SYLVOX 65 inch Partial Sunshine Outdoor TV: Can a Waterproof 4K Smart TV Really Shine in Partial Sunshine?
joe603
  1. 1 Spec
When we think of outdoor entertainment, the first image that often comes to mind is a simple projector and a screen under the stars, right? But what if I told you that the SYLVOX 65 inch Outdoor TV is challenging that notion entirely? This isn't just a TV; it's a robust piece of technology designed to withstand the elements while delivering stunning 4K visuals.
With an impressive 1000 nits of brightness, it claims to bring the cinema experience to your backyard, even in partial sunshine. But does it really live up to those promises? Is this waterproof, weatherproof gadget worth your investment, or just another overpriced piece of tech that won't last past the first rain?
Join me as we dive into the features, performance, and real-world usability of the SYLVOX Outdoor TV—because, in a world where outdoor entertainment is becoming more mainstream, it’s time to question whether we need an outdoor TV at all.
Spec​
SYLVOX 65 inch Partial Sunshine Outdoor TV​
65 Inches​
$2199​
Model Year​
2022​
Specific Uses​
Home Viewing​
Google TV​
【Different Outdoor Experience】 SYLVOX outdoor TV is equipped with 4k Ultra HD resolution, supports HDR, and 1000nits high brightness, which can bring you excellent viewing effects during the day.
【Waterproof TV】: Weatherproof TV with IP55 waterproof rating, not afraid of rain. With dustproof, sunscreen, and anti-inclement weather ability.
【Durable Outdoor TV】: The TV is made of aluminum alloy body, the surface is added with special metallic paint, dust-proof, anti-corrosion, anti-scratch, can protect the expensive TV for several years, prolonging the life of the TV.
【Smart TV with Google Assistant】Access all your favorite streaming apps in one place with Google TV. Simply use your voice to search and ask questions with Google Assistant, making it easy to find what you want. Additionally, you can effortlessly stream to your TV using casting apps.
【Wide Compatication】With its versatile output hub featuring 12 ports, alongside robust WiFi and Bluetooth capabilities, this device enables you to effortlessly play content from a multitude of devices. Also works with Firestick, Roku or more device.
Operating System​
Linux​
Internet Applications​
Google TV​
Bluetooth​
Aspect Ratio​
16:9​
Display Technology​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
60 Hz​
HDR Format​
HDR10​
Maximum Brightness​
1E+3 Nit​
High Brightness, 4K UHD, HDR​
Audio Output​
Stereo​
Audio Input​
USB, HDMI
Speaker Description​
Two speakers, each with 10W audio output​
Screen Mirroring​
Miracast​
Laptops, Desktops, Gaming Consoles, Firestick, Roku, Television, Tablets, Car Audio Systems, Cellphones​
Tuner Type​
ATSC​
Line Voltage​
100-240 VAC 50-60 Hz​
Weatherproof​
Mount Standard​
400 x 200 mm​
USB​
Bluetooth Version​
5.0​
Wireless Technology​
Wi-Fi​
Usb Ports​
2​
Audio Out Ports​
2​
HDMI Ports​
3​
Connector Type​
usb, hdmi, bluetooth​
Signal Format​
ATSC, NTSC​
Sharing Direction​
Mobile to TV​
Hardware Interface​
Bluetooth, USB​
D x W x H​
3.44"D x 57.61"W x 34.8"H​
I'm considering the SYLVOX 65 inch Outdoor TV and would love your thoughts on its picture and sound quality, especially in partial sunshine areas. Does the 4K Ultra HD and HDR really deliver a great viewing experience outdoors? I’m also curious about the sound quality—does it hold up in open spaces, or will I need external speakers to get a decent audio experience?
Additionally, how well does the smart system work with Google Assistant? Is it user-friendly when accessing streaming apps? I’m also interested in the durability—does the waterproof and weatherproof features truly live up to expectations? Any potential downsides I should be aware of before making a purchase?
Thanks for any insights you can share!
