The Last of US Part 2 parts and supplements location guide for Chapter 1-20
BladeW
The parts and supplies in The Last of US Part 2 can be used to unlock upgraded weapons and skills. Many players may not know the location of these items. I will introduce to you a list of the locations of all parts and supplements in The Last of US Part 2. I hope to help you.
Parts (gears) can be used to upgrade weapons on the workbench; Supplements (pills) can be used to unlock skills upgrades in the backpack (press the touchpad); the skill tree needs to find Training Manual to unlock.
It should be noted that you can't complete all upgrades by clearing the game only one time because there are not enough parts and supplements, and you can only complete about 80% of the upgrades in the first start.
Others can only be unlocked in [New Game+]. [New Game+] All items will be inherited (including all upgrades you have unlocked and parts and supplements in the backpack will also be retained).
In order to fully upgrade all items, a total of 1920 parts and 1900 supplements are required. Simultaneously unlock two trophies of [Weapon Master] and [Survival Expert].
If you want to quickly locate parts and supplements, you can open the following auxiliary function options: [Option] → [Auxiliary Function] → [Navigation and Crossing] → [Enhanced Listening Mode] = [On], Scanning Range = 30 meters, Scanning Time = 1 second. Now you can press [R1+○] to enter the listening mode to highlight all the collectibles within a radius of 30 meters around the character. This function is like a radar, which can continuously scan the props that appear around.
Note: The following pagination title and the position of some props involve spoilers.
Chapter 1: Prologue
There are no parts or supplements in this chapter (Joel is finished after a short ride).
Chapter 2: Sober
Parts×7
After controlling [Ellie] and following [Jesse] through the snow-covered town, at the end of the snow road, you can see a part on the right side of the blacksmith shop (that is, the small workbench where the blacksmith works). Be sure to collect before the bar.
Parts × 3
It can be found on the scaffolding on the right after leaving the bar (just to the right of the library entrance).
Parts × 5
After leaving the bar, follow your friend to the end of the road, you can see a squirrel on the snow, you can find the parts in the box where the squirrel is located.
Chapter 3: Overlook
There are no parts and supplements in this chapter.
Chapter 4: Patrol
Parts × 5
After [Tina] lets you climb the rope, in the room on the right (the room with the pipe).
Supplement × 7 + Parts × 8
When [Ellie] and [Tina] rode for the second time (after leaving the first house overlooking) and came to an area that can be explored, Tina would let us search for it, press the △ button to dismount and then enter the center of the area Can find some parts and supplements.
Supplement × 2
In the same area as the above props. After leaving the RV, check the abandoned house on the left (upstairs), which can be found in the bathroom.
Supplement × 2
In the same area as the above props, in the house on the right. You need to climb up the second floor by the truck outside, and the supplements are on the bedside table.
Supplement × 7
When [Ellie] and [Tina] dismount to enter the supermarket and kill the first infected person inside, do not go through the door on the left!
Enter the small room on the right, the door is blocked but you can climb out of the window, there are 7 supplements in the sink.
Parts × 4
From the 7 supplements mentioned above, take the door to the left. The plot animation is triggered there (Ellie threw a bottle at the runner), and the parts are in this room.
Parts×7
When crawling under the truck, you will be attacked by the infected and rescued by [Tina], then turn around and climb up the truck to see 7 parts.
Supplement × 8
From the 7 parts mentioned above into the back of the truck, you can find 8 supplements and collected information.
Parts × 3
When [Ellie] and [Tina] put on masks to enter the infected area, there are 3 parts on the left side of the room (and some alcohol and rags).
Parts×12+Supplement×14
It was in the area where [Ellie] and [Tina] wore masks to enter the infected area, and explored the logistics office of the supermarket, which contained a safe. The password 07-20-13 (or 20-13-07) can be opened to obtain 14 supplements and 12 parts.
Note that it must be collected before reaching the kitchen through the second gap, otherwise it cannot be returned afterwards.
Supplement × 8
In the kitchen locker, just outside the logistics office (the location of the safe and collection items mentioned above). Also collect before passing the second gap, otherwise you cannot return.
