mufcroberts
Unboxing Experience
- 1.1.1 Tecaki Mini Projector:
- 1.1.2 ear&ear HY300 PRO Projector:
- 1.1.3 ClokoWe Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Tecaki Mini Projector:
- 1.3.2 ear&ear HY300 PRO Projector:
- 1.3.3 ClokoWe Mini Projector:
- 1.4 Features
1.5
- 1.5.1 Tecaki Mini Projector:
- 1.5.2 ear&ear HY300 PRO Projector:
- 1.5.3 ClokoWe Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | Tecaki Mini Projector | ear&ear HY300 PRO Projector | ClokoWe Mini Projector |
Picture | |||
Reference Price | $49.99 | $59.99 | $56.99 |
Recommended Uses | Indoor/Outdoor | Education, Home Cinema, Gaming, Business | Home Cinema |
Built-In Media | User Manual, Warranty Card, Remote, HDMI Cable, Cleaning Kit | User Manual, Power Cord, Remote | 1 * Lens Cover, 1 * Remote Control, 1 * HDMI Cable, 1 * Power Supply, 1 * M8 Mini projector |
Highlight | Resolution: 1080P HD Bluetooth Version: 5.2 Device Compatibility: iOS, Android, and other Bluetooth-enabled devices Rotatable Design: 180° Keystone Correction: Advanced auto-keystone function Zoom Function: 75% to 100% adjustable Portability: Lightweight and easy to carry | Smart Projector: Android TV 13.0, built-in app ecosystem, access to over 500,000 movies and TV shows Projection Flexibility: 180° rotational projection for wall, ceiling, or floor use Keystone Correction: Auto keystone correction, manual focus adjustment Audio: 360-degree surround sound system Video Quality: 1080P/4K resolution, LED technology, 200 ANSI lumens brightness, 1500:1 contrast ratio Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G and 5G networks Noise Level: Below 25 dB for quiet operation Ports: HDMI, USB, audio ports for external device connectivity | Model: 2024 Upgrade Mini Projector Brightness: 9000 Lux Resolution: 1080P Full HD Display Size: 30-180 inches (Recommended 60-100 inches) Dimensions: 6.74 x 5.28 x 2.96 inches Weight: 0.72 kg Connectivity: HDMI, USB, AV Compatibility: iPhone, Android Phone, Tablet, Laptop, Blu-ray Player, TV boxes, PS4, USB flash disks Audio: Built-in Hi-Fi stereo speakers, audio output port Noise Reduction: 80% reduction in fan noise Warranty: Three-year product replacement warranty Customer Service: 24-hour response time, lifetime after-sales service Limitations: Does not support Netflix, Amazon Prime, Hulu (HDCP compliance) |
Unboxing Experience
The Tecaki Mini Projector has an unexpectedly compact design, roughly the size of a 2-liter soda bottle, which makes it portable and easy to handle. While it is not as "mini" as I anticipated, its lightweight nature and sleek exterior contribute to a modern aesthetic that fits well within a small bedroom setup. However, it lacks a dedicated carrying case, which could have enhanced its portability. The projector features a simple layout with a manual focus ring and a remote control, though the latter requires batteries that are not included with the purchase, a minor inconvenience.ear&ear HY300 PRO Projector:
The Mini Projector HY300 PRO has a sleek and compact design that immediately caught my eye. Its lightweight build makes it highly portable, fitting effortlessly into my bag, which is perfect for both home use and outdoor movie nights. The stylish aesthetic of the projector adds a modern touch, making it a visually appealing addition to any setup.ClokoWe Mini Projector:
The CLOKOWE 2024 Mini Projector is impressively compact and sleek, making it a stylish addition to any entertainment setup. Its lightweight design allows for easy transport, and the modern aesthetics blend well into various environments, whether it’s a cozy living room or an outdoor movie night. The projector’s small footprint does not compromise its functionality, and it comes well-packaged, ensuring protection during transit.Display
Screen Size | 30 Inches - 200 Inches | 35 Inches - 130 Inches | 30 Inches - 180 Inches |
Throw Distance | 3.2 - 16.4 | 35 - 130 | 1 Meters - 4 Meters |
Contrast Ratio | 10000:1 | 1500:1 | High Contrast Ratio |
Maximum Resolution | 1920x1080 Pixels | 4096 x 2160 | 1920 x 1080 Pixels |
Native Resolution | 1920 x 1080 | 1280 x 720 | 1920 x 1080 |
Brightness | - | 200 Lumen | 7000 Lux |
Display Type | LED | LED | LED |
Viewing Experience
Watching shows with the Tecaki Mini Projector has transformed our bedtime routine into a cozy movie experience. In a darkened room, the colors appear vibrant and true to the source, making it feel like a cinema at home. However, I've noticed some pixelation at the edges of larger projections, which can compromise the overall clarity, especially when projecting larger than 60 inches. The auto keystone correction works effectively, allowing for easy adjustments to maintain a rectangular image, although the projector must be positioned directly in front of the wall for the best results.ear&ear HY300 PRO Projector:
The viewing experience with this projector is outstanding. The picture quality is sharp and vibrant, supporting both 4K and 1080P resolutions. I was pleasantly surprised by how well it performed even in moderately lit rooms, delivering clear images for movies, gaming, and presentations. The 180° rotatable design and auto keystone correction feature ensure that I always have a perfectly aligned display, regardless of where I set it up.ClokoWe Mini Projector:
