Tecaki Mini Projector vs ear&ear HY300 PRO vs PANSEBA Mini Projector: Which Offers the Best 180° Rotatable Feature?
Amanda Brown
Active member
Tecaki Mini Projector​
ear&ear HY300 PRO Projector​
PANSEBA Mini Projector​
$49.99​
$59.99​
$59.99​
Indoor/Outdoor​
Home Cinema​
User Manual, Warranty Card, Remote, HDMI Cable, Cleaning Kit​
User Manual, Power Cord, Projector Screen, Remote, HDMI Cable​
Resolution: 1080P HD
Bluetooth Version: 5.2
Device Compatibility: iOS, Android, Bluetooth-enabled devices
Rotation: 180° rotatable
Keystone Correction: Advanced auto-keystone correction
Zoom Function: Adjustable from 75% to 100%
Design: Mini and portable
Use Cases: Home theater, outdoor movie nights, gaming, travel, presentations
Operating System: Android TV 13.0
Content Library: Over 500,000 movies and TV shows
Graphics Processor: Mali-G31 GPU
WiFi Technology: WiFi 6
Projection Angle: 180° rotational
Usage Scenarios: Home theater, leisure, education, video conferencing
Keystone Correction: Auto keystone correction with manual focus
Sound System: 360-degree surround sound
Video Resolution: Supports 1080P/4K
Brightness: 200 ANSI lumens
Contrast Ratio: 1500:1
Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G/5G
Noise Level: Below 25 dB
Ports: HDMI, USB, audio ports
Speaker Type: HIFI
Screen Size: Max 200 inches
Brightness: 50% brighter than similar projectors
Contrast Ratio: 8000:1
Resolution Supported: 1080p
Clarity Improvement: 50% more clear images than similar projectors
Lamp Life: 50,000 hours
Cooling Technology: Advanced fan cooling
Input Compatibility: Laptops, smartphones, tablets, USB drives, X-Box
Connection Requirement for Smartphone: HDMI adapter cable (not included)
Special Note: Incompatibility with Hulu for mirrored projectors; use TV Stick instead.
Unboxing Experience​
Tecaki Mini Projector:​
The Tecaki Mini Projector, while not exactly "mini," has a compact size somewhat similar to a 2-liter soda bottle, making it lighter and easier to handle than traditional heavy-duty projectors. Its aesthetic is simple and functional, but the lack of a carrying case is noticeable, as it would add to its portability. The remote control is a handy addition, although it requires batteries that are not included in the package. Overall, its design is practical, but could benefit from a few enhancements for user convenience.
ear&ear HY300 PRO Projector:​
The Mini Projector HY300 PRO makes a strong first impression with its compact and stylish design. It's lightweight and portable, which is perfect for both home use and outdoor movie nights. The build quality feels solid, giving me confidence in its durability over time. Its sleek appearance adds a modern touch, making it an attractive addition to any entertainment setup.
PANSEBA Mini Projector:​
The PANSEBA Mini Projector has a sleek and compact design that is both portable and user-friendly. Its lightweight construction makes it easy to carry around, whether for indoor movie nights or outdoor presentations. Despite its small size, the projector has a professional aesthetic that doesn’t compromise on functionality. The materials feel sturdy, and the design is balanced, allowing it to sit securely on various surfaces without tipping. Overall, it’s a visually appealing device that fits well in any environment.
30 Inches - 200 Inches​
35 Inches - 130 Inches​
32 Inches - 200 Inches​
3.2 - 16.4​
35 - 130​
2.65 Feet - 26.25 Feet​
10000:1​
1500:1​
8000:1​
1920x1080 Pixels​
4096 x 2160​
1980 x 1080 Pixels​
1280 x 720​
200 Lumen​
95 Lumen​
LED​
LED​
LED​
High Contrast Ratio and Full HD Resolution​
The viewing experience has been quite pleasant, particularly when the lights are turned off. The colors appear vibrant and true to the original source, creating a cozy movie-watching atmosphere in our small bedroom. However, I did notice that at larger screen sizes, particularly around the 60-inch mark, the image can become pixelated, which detracts from the overall quality. The projector's ability to adjust according to the angle of projection is commendable, but it does seem to perform best in dim lighting conditions, as brightness and clarity drop significantly in well-lit rooms.
The viewing experience with the HY300 PRO has been nothing short of impressive. The image quality is sharp and vibrant, supporting resolutions up to 4K and 1080P, which enhances movie watching and gaming sessions. Even in moderately lit rooms, the brightness and clarity of the projected image are commendable. I could easily enjoy my favorite shows and movies on a large screen of up to 130 inches, making it a fantastic choice for both casual viewing and more immersive experiences.
The picture quality delivered by this mini projector is surprisingly impressive, boasting Full HD 1080P resolution that brings vibrant colors and sharp images to life. Even in dimly lit rooms, the brightness is adequate for an enjoyable viewing experience. While the built-in speaker is decent for casual use, I found that connecting external speakers significantly enhances the sound quality, creating a more immersive experience. The projector can project images up to 200 inches, making it perfect for movie nights or gaming sessions with family and friends.