Supplement × 25
Just in the room where [Tina] gave you the flask (search for the table and shelves in the room).
Parts×24
Located in the library, in the room behind the broken window.
Parts×7
Located in the library, on the table in the room behind the workbench.
After turning on the generator to power the first workbench encountered in this work, return to the previous room to collect these parts.
Chapter 5/6/7: no parts and supplements
BladeW
Chapter 8: The Gate (Day 1 in Seattle)
Parts×7+Supplement×3
After crossing the overgrown highway to the end, the door says that the trespasser died. On the left side of this wall, 7 parts can be found on the truck in the far left corner (climbing the back of the truck).
The other three parts are in the small guardhouse in the fence area, also on the left of the gate.
Parts × 5
When climbing into the next tower after climbing over the wall, do not go down the ladder immediately. Turn left directly to see a hidden ladder leading to the sentry tower, and 5 parts and some other props can be found on the top.
Parts×4+Supplement×7
Climb down the ladder in the sentry tower and come outside to see a closed door on the right, and a truck in front.
A generator and a yellow cable can be seen behind the truck.
Start the generator and pick up the cables. Before opening the fence door next to the generator, throw the yellow cable over the generator over the building to the other side.
It is best to stand next to the generator, throw it behind the sign on the roof of the truck, and then fall next to the fence door.
In this way, you can grab the yellow cable and climb up the truck by pressing ×, the parts and supplements are on the top.
Parts×12+Supplement×17
In the next truck (the place where the door code 0512 is obtained), you can break out the window and climb out. Climb up there to find 12 parts and 17 supplements.
BladeW
The Last of US Part 2 Chapter 9: Downtown (Day 1 in Seattle)
Supplement × 10 + Parts × 16
In the free exploration area, walk north to the broken bridge between 6th Ave and 7th Ave. There is a fire truck on the bridge. Climb up the military truck parked next to the bridge and jump from the top to the fire truck. Pick up the fire hose (press △) and throw it onto the road under the bridge (press L2 + R2) (there is a tipped truck). Climb down the fire hose (press ×) and swing it onto the overturned truck, where you can find supplements and parts.
Supplement × 18 + Parts × 7
The third square from the left (Ruins) between Columbia ST and Marion ST is at the top. Go upstairs and smash the window in front of you, step on the balcony behind the window and jump to the balcony on the right, then go upstairs to reach the top.
Parts×13
Between Fifth Avenue (5th Ave) and Sixth Avenue (6th Ave, Musical Instrument Store), search for the glass cabinets upstairs.
Supplement × 1
From the third square from the left on Madison ST, there are some upward stairs, and notes can be found on the corpse upstairs (North of Musical Instrument Shop, South of Court).
Parts×16
Located in the middle of Marion ST (Maion ST) and Madison ST (Madison ST), the second square from the left is in the barracks.
Parts×17+Supplement×20
Located on the second square from the left in the middle of Marion ST and Madison ST. There is a door that can be pushed open on Madison Avenue, at the end of the road on the left (west side) of Madison Avenue, where you can find a safe (password 04-51), which can be obtained by opening it.
Parts×12+Supplement×12
In the northernmost house (cafe), on the north side of Spring Street (Spring ST) (the second square from the left in the first row of the map). Smash the window and enter the store, these props are scattered in the store.
Supplement × 18 + Parts × 8
The third square from the left in the middle of Marion ST and Madison ST, just to the east of the musical instrument house (Buck Pet Shop). If you want to enter the pet shop, you need to get the key from the toilet in the cafe.
Parts×12
Walk north to the source of the river (with a small waterfall) between 6th Ave and 7th Ave. There was a truck parked in front of the waterfall, and Ellie would mark its location on the map. Twelve parts can be found after opening the truck.
Parts×10
Between Columbia ST and Marion ST, the second square from the left (Dome Church). Entering the dome church, you can find 10 parts on the shelves on the first floor.
Parts×11
Still inside the domed church, the upper layer can be found before using a rope to sway.
Supplement × 8
Located on the upper floor of the dome church, after using the rope to swing to the balcony (mandatory plot), explore the office on the right, and you can find supplements on the table.
