windstri85
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 System
- 2.2 Display
- 2.3 Audio
- 2.4 Connectivity
- 2.5 Features
- 2.6 Measurements
- 3 Conclusion
Parameter | SYLVOX | Soulaca | Haocrown | |
Picture | - | |||
Price | $559 | $650 | $799 | - |
Model Year | 2024 | 2024 | 2024 | - |
Specific Uses | - | Entertainment | indoor home (bathroom), hotels, spa, salon, swimming pools, kitchens, yachts | - |
Highlight | Product Type: Smart Waterproof TV Operating System: Google system smart TV Content Availability: 700,000+ movies and TV shows Safety Features: DC 12volt voltage, IP66 waterproof rating Functionality: Can be used as a mirror Smart Home Features: Supports ARC CEC WiFi, wireless connection, voice control with Google Assistant Audio Features: Dual front speakers Display Quality: 1080P Full HD, 16:9 aspect ratio, 8-bit color panel, 16.7 million colors, 500 nits brightness Installation: Wall mounted, includes bracket for easy setup Suitable Environments: Hotel bathrooms, saunas, humid environments | Product Type: Bathroom/Hotel TV Size: 27” Waterproof Rating: IP66 (TV), IP68 (remote) Tuner Support: ATSC (other standards available upon request) Smart Features: Android 11.0, Full HD (1920x1080), no aerial required Audio: Built-in 2 vibration speakers, Bluetooth connectivity Interfaces: TV, 2x HDMI, 2x USB, Audio Out, LAN, Integrated Wi-Fi Pre-installed Apps: YouTube, Netflix Power Supply: 12 Volt DC, mains 240-adaptor included Dimensions: Unit: 613x375x51 mm (24”x15”x2”); Recess: 575x276x30 mm (W22.6”x H10.9”x D1.2”); VESA: 100x100 mm (3.93”x3.93”) Installation: Includes embedded bracket for in-wall and wall bracket for on-wall installation. | Dimensions: 27-inch unit: 26.7” x 17.6” x 1.5”; wall bracket: 25.8” x 17” x 1.3” Viewing Experience: ATSC tuner, Full HD (1920x1080), 178° viewing angles, HDMI input, Bluetooth compatibility Operating System: Android 11, 2.4/5GHz Wi-Fi, LAN, 8GB RAM, 64GB ROM, 500-nit brightness Package Includes: Smart waterproof mirror TV, IP68 waterproof remote, Bluetooth remote, DC12V power adapter, wall mount, installation manual Waterproof Rating: IP66, designed for wet environments Features: Multifunctional smart TV and mirror, suitable for bathrooms, kitchens, gyms, luxury hotels, salons | - |
System
Operating System | Android | Android | Android | - |
Internet Applications | Netflix, Pandora, Vudu, Facebook, YouTube | Netflix, Vudu, Amazon Instant Video, YouTube, Browser | Netflix, Skype, Hulu, YouTube, Browser | - |
Remote Control | Infrared | Infrared | Bluetooth | - |
Controller Type | Remote Control | Hand Control | Remote Control, Touch Control | - |
Aspect Ratio | 16:9 | 16:9 | 16:9 | - |
Display Technology | LED | LED | LED | - |
Screen Finish | Flat | Flat | Glossy | - |
Has Color Screen | Yes | Yes | - | - |
Resolution | 1080p | 1080p | 1080p | - |
Refresh Rate | 60 | 60 Hz | 60 Hz | - |
Response Time | - | 8 Milliseconds | 6 Milliseconds | - |
HDR Format Supported | - | - | - | - |
Maximum Display Brightness | - | 300 Candela Per Square Meter | - | - |
Display Backlight | - | LED | LED | - |
Display Backlight Setting | Adjustable | Dimming | - | - |
Picture Quality Enhancement | - | - | High brightness, nano-silver glass mirror finish | - |
Motion Enhancement | - | - | - | - |
Audio
Number of Audio Channels | - | - | stereo | - |
Audio Output Mode | Stereo | Surround | Surround | - |
Audio Input | Optical | 3.5mm | USB, HDMI | - |
Speaker Description | - | Built-in 2 pcs 5W Speakers | Built-in waterproof speakers, 8Ω, 10W x 2 | - |
Connectivity
Connectivity Technology | Wi-Fi | Ethernet, WIFI, LAN, TV, HDMI, Bluetooth | Wi-Fi | - |
Bluetooth Version | - | - | 4.2 | - |
Screen Mirroring | - | - | - | - |
Total Usb Ports | 1 | 2 | 2 | - |
Number of HDMI Ports | 1 | 2 | 2 | - |
Connector Type | - | Ethernet, HDMI | USB, HDMI | - |
Signal Format | - | ATSC | ATSC (digital) | - |
Video Encoding | MPEG-2, H.264 | - | AVC | - |
Compatible Devices | - | Speaker | Laptop, Gaming Console, Smartphone, Headphone, Tablet, Smart Home Devices | - |
Tuner Type | ATSC | ATSC, DTV | ATSC | - |
Noteworthy Features | Built-In Speaker | Flat | Full touch screen, IP66 waterproof, Smart tv hidden in mirror | - |
Measurements
Dimensions D x W x H | 5"D x 26.85"W x 19.53"H | 2"D x 24"W x 15"H | 1.7"D x 26.7"W x 17.6"H | - |
Item Weight | - | 8 Kilograms | 19.84 Pounds | - |
Screen Size | 24 Inches | 27 Inches | 27 Inches | - |
Product | PROS AND CONS |
SYLVOX | Pros • Many features available • Works seamlessly with various apps • Resistant to fog in steamy environments • Great design and aesthetic appeal • Satisfied users recommend the product Cons • Poor picture quality in well-lit conditions • Sound quality is lacking; may require external speakers or headphones • Installation may pose challenges for some users |
Soulaca | Pros • Smart TV functionality • Waterproof design • Mirror-type screen ideal for jacuzzi settings • Good overall quality Cons • No specific drawbacks mentioned Overall Impression The product is a highly recommended waterproof smart TV with a mirror-type screen, ideal for use in humid environments like a jacuzzi. Users have reported satisfaction with its quality and functionality. |
Haocrown | Pros • Waterproof design suitable for bathroom use • 27" size offers a good viewing experience • Smart touch screen for easy navigation • Simple installation process Cons • Universal remote does not come with a battery • Uncertainty about battery type for the remote Overall Impression This waterproof bathroom mirror TV is a stylish and functional addition to any bathroom, enhancing both the aesthetics and entertainment options. Its easy installation and smart touch screen make it user-friendly, although potential buyers should be aware of the missing remote battery. |