Short Throw​
Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player​
Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom​
AVC​
AVC​
H.264 or MPEG-4 AVC​
50000 Hours​
USB, HDMI
Laptop, Tablet, Smartphone, Speaker​
TV Stick, Smartphone, USB, SD Card​
45 watts​
55 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Ceiling/Floor/Tabletop/Tripod/Wall Mount​
7.28"L x 5.2"W x 4.72"H​
7.28"L x 5.98"W x 2.95"H​
Setting up the Tecaki Mini Projector was straightforward for me, especially when connecting it to my laptop via HDMI, which was literally plug and play. While I haven't explored other connection methods like USB or smart device compatibility yet, the ease of using HDMI made the initial experience quite enjoyable. However, I did note that the remote is essential for operation, as there are no physical buttons on the unit itself, which could be inconvenient if the remote is misplaced.
Setting up the HY300 PRO was incredibly straightforward. I appreciated the intuitive controls that allowed me to get it running without having to sift through lengthy manuals. Within minutes, I had it connected to my Wi-Fi and was streaming content from various apps, thanks to the built-in Android 13 system. The 180° rotatable design, along with the auto keystone correction feature, made positioning the projector effortless, ensuring a perfectly aligned image regardless of where I placed it.
Setting up the projector was incredibly straightforward. Within minutes, I was able to connect it to my Roku, Firestick, and even my laptop via HDMI, making streaming content a breeze. The intuitive controls, whether through the remote or the buttons on top, make navigation a simple task. While the included projector screen is decent, I found that projecting onto a plain wall provides better clarity. The zoom and focus adjustments are quick and easy, ensuring the image is sharp and well-aligned for any viewing situation.
• Affordable price point
• Easy setup with HDMI connection
• Compact and lightweight for portability
• Vibrant colors in dark settings
• Good keystone correction feature
• The image quality diminishes at larger screen sizes
• Built-in speaker quality is subpar
• No physical controls; reliant on remote
• Somewhat loud fan noise
• Requires batteries for remote control
Overall, I find the Tecaki Mini Projector to be an excellent value for its price. It serves its purpose well for casual viewing in a small space, making it ideal for my needs. While it may not replace a full-fledged home theater system, it certainly adds a fun and versatile option for movie nights or presentations. Just keep your expectations in check regarding its limitations, especially in terms of brightness and sound. As a budget-friendly projector, it performs admirably well in the right conditions, and I'm looking forward to continuing to use it for various viewing experiences.
• Good image quality – supports 4K and 1080P, delivering sharp and vibrant visuals.
• Fast connectivity – Wi-Fi 6 and Bluetooth 5.2 ensure stable and quick connections.
• Portable design – small, lightweight, and easy to carry.
• Auto keystone correction – makes setup effortless.
• 180° rotation – allows projection on the ceiling, wall, or any surface.
• Works best in a dark room; daylight affects image brightness.
• Built-in speaker is decent, but for better sound, an external speaker is recommended.
Overall, the Mini Projector HY300 PRO has exceeded my expectations in terms of performance and versatility. Its combination of advanced features, ease of use, and portability makes it an excellent choice for anyone looking for a reliable projector for home entertainment or outdoor activities. With its high-quality image output and seamless connectivity, I find it to be a fantastic value for the price, and I highly recommend it to anyone in the market for a mini projector.
• Compact and portable design for easy transport.
• Excellent image quality with vibrant colors.
• Quick and easy setup process.
• Versatile connectivity options (HDMI, USB, Bluetooth).
• Two-way Bluetooth functionality adds flexibility for audio.
• Built-in speaker quality is decent but not ideal for larger spaces.
• The included projector screen is somewhat transparent, limiting its effectiveness.
• Some latency with Bluetooth audio; HDMI connections are more reliable.
• Adjustments for viewing angle are minimal, requiring careful placement.
Overall, the PANSEBA Mini Projector has exceeded my expectations, proving itself to be an excellent value for the price. Its combination of portability, image quality, and versatile connectivity options makes it a fantastic choice for anyone looking to enjoy movies, presentations, or gaming on a bigger scale. While there are minor limitations, particularly with the built-in audio and screen quality, the projector’s strengths far outweigh these drawbacks. I would highly recommend it to anyone seeking a reliable and compact projection solution.
Curtis_Baefield
The Tecaki Mini Projector HDMI cable is great for tight spots! The right angle plug keeps things snug without sticking out too much. Just a heads up, it's only about 5ft long, so it's perfect for short connections but might not cut it for bigger setups.
Hellopi314
The ear&ear HY300 PRO Projector has some great features for the price, like smart TV options, Wi-Fi, and Bluetooth. But it was too dim for me, so I ended up returning it.
The PANSEBA Mini Projector has pretty good picture and sound. Just wish the screen was thicker since it’s kinda see-through. But it's super easy to use if you follow the instructions!
PANSEBA Mini Projector is super compact and easy to use! The picture isn’t as clear as it looks online, but it’s not a big deal for most. The sound’s decent, but you might wanna grab an extra speaker for better vibes. You’ll need a Roku or Fire Stick to stream stuff, or you can hook up a laptop. Overall, it’s a solid deal for the price!