Parts × 3
Located on the third square (court) from the left between Madison ST and Spring ST. After fighting some infected people, proceed to the lower area of the court. At the end of the dim hallway, smashing windows into a small office, three parts can be found on the floor inside.
Parts×7+Supplement×19
There is a safe in the same room as the above parts, password 86-07-22, open to get these parts and supplements.
Parts×8
In the same area as the above props, before sliding down with a rope, you can find 8 parts in the corridor (that is, the corridor where the corpses carrying the remnants are located).
Parts×7
After finding the fuel, return to the gate, use the fuel to start the power supply, and pass through the gate (password 5345). Go to the hotel (the place where "WLF?" is written on the map) and 7 parts can be found in the drawer on the first floor.
Parts×11
Located in the same area as the above parts, on the first floor of the hotel (concierge room).
Supplement × 18
Still in the hotel, the first bedroom on the second floor is in the sink in the shower.
BladeW
The Last of US Part 2 parts and supplements location guide - Chapter 10: Primary School
Parts×16+Supplement×8
After the battle in the corridor you will come to an overgrown area with many trees and enemies. Explore the cafeteria here to find these parts and supplements.
Parts×8
Just after the location of the last part and supplement, it's on the roof that you have to cross.
Parts×16+Supplement×13
Just enter the next room after crossing the roof.
Parts×11+Supplement×3
After jumping over the balcony of the apartment, you can find parts in the cabinet after entering the bedroom, and you can find supplements in the bathroom sink.
Parts×16+Supplement×6
In the next apartment (the bedroom cabinet has parts and the bathroom sink has supplements).
BladeW
Chapter 11: Capitol Hill
Parts × 1
At the beginning of this chapter, it can be found in the kitchen drawer of the first house on the right (the number “3” on the houses).
Supplement × 8 + Parts × 3
In a room with the number "6" on the door (a room near the outdoor swimming pool). There are 2 supplements in the downstairs bathroom, 6 supplements in the upstairs bathroom, and 3 parts in the upstairs bedroom.
Supplies×9
In the motel with the door open on the first floor.
Parts×15+Supplement×3
There is a green trash can on the right side of the motel, interacting with the trash can and pulling it under the white balcony next to it, climb the balcony through the trash can and enter the apartment. There are 6 parts in the washing machine, 3 supplements in the bathroom, and 9 parts in the bed.
Parts×14+Supplement×8
Jump off the motel (or use the trash can to jump over the fence) and keep going left to enter the garage of the gas station. Note that there are many human enemies patrolling the gas station. There are 14 parts in the garage of the gas station and 8 supplements in the shower.
Supplement × 3
In the bookstore (in the bathroom) opposite the gas station. There will be some infected people in the corridor.
Parts×8+Supplement×9
Continue to a lower area where there is a store called "Olive Street Market". When entering the store, you can find 8 parts on the shelf in the dressing room, and 9 supplements behind the cash register. Watch out for enemies outside the shop and infected people inside.
Supplement × 6
In the bank (just to the right when fighting human enemies behind Olive Street Market).
Supplement × 22
After finding the last supplement, go to "Bagel Bros Building", where there are many enemies. There are 6 supplements on the bar shelf on the first floor, 10 in the studio on the top floor, and the remaining 6 on the table near the exit of the top floor.
Supplement × 7
After the cutscenes of the dead horse and Tina vomiting, you will come to a place full of thunder. In the store on the left, you can find a safe (password 55-01-33) in the background. You can get these supplements by opening it.
BladeW
Chapter 12: TV Station
Parts×7
At the beginning of this chapter, you can find 7 parts at the back of the van that says "Channel 13 News". The car is right in front of you before entering the TV station.
Supplement × 12
In the small room at the end of the first floor of the TV station, just before climbing over the vent.
Parts×15
In the news room on the first floor of the TV station (there are many cameras), check the control room, there are 15 parts on the ground.
Supplement × 10
Located on the TV station, on the floor where Leah's body is.
BladeW
Chapter 13: Tunnel
Supplement × 12
After meeting humans and followers, Ellie and Tina will open a train door and enter the dark train compartment. Twelve supplements are on the train.
