Supersonic SC-2814 vs Othoig 14'' Portable TV: A Comparison of 14-Inch TV Options for Your Viewing Needs
ApaHualpa
Supersonic SC-2814 TV​
Othoig14'' Portable TV​
$109​
$99.99​
Model Year​
2020​
2022​
Specific Uses​
Home viewing, RVs, kitchens, outdoors, on-the-go entertainment​
Home Viewing​
Screen Size: 14-inch LED
Image Quality: Crystal-clear, vibrant, sharp
Connectivity: USB, AC/DC, MMC, compatible with Firestick, Roku, Chromecast
Built-in Features: Digital TV tuner
Power Source: Built-in lithium battery
Portability: Designed for versatile use in various settings
Screen Size: 14 inch
Network Compatibility: Not compatible with wifi/bluetooth/satellite/other networks
Audio: Double firing speakers, 5W throughput capacity each
Power Options: AC and DC powering capability
Tuner Type: Digital HDTV with ATSC tuner
Frequency Range: ATSC: 54MHz~803MHz; NTSC: 55.25MHz~801.25MHz
Ports: Audio IN/OUT, 1 HDMI, 1 USB
Remote Control: Yes
Unboxing Experience​
Supersonic SC-2814 TV:​
The Supersonic TV features a compact design, making it suitable for small spaces like workbenches or kitchens. Users noted that it comes with a small stand, although assembly can be tricky due to poorly aligned screw holes. The overall aesthetics are considered decent for a portable TV, but some users received slightly different models than pictured, leading to confusion regarding their specific model's features.
Othoig14'' Portable TV:​
The TV has a compact and lightweight design, making it easy to transport and set up in various locations. Its small size makes it suitable for different environments, such as kitchens, porches, or even in a van for those living a mobile lifestyle. The inclusion of VESA mounting holes allows for easy wall mounting, enhancing its versatility as a space-saving option.
Side-by-Side Comparison​
System​
Internet Applications​
Browser​
fire tv,roku tv​
Infrared​
Setting up the Supersonic TV is generally straightforward for those with technical knowledge. Users reported that the initial setup and channel scanning processes were easy, although the included instructions were found to be lacking and often confusing. Many advised connecting the TV to a better antenna to enhance reception, as the included options were inadequate for most users.
Setting up the TV is straightforward, with many users reporting that they were able to start watching their favorite programs almost immediately. The unit comes with various accessories, including a portable antenna, power adapters, and cables, which facilitate a simple and quick installation process. However, some users noted difficulty in properly assembling the antenna due to a lack of clear instructions.
Aspect Ratio​
16:9​
16:10​
Display Technology​
LED​
Screen Finish​
Flat​
Flat​
Has Color Screen​
Yes​
Resolution​
1080p​
720p​
Refresh Rate​
60 Hz​
The picture quality of the TV is often praised, with many users noting that it delivers a sharp and vivid image, especially when viewed straight on. However, the vertical viewing angle is less favorable, with colors becoming washed out if viewed from above or below. The settings allow for some adjustments, and users reported satisfaction with the picture when utilizing the right mode, such as "Soft" or "Standard."
The picture quality is generally well-received, especially when viewed head-on, although some have found the brightness and contrast settings lacking. Viewers have been able to access a significant number of channels, providing a great selection of content. However, certain users reported issues with the TV reverting to Spanish language settings, which caused frustration during their viewing experience.
Audio​
Audio Output​
Stereo​
Audio Input​
USB, HDMI
USB, HDMI
Speaker Description​
Built-in speakers​
Double firing speakers, 5W each​
Audio Experience​
The sound quality of the Supersonic TV is described as decent, with users mentioning that it can get reasonably loud. However, some found the sound to be somewhat tinny, particularly when the volume is cranked up. Users who connected external speakers reported improved audio performance, indicating that while the built-in speakers are adequate, they could benefit from additional sound equipment for a better experience.
