- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | TMY V08 | TMY V88 | TMY V68 |
Picture | |||
Price | $79.99 | $99.98 | $89.99 |
Recommended Uses | Indoor/Outdoor | Indoor/Outdoor | Business |
Highlight | Bluetooth 5.1 Function: Built-in upgraded speaker, supports wireless audio transmission to Bluetooth speakers/headphones, not for smartphone screen mirroring. Extensive Connection Compatibility: Equipped with HDMI, USB, TF interface, and 3.5mm headphone port; compatible with USB flash drives, TF memory cards, and HDMI devices (TV stick, game console, laptop, DVD player). Upgraded 1080P HD Video Projector: Native 720P resolution (1280x720), 1080P Full HD support, enhanced 3LCD color technology for vibrant images. Portable Mobile Home Cinema: Projection size from 32” to 220”, distance 1.5-6m, aspect ratio 4:3/16:9, contrast ratio 5000:1, lamp lifetime 60,000 hours, improved illumination for optimal visual experience. Compatibility Instruction: Compatible with phones/tablets; requires HDMI adapter cable for connection (not included). Specific adapters needed for iOS (Lightning to HDMI) and Android (MHL or Chrome-cast). | Portable Projector Screen Included - 100" foldable, anti-wrinkle, easy to wash screen for enhanced viewing. Native 1080P Resolution & 4K Supported - 1920*1080 resolution, supports 4K video sources. Faster and Stable 5G WiFi Connection - Latest 5G WiFi technology for smooth mirroring of iOS and Android devices; no lag during gaming or streaming. Bluetooth 5.1 Function & Upgraded Speaker - Built-in speaker for audio-visual experience; Bluetooth 5.1 for faster audio synchronization and wireless speaker/headphone connection. 320 ANSI & 300” Large Screen Viewing - 320 ANSI LED light source, 30"-300" display, 4:3/16:9 aspect ratio, ±15° keystone correction. | Resolution: Native 1080P FHD, 4K supported WiFi Connection: 5G WiFi for stable streaming Bluetooth: 5.1 support for wireless audio Speaker: Built-in upgraded speaker Compatibility: Multiple ports (HDMI, USB, TF, 3.5mm audio) Brightness: 320 ANSI Screen Size: 30"-300", aspect ratio 4:3/16:9 Keystone Correction: ±15° |
Screen Size | 32 Inches - 5 Meters | 40 Inches - 300 Inches | 40 Inches - 300 Inches |
Throw Distance | 1.5 Meters - 6 Meters | 1.2 Meters - 7 Meters | 1.1 Meters - 6 Meters |
Contrast Ratio | 8000:1 | 10000:1 | 10000:1 |
Display Resolution | 1920 x 1080 | 1920 x 1080 Pixels | 1920 x 1080 Pixels |
Native Resolution | 1280 x 720 | 1920 x 1080 | 1920 x 1080 |
Brightness | 95000 lumen | - | 320 lumen |
Picture Quality Enhancement | 3LCD color calibrating and adjusting technology | Native 1080P, 4K Support | Yes |
Video Encoding | AVC | AVC | H.264, H.265, VP9 |
Lamp Wattage | - | - | - |
Light Source Life | 6E+4 Hours | 50000 Hours | 50000 Hours |
Controller Type | Remote Control | Button Control | Button Control |
Mount Type | Tabletop Mount | Tabletop Mount | Tabletop Mount |
Noteworthy Features | Built-In Speaker | Built-In Speaker, Built-In 5G Wi-Fi, Built-In Cooling System, 4K Supported, 100 inch Projection Screen included | Built-In Wi-Fi |
Connectivity
Connectivity Technology | Bluetooth, USB, HDMI, 3.5mm Jack | SD, USB, HDMI, Audio | Wi-Fi, Bluetooth, HDMI, Audio, USB, MicroSD |
Hardware Connectivity | HDMI, 3.5mm Audio, USB 2.0 | MicroSD, HDMI, 3.5mm Audio, Bluetooth 5, USB 2.0 | MicroSD, HDMI, Headphone, USB 2.0 |
Compatible Devices | Laptop, Gaming Console, Television, Tablet, Smartphone | Television, Gaming Console, Speaker, Laptop, Smartphone | Television, Gaming Console, Speaker, Laptop, Smartphone, External Speaker |
Measurements
Dimensions L x W x H | 7.09"L x 5.31"W x 2.76"H | 21.84"L x 16.5"W x 8.12"H | 8.86"L x 6.89"W x 3.35"H |
Item Weight | - | 900 Grams | 1.1 Kilograms |
Product | PROS AND CONS |
TMY V08 | Pros • Compact and portable design, easy to carry and set up • Excellent picture quality for a budget-friendly device • Versatile performance for home entertainment and casual presentations • Comes with helpful accessories, eliminating the need for extra purchases • Exceptional value for the price Cons • Brightness output is less than advertised (7500 lumens) • Performance may not meet expectations compared to higher-end models • Potential confusion over lumen ratings and their meaning • Limited brightness for larger screens or well-lit environments Overall Impression The TMY Mini Projector is a solid choice for those seeking a budget-friendly, portable projector with decent picture quality. While it excels in convenience and value, potential buyers should be aware of its limitations in brightness and understand the nuances of lumen ratings to set realistic expectations. |
TMY V88 | Pros: • Excellent picture quality with sharp and vibrant visuals • Supports 4K streaming • Easy Wi-Fi setup for quick streaming • Bluetooth feature for pairing with external speakers • Portable design for easy movement between locations • Included 100" screen enhances viewing experience • Good sound quality for a built-in projector speaker • Great value for the price Cons: • Text can be hard to read • Remote control design is clunky Overall Impression: The TMY projector is an impressive entry-level option that delivers outstanding picture and sound quality, making it perfect for movie nights and presentations. Its ease of use, portability, and included screen further enhance its value, making it a highly recommended choice for anyone seeking an affordable projection solution. |
TMY V68 | Pros: • Stunning native 1080P resolution with support for 4K • Vibrant colors and excellent contrast • Easy setup process • 5G WiFi and Bluetooth 5.1 for seamless connectivity • Multiple input options (HDMI, USB, TF) for versatility • Compact and lightweight design ideal for portability • Decent built-in speakers with option for external audio enhancement • Great value for the price Cons: • Loud vent fan noise during operation Overall Impression: The TMY Native 1080P Projector is an impressive device that combines high-quality visuals, modern connectivity features, and portability, making it a fantastic choice for home entertainment and outdoor movie nights. Its value for money is exceptional, especially for those looking for a reliable projector without a hefty price tag. Highly recommended! |