Parts×7
Soon after leaving the train, enter a room with a red light, where you will be forced to climb the ladder. Don't pick up the yellow cable on the left, check the room with the workbench on the right, there are 7 parts inside.
Supplement × 8
After jumping over with the yellow cable, check the room on the right.
Parts×12
After defeating the two Big Macs you encounter for the first time, you will pass through a chain gate and enter the first room on the right. This place is surrounded by a fence, you can crawl under the table on the right side of the room, and then squat through the hole in the fence.
Supplies×15
After leaving the next area where the enemy is encountered, come to the subway station, pass the first blue train you see, and check behind the train.
BladeW
Chapter 14: Theater
Supplement × 9
The bathroom on the first floor of the theater.
Parts × 4
The projection room on the second floor of the theater.
Parts×6
The roof of the theater, after climbing the outside ladder, is located in the room where the generator must be turned on.
BladeW
The Last of US Part 2 parts and supplements location guide - Chapter 16: Hillcrest
Supplement × 18
At the beginning of the town, the second building on the left, "Natural Remedies" (3 supplements on the shelf behind the counter, 7 on the right shelf, 8 in the bathroom, which can be accessed from the broken wall in the backyard).
Parts×27+Supplement×6
At the beginning of the town the second building on the right "Rosernont (clothing shop)". You can jump into the basement through the hole in the wall behind the counter.
Supplement × 10
Back on the street, walk forward from the overturned truck (trigger a human enemy driving off the jeep's cutscenes), until you see the cafe, immediately turn left and walk along the road to the end, from there climb the trash can into "Caroline Paper Co. "Some supplements can be found (8 in the left drawer and 2 on the counter).
Parts × 4
Go back and enter the coffee shop, climb into the vent from the bathroom to the kitchen, you can find 4 parts.
Parts × 4
Continue the process (climb up the ladder behind the bookstore → jump off the roof → kill human enemies and dogs → cross the red door). After the first encounter with the dog and through the red door, you can immediately see the parts on the right.
Parts × 3
Behind the location of the previous part, you need to open a fence door (let the trash can down the street to force the plot), and check the ground around it before it rolls down.
Parts×15
After pushing the trash can into the building with a workbench, check the right room (the room opposite the tool bench).
Supplement × 9
Leave the building with a workbench and come to another street with 4 houses (2 on the left: Velvet Tattoo, Shear Lux; 2 on the right: Goldstar Liquor, Pet Boutique). Enter the first house "Velvet Tattoo" on the left. Nine supplements can be found on the blue box next to the chair.
Parts×9
Enter the alley behind the "Velvet Tattoo" tattoo shop and remove the green trash can in front of the door. There are many infected people and a safe in the room behind you. You can get the parts by opening the safe (password 30-82-65).
Parts×5+Supplement×7
In the office behind the safe.
Supplement × 8
In the second house "Shear Lux" on the left, the one next to the "Velvet Tattoo" tattoo shop. The supplements are on the counter.
Supplement × 10 + Parts × 4
The first building on the right is "Goldstar Liquor". You can enter the basement from the back of the building, there are two infected enemies inside, you can get it after exploring the basement (2 parts on the left shelf, 2 parts on the right table, 10 supplies in the bathroom in the basement) in).
Parts×11
The next time you encounter a human enemy with a dog (after obtaining a weapon bow), walk to the last house on the right side of the road, where there are many enemies, and the parts are in the garage.
Parts×10
More dogs and enemies will be encountered just further away from the suburbs. There is a garden with a terrace, and then there is a green garden hut, there are 10 parts on the left shelf.
Parts × 3
The next time you encounter an enemy, you can find these parts in a burnt house on the outskirts of the city, right on the table in the house.
BladeW
The Last of US Part 2 parts and supplements location guide - Chapter 18: Serrafit
Parts×10
After passing through the revolving door at the beginning of this chapter, climb up the box on the left to reach the roof. Ten parts can be found on the left side of the roof.
Parts × 5
In the first building "Quickmart" (supermarket) you have to pass, you can find 5 parts in the bathroom.
