in-one solution for outdoor entertainment.
