windstri85
Unboxing Experience
- 1.1.1 TCL 43-Inch Class S4 TV:
- 1.1.2 TCL 43-inch Class S3 TV:
1.1
Unboxing Experience
2
Side-by-Side Comparison
- 2.1 System
2.2
- 2.2.1 TCL 43-Inch Class S4 TV:
- 2.2.2 TCL 43-inch Class S3 TV:
- 2.3 Display
2.4
Viewing Experience
- 2.4.1 TCL 43-Inch Class S4 TV:
- 2.4.2 TCL 43-inch Class S3 TV:
- 2.5 Audio
2.6
Audio Experience
- 2.6.1 TCL 43-Inch Class S4 TV:
- 2.6.2 TCL 43-inch Class S3 TV:
- 2.7 Features
2.8
Motion & Gaming
- 2.8.1 TCL 43-Inch Class S4 TV:
- 2.8.2 TCL 43-inch Class S3 TV:
- 2.9 Connectivity
2.10
Compatibility
- 2.10.1 TCL 43-Inch Class S4 TV:
- 2.10.2 TCL 43-inch Class S3 TV:
- 3 Conclusion
Parameter | TCL 43-Inch Class S4 TV | TCL 43-inch Class S3 TV |
Reference Price | - | $178 |
Model Year | - | 2023 |
Specific Uses | - | Home Viewing |
Highlight | Motion Rate: 120 Dynamic Contrast: Enhanced image contrast HDR PRO: Supports Dolby Vision, HDR10, HLG HDMI Inputs: 4 (1 with eARC) Auto Game Mode: ALLM for low input lag Audio Technology: Dolby Atmos built-in | Bluetooth Personal Audio: Private listening with Bluetooth headphones Chromecast Built-in: Access to thousands of streaming apps HDMI Inputs: 2 high-speed HDMI inputs (one with ARC) FullView Metal Bezel-less Design: Modern edge-to-edge glass design 1080P Full HD Resolution: Enhanced clarity and detail in high-definition Google TV Smart OS: Integrated access to movies, shows, and live content |
Unboxing Experience
The TV has a sleek design with a minimal bezel that enhances the viewing experience. However, the small bezel on the screen does not fully allow the picture to expand to the edge, which can be slightly disappointing for those who prefer a borderless look.TCL 43-inch Class S3 TV:
The TCL TV boasts a lightweight design that makes it easy to mount on the wall, complemented by a small bezel around the screen that enhances its modern aesthetic. The overall appearance is sleek and unobtrusive, fitting well in various environments, including bedrooms and mancaves.Side-by-Side Comparison
System
Operating System | - | Google TV |
Internet Applications | - | Netflix |
Remote Control | - | Bluetooth |
Controller Type | - | Remote Control, Voice Control |
Control Method | - | Voice |
Setting up the TV was a straightforward process, especially for those already familiar with Roku. The user interface is easy to navigate, and adding apps and customizing settings to suit personal preferences is a breeze. The TV was delivered with great care, and the quality of the hardware was impressive.TCL 43-inch Class S3 TV:
Setting up the TCL TV is generally straightforward, especially for those familiar with the Google ecosystem. Users can easily connect the TV to Wi-Fi and navigate through the setup process, although some have noted that the remote control can take a bit of getting used to. While many find the Google TV interface to be snappy and user-friendly, some users have expressed frustration with the inability to delete or hide pre-installed apps.Display
Aspect Ratio | - | 16:9 |
Display Technology | - | LED |
Screen Finish | - | Flat |
Has Color Screen | - | Yes |
Resolution | - | 1080p |
Refresh Rate | - | 60 Hz |
HDR Format | - | ['HDR10', 'HLG'] |
Picture Enhancement | - | True |
Viewing Experience
The 4K resolution delivers a decent picture quality, although some users noted that the brightness could be improved. While the picture quality is generally good, a few users felt that colors appeared washed out or pale, particularly when compared to their older TVs. The capability to watch high-motion content is present, but some users felt that their previous models performed better in this regard.TCL 43-inch Class S3 TV:
The picture quality is often described as outstanding for a 1080p TV of this size, with some users even comparing it favorably to larger 4K TVs. The clarity and crispness of the images enhance the viewing experience, making it suitable for watching everything from repair videos to movies. However, some users have reported ghosting issues and subpar color adjustments, indicating that performance may vary.Audio
Audio Channels | - | 5.1 |
Audio Output | - | Dolby Digital+ |
Audio Input | - | HDMI |
Speaker Description | - | 9.5W + 9.5W speakers |
Audio Experience