Parts×4+Supplement×15
In the next building on the left, "Kingsgate Brewing Co." Smash the window and enter the room, destroying all enemies. Then find 4 parts on the dining table and 15 supplements in the kitchen.
Parts×18
Enter the "Conference Center" across the street from "Kingsgate Brewing Co." Go up one floor from the elevator on the left.
Break all the windows, then pick up the bottles or bricks on the ground and smash it on the outside glass roof, and then throw the rope over, so that you can use the rope to swing to a locked room on the other side of the building. Components.
Parts×6
Leave the "Conference Center" and walk along the main road. There is a yellow taxi under the overpass and parts can be found on the ground.
Supplement × 24
After passing under the overpass on the main road (just after the yellow taxi), turn left to an apartment, a truck parked in front of the main entrance, climb the roof to jump onto the roof of the apartment building, and then jump to the balcony on the right Smash the window. There is a safe at the back of the apartment with the password 08-10-83. When opened, you can get 24 supplements.
Parts × 5
On the same floor as the supplement above, on the other side of the apartment (and a workbench).
Supplement × 29
In the same position as the above parts. After interacting with the workbench, they will be attacked by the enemy, enter the room where the enemy is coming and get supplements on the shelf.
Parts×7
After pushing the trash can under the door and climbing the wall, enter the next building "Seattle Conference Center". Jump to the scaffolding and then to the first floor, where there is a small office. Before continuing the process, break the windows behind the office and climb in to find the parts on the table.
Parts×15
After reaching the sewer, enter a room under the metal bar on the left, with 15 parts on the shelf.
Parts×13
After killing the scar-faced enemies in the park, enter the next building "Garden Suites 113" and go upstairs to room 201. There are parts on the shelves and cabinets near the terrace exit.
Supplement × 35
From the location of the parts mentioned above, enter the terrace, and then walk along the fire ladder to the upper room, you can find 35 supplements.
Supplement × 2
After killing the human boss with an axe, continue to play the plot until the roof, then jump from the ladder into the water, leave the water, enter the building on the left, "Weston’s Pharmacy", you can see 2 supplements on the counter.
Supplement × 18
In the same position as the supplement above. Climb from the hole behind the counter to a dark room, there is a safe in the corner, password 38-55-23, open to get 18 supplements.
Supplement × 7
In the same room as the supplement above, on the shelf in front of the workbench.
Parts × 4
After killing "the last PSV player in the world", 4 parts can be found on the box on the right.
Supplement × 10
It can be found in the white tent on the right before the next encounter with the enemy.
Parts × 4
During the encounter with the enemy, in the outpost.
Supplement × 7
It can be found in the hospital during the encounter with the enemy. Just under the microscope on the left in the laboratory on the first floor.
Supplement × 3
After encountering the enemy in the hospital, go from the stairs to the upper floor and enter the first room on the right. There are 3 supplements in the corner.
Supplement × 11
After falling from the ventilation pipe, you can find it by searching the shelf behind you.
BladeW
The Last of US Part 2 parts and supplements location guide - Chapter 20: The Road to the Aquarium
Parts × 3
After leaving the theater, follow Jesse into the first building on the right, "Frontier Rental Car", in the cabinet in the office.
Supplement × 17 + Parts × 17
When passing the "WDL" transportation & packaging store, you can get 17 supplements on the cabinet of the cafeteria through the first door of the house, and 17 parts in the bathroom.
Supplement × 6
At the same location as the above supplements & parts, enter the next room on the right (still in the WDL building), there will be some gravel blocking the passage, press the ○ key to climb over from below, and you can find a collection card after entering the room , A workbench and 6 supplements.
Parts×1+Supplement×11
When you jump to the exit of the bookstore, before going out, turn around and crawl under the holed floor (1 part on the left rubble and 11 supplements behind the left rubble).
Supplement × 18
The next time you encounter an enemy, enter the "Rachel’s Fabrics" store on the right and find 18 supplements on the table in the upper corner.
Parts×15
The next dive into the warehouse ruins, there is a workbench on the upper level, 15 parts can be found next to it.
Parts×10
Climbing one floor up from the previous location, 10 parts can be found on the metal shelf.