The sound quality received mixed reviews. While some users appreciated the audio clarity, others described it as flat and tinny, suggesting that it might not meet the expectations for a more immersive sound experience. The sound has been adequate for casual viewing, but it may lack the depth desired for movie nights or gaming sessions.
AVC​
Screen Mirroring​
Miracast​
Laptops, Desktops, Gaming Consoles, Tablets, Cameras, Cable/Satellite Set-Top Boxes, Over-the-Air Antennas​
[VARIOUS]​
Tuner Type​
ATSC​
ATSC​
Voltage​
12 Volts (DC)​
Line Voltage​
100-240 VAC 50-60 Hz​
Digital TV Tuner​
Flat​
D x W x H​
1"D x 2"W x 8.9"H​
1.19"D x 13.2"W x 9.8"H​
Motion & Gaming​
There are limited reviews specifically addressing gaming performance; however, some users appreciate the TV's versatility for various media inputs. The ability to connect to gaming consoles or external devices likely enhances its usability, though feedback on lag or responsiveness during gaming was not prominently noted.
The TV is praised for being a portable option for gaming, fitting easily into a laptop bag and functioning well with a DVD player or games console. This makes it an appealing choice for those who want to enjoy gaming on the go or during travel. However, specific gaming performance feedback was not extensively provided.
Connectivity​
HDMI
HDMI
Wireless Technology​
Radio Frequency​
Usb Ports​
1​
HDMI Ports​
1​
1​
Audio Out Ports​
2​
1​
Connector Type​
USB​
USB​
Signal Format​
Digital​
digital​
Compatibility​
The Supersonic TV includes various input options, enabling users to connect additional devices. It also has a USB port that users have found useful for powering accessories like antennas. However, users reported that the remote control's functionality can be hit or miss, with some having difficulty due to hard-to-press buttons.
The TV includes a built-in rechargeable battery, which is a standout feature for emergency situations or outdoor use. It has multiple power options, such as a 12-volt requirement and compatibility with both power adapters and cigarette lighter connectors. Additionally, it boasts a multimedia player for playing files from a USB drive, enhancing its functionality.
• Good picture quality with vivid colors
• Easy setup for tech-savvy users
• Multiple input options for versatility
• Adequate sound quality with external speaker support
• Poor reception with included antennas
• Instructions are unclear and often unhelpful
• Limited vertical viewing angles affect picture quality
• Remote control buttons require significant pressure to operate
The Supersonic TV is a compact and functional option for those needing a small screen for various uses, particularly in emergency situations or for portable setups. The performance largely depends on the quality of the antenna used and the user's technical proficiency during setup. While it has its drawbacks, particularly regarding the included accessories and remote control, most users find it satisfactory for casual viewing needs, making it a reasonable purchase for its price range.
• Compact and lightweight design
• Easy setup and installation
• Good picture quality when viewed straight on
• Built-in rechargeable battery for emergency use
• Multiple power options and input ports
• Sound quality can be flat and tinny
• Issues with reverting language settings to Spanish
• Lack of clear instructions for assembly of accessories
• Some users experienced reliability issues after a short period
This TV offers a solid balance of affordability and functionality, making it a great option for those looking for a portable viewing solution, especially in emergency situations. While it excels in versatility and ease of use, certain drawbacks such as sound quality and language settings may detract from the overall experience for some users. Nonetheless, it stands out as a valuable addition to any home, kitchen, or outdoor setup.
Charger196904
We've had our little Supersonic battery TV for over 20 years for when the power goes out. The battery's getting old, so we wanted a bigger screen. This 14-inch one has awesome picture and sound, and the battery charges fast! Totally recommend Supersonic!
Wwalmarts
The Supersonic SC-2814 TV is awesome for watching CCTV, but I learned the hard way to always use a surge protector. Mine broke when it got hit by a power surge. Keep it safe!
PlayStationPepe
Just got the Othoig 14" Portable TV for our teardrop camper, and it's perfect! Super quick delivery, no damage at all. Haven't tried it out yet, but we’re totally pumped!