Sound quality has received mixed reviews. Several users found the audio lacking, describing it as "hollow" or "flat," particularly in the mid-range frequencies, which can impact dialogue clarity. While using apps like Netflix or Prime Video offers better sound quality, the volume through external devices like DirecTV tends to be inadequate, leading some users to seek additional sound solutions like soundbars.TCL 43-inch Class S3 TV:
The built-in speakers are adequate for small spaces, providing satisfactory sound for those within 20-30 feet. However, many users find the sound quality lacking, describing it as tinny or high-pitched, which leads many to consider external sound systems for an improved audio experience. The volume levels can also be a concern, with some users wishing for a boost.Features
Video Encoding | - | HEVC/H.265 |
Screen Mirroring | - | Google Cast |
Compatible Devices | - | Smartphones, Tablets, Laptops |
Tuner Type | - | ATSC |
Other Features | - | Flat |
D x W x H | - | 3.5"D x 37.6"W x 21.9"H |
Motion & Gaming
Users did not specifically highlight gaming performance, but some expressed frustration regarding the inability to connect wireless headphones directly to the TV while using external HDMI devices. This limitation detracts from the gaming experience for those who prefer wireless setups.TCL 43-inch Class S3 TV:
The reviews do not specifically address gaming performance, but the general consensus on picture quality and responsive system performance suggests that it could handle casual gaming well. The lightweight design also makes it easy to set up in gaming spaces, though sound quality may need enhancement for a more immersive experience.Connectivity
Connectivity Technology | - | Wi-Fi, HDMI |
Bluetooth Version | - | 5.0 |
Wireless Technology | - | Wi-Fi |
Usb Ports | - | 1 |
HDMI Ports | - | 2 |
Connector Type | - | HDMI |
Signal Format | - | ATSC, NTSC, Clear QAM |
Compatibility
The Roku platform offers a variety of apps and features, but there are some drawbacks regarding advertisements and data privacy. Users can disable certain ad settings, but some advertisements remain unavoidable on the home screen. Additionally, the remote control lacks backlighting, making it difficult to use in low-light conditions, though there is a free Roku app that provides more features.TCL 43-inch Class S3 TV:
The Google TV interface offers various features, including personalized recommendations and the ability to connect with Google Home for voice control. However, some users have noted the presence of unwanted pre-installed apps and the complexity in navigating certain settings like the sleep timer. The remote has been criticized for its size and layout, potentially leading to a frustrating user experience.Conclusion
Pros:- 4K resolution is impressive.
- Affordable pricing for quality.
- Easy access to picture settings and sleep timer.
- Functional picture off option for nighttime use.
- User-friendly interface.
- Small bezel limits full picture expansion.
- Roku's data selling practices raise privacy concerns.
- TV defaults to the UI homepage rather than the last used input.
- Inconsistent sound quality, particularly with external devices.
- No voice control or Bluetooth connectivity.
Overall, the TV offers a solid performance for its price, especially for those who appreciate the Roku platform and its app capabilities. While there are a few minor complaints regarding sound quality, brightness, and the presence of advertisements, the ease of use and impressive 4K resolution make it a commendable choice for budget-conscious consumers looking for a smart TV experience.
Pros:• Excellent picture quality for the price
• Lightweight and easy to mount
• User-friendly Google TV interface
• Good internet connectivity
• Satisfactory built-in speakers for small spaces
• Sound quality lacks depth and can be tinny
• Remote control can be awkward and less intuitive
• Difficulty in adjusting certain settings
• Some users experience ghosting and color issues
• Bright blue light when the TV is off can be distracting
The TCL TV presents a compelling value for those seeking a budget-friendly option with solid picture quality and the convenience of Google TV. While it has its downsides, especially regarding sound quality and remote usability, it provides a satisfactory viewing experience for casual use. Many users express overall satisfaction, particularly in smaller settings, but those with higher demands may want to consider alternatives.