I was pleasantly surprised by the viewing experience this mini projector delivers. The 1080P resolution results in crisp, vibrant images that maintain clarity even in dimly lit environments. Whether I was watching movies, playing video games, or presenting work materials, the color reproduction was impressive. The projector performs particularly well in darker settings, offering a large projected image that brings excitement to movie nights. While the built-in speaker is decent for smaller settings, connecting an external speaker significantly enhances the audio experience.Features
Other Features | Short Throw | Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player | Zoom 25%-100%, 2 HiFi Stereo Speakers, 1080P Support |
Video Encoding | AVC | AVC | H.264 or H.265 |
LightSource Life | - | - | 50000 Hours |
Controller Type | - | Remote Control | Remote Control, iOS,Android |
Control Method | - | Remote | Remote |
Connectivity Technology | USB, HDMI | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | USB, HDMI |
Compatible Devices | Laptop, Gaming Console, Tablet, Smartphone, Speaker | Laptop, Tablet, Smartphone, Speaker | Laptop, Smartphone, Tablet, Gaming Console |
Wattage | 45 watts | - | 45 kWh |
Mount Type | Tabletop Mount | Tabletop Mount | Ceiling Mount, Tripod Mount, Wall Mount, Tabletop Mount, Floor Mount |
L x W x H | 7.28"L x 5.2"W x 4.72"H | - | 6.7"L x 5"W x 2.96"H |
Setting up the Tecaki Mini Projector was a breeze, especially when connecting it to a laptop via HDMI. It truly is a plug-and-play device, and I appreciated the inclusion of both USB and HDMI cables in the box. Although I have yet to explore other connection options such as smart devices or USB sticks, I found the initial setup straightforward. Mounting it on a small shelf above my bed was a simple task, and I was able to easily adjust the projection angle and focus to achieve a clear image.ear&ear HY300 PRO Projector:
Setting up the HY300 PRO was incredibly straightforward. I appreciated the intuitive controls that allowed me to jump right in without needing to sift through lengthy manuals. The projector supports a variety of connections, including HDMI and USB, which made it easy to connect my devices. The built-in Android 13 system simplifies streaming, allowing me to access my favorite apps directly, eliminating the need for additional devices.ClokoWe Mini Projector:
Setting up the CLOKOWE 2024 Mini Projector was an absolute breeze. I simply plugged in the HDMI cable and selected the input, and it was ready to go! The user-friendly interface and remote control make navigating settings effortless, even for those who may not be tech-savvy. It connects seamlessly with a variety of devices, including smartphones, laptops, and streaming sticks, which enhances its versatility for different viewing scenarios.Conclusion
Pros:• Affordable price point, especially for a projector.
• Easy to set up and use, particularly with HDMI connections.
• Portable and lightweight design.
• Good image quality in dark conditions with vibrant colors.
• Auto keystone correction simplifies adjustments.
• Limited projection quality at larger sizes, with some pixelation.
• Built-in speaker lacks volume and clarity; external speakers are recommended.
• Remote control requires batteries not included with purchase.
• Noise from the fan can be distracting, particularly when mounted close to the user.
Overall, I find the Tecaki Mini Projector to be an excellent value for its price, offering a fun and practical solution for watching shows in a small space. It has met my expectations for indoor use, especially in a darkened room, and has added a unique flair to our movie nights. While it may not replace a high-end projector or TV, it serves perfectly as a budget-friendly alternative for casual viewing. I would recommend it to anyone looking for a portable projector that delivers decent performance without breaking the bank.
Pros:• Good image quality – supports 4K and 1080P, delivering sharp and vibrant visuals.
• Fast connectivity – Wi-Fi 6 and Bluetooth 5.2 ensure stable and quick connections.
• Portable design – small, lightweight, and easy to carry.
• Auto keystone correction – makes setup effortless.
• 180° rotation – allows projection on the ceiling, wall, or any surface.
• Works best in a dark room; daylight affects image brightness.
• Built-in speaker is decent, but for better sound, an external speaker is recommended.
Overall, the Mini Projector HY300 PRO has exceeded my expectations. It is a powerful and versatile device that is perfect for anyone looking for a high-quality projector without breaking the bank. Its portability, combined with impressive image quality and ease of use, makes it an excellent choice for movie nights, gaming, and presentations. I highly recommend it to anyone in search of a reliable mini projector.
Pros:• Compact and portable design
• Excellent image quality with 1080P resolution
• Versatile connectivity options
• Good battery life for on-the-go use
• Great value for money
• Built-in speaker could be louder
• May struggle with brightness in well-lit rooms
• Some compatibility issues with newer iOS devices
• External speaker recommended for optimal audio experience
Overall, the CLOKOWE 2024 Mini Projector has exceeded my expectations, offering remarkable performance at an affordable price. Its portability makes it ideal for both indoor and outdoor use, and the image quality is impressive for such a compact device. While there are a few minor drawbacks, such as sound quality and brightness in well-lit environments, the overall value and functionality make it a highly recommended option for anyone seeking a reliable mini projector. Whether for family movie nights, gaming sessions, or outdoor events, this projector is a fantastic investment that delivers a memorable viewing experience.
