Unboxing Experience
- 1.1.1 Supersonic SC-2212 TV:
- 1.1.2 Feihe 22 Inch TV:
1.1
Unboxing Experience
2
Side-by-Side Comparison
- 2.1 System
2.2
- 2.2.1 Supersonic SC-2212 TV:
- 2.2.2 Feihe 22 Inch TV:
- 2.3 Display
2.4
Viewing Experience
- 2.4.1 Supersonic SC-2212 TV:
- 2.4.2 Feihe 22 Inch TV:
- 2.5 Audio
2.6
Audio Experience
- 2.6.1 Supersonic SC-2212 TV:
- 2.6.2 Feihe 22 Inch TV:
- 2.7 Features
2.8
Motion & Gaming
- 2.8.1 Supersonic SC-2212 TV:
- 2.8.2 Feihe 22 Inch TV:
- 2.9 Connectivity
2.10
Compatibility
- 2.10.1 Supersonic SC-2212 TV:
- 2.10.2 Feihe 22 Inch TV:
- 3 Conclusion
Parameter | Supersonic SC-2212 TV | Feihe 22 Inch TV |
Reference Price | $15.99 | $169.99 |
Model Year | - | 2023 |
Specific Uses | - | Home Viewing |
Highlight | Product Type: Remote Control Compatibility: SuperSonic LED TV/DVD Combo models SC-1311, SC-1312, SC-1511WHT, SC-1512, SC-1912, SC-2212 Setup: Ready to use out of the package Battery Requirement: 2 x AAA Batteries | Screen Size: 22 inch Type: Not Smart TV Resolution: 1920x1080 Refresh Rate: 60Hz Aspect Ratio: 16:9 Viewing Angle: 170° Ports: USB, RF In (ATSC), 12V DC, AV, VGA, HDMI, Headphone Jack Audio: Built-in speakers Tuner: ATSC Tuner Remote Control: Unique remote, not compatible with Xfinity/Direct TV/Comcast/Verizon Mounting: Wall-mountable (100mm x 100mm) Use Cases: Kitchen, RV, portable TV Compatibility: Computer, DVR, Apple TV, Amazon Firestick, Roku, Slingbox, Chromecast, DVD players, game consoles |
Unboxing Experience
La apariencia del producto es bastante sencilla y funcional. Tiene un diseño compacto y ligero, ideal para ser portátil y fácil de manejar. La construcción parece robusta, lo que es un plus para un dispositivo que se espera usar en diferentes situaciones.Feihe 22 Inch TV:
The TV presents a modern design that fits well in various settings, including kitchens and RVs. Its size is suitable for compact spaces, and the overall aesthetic seems to cater to consumers looking for functionality without compromising style.Side-by-Side Comparison
System
Operating System | - | Not Smart TV |
Internet Applications | - | NO SMART TV |
Remote Control | - | Infrared |
Controller Type | Button Control | Remote Control |
Control Method | - | Remote |
La configuración fue increíblemente fácil; simplemente inserté las baterías y el dispositivo comenzó a funcionar de inmediato. No tuve que lidiar con complicaciones adicionales, lo que hizo que la experiencia de instalación fuera muy fluida.Feihe 22 Inch TV:
Setting up the TV involved some challenges, particularly in connecting it to cable services. While it arrived well-packaged and was easy to mount, there were complaints about the lack of clear instructions in the manual, which did not adequately guide users in setting up their cable connections. This lack of support left some users frustrated and led to the return of the product.Display
Aspect Ratio | - | 16:9 |
Display Technology | - | LED |
Screen Finish | - | Flat |
Resolution | - | 1080p |
Refresh Rate | - | 60 Hz |
Maximum Brightness | - | 350 Nit |
Backlight Technology | - | LED |
Viewing Experience
Sin embargo, la experiencia de visualización fue decepcionante. A pesar de que el dispositivo debería haber funcionado con mi televisor, no hubo comunicación entre ambos, lo que impidió disfrutar de la experiencia visual que esperaba.Feihe 22 Inch TV:
The viewing experience varied significantly among users. While some praised the clear picture quality and vibrant colors, others reported issues with the TV’s performance from different angles, noting that the picture could wash out when viewed from below. There were also mentions of a blue line appearing on the screen, which detracted from the overall enjoyment.Audio
Audio Channels | - | 2 |
Audio Output | - | Stereo |
Audio Input | - | RCA, USB, HDMI |
Speaker Description | - | state-of-the-art speakers |
Audio Experience
No tuve la oportunidad de evaluar la calidad de sonido, ya que el dispositivo no funcionó como se esperaba. Sin embargo, asumiendo que se conecta a un televisor, la calidad podría depender de las capacidades del televisor en sí.Feihe 22 Inch TV:
Sound quality received mixed reviews. While some users found it acceptable for casual viewing, others highlighted poor audio performance, leading to dissatisfaction. The need for additional remotes for sound control further complicated the audio experience for some users.Features
Compatible Devices | Television | [Inferred from product details: HDMI devices, VGA devices, USB devices, AV IN devices, COAXIAL devices, Amazon Firestick, video game consoles, devices with AC power, devices with car power] |
Tuner Type | - | ATSC |
Voltage | - | 12 Volts (DC) |
Line Voltage | - | 110 VAC 60 Hz |
Other Features | Ergonomic | RV TV |
D x W x H | - | 0.78"D x 19.88"W x 14.17"H |
Motion & Gaming
No pude probar el dispositivo para juegos debido a su falta de funcionamiento con mi televisor. No puedo ofrecer una opinión sobre su rendimiento en este aspecto.Feihe 22 Inch TV:
The product does not appear to have specific feedback regarding gaming capabilities, as most comments focused on general TV use in various environments, such as RVs and kitchens. There were mentions of the need for multiple remotes, which could impact gaming experiences if the user is juggling control between the TV and other devices.Connectivity
Connectivity Technology | Infrared | HDMI/VGA/USB/AV IN/EARPHONE/COAXIAL |
Wireless Technology | - | ATSC |
Usb Ports | - | 1 |
HDMI Ports | - | 1 |
Connector Type | - | VGA, HDMI |
Signal Format | - | digital |
Compatibility
Las características adicionales no fueron evaluadas, ya que el principal propósito del dispositivo, que era interactuar con la televisión, no se cumplió.• Pros:
- Diseño compacto y ligero
- Configuración sencilla y rápida
• Cons:
- No funcionó con el televisor
- Decepcionante experiencia de visualización
Feihe 22 Inch TV:
The TV offers a 1040 resolution, which is a plus for smaller models, and it can be powered by both 12v and 120v, making it versatile for different settings like RVs or boats. However, the absence of smart features and the lack of an included antenna were notable downsides.Conclusion
Overall Impression:Mi impresión general del producto es negativa. Aunque la instalación fue fácil y su diseño es atractivo, el hecho de que no funcionara con mi televisor eclipsa cualquier aspecto positivo. Me siento frustrado por la falta de comunicación entre el dispositivo y la TV, lo que impidió disfrutar de su funcionalidad.
Feihe 22 Inch TV:
Pros:• Good quality picture and color
• Perfect size for small spaces
• Versatile power options (12v and 120v)
• Affordable compared to competitors
• Poor sound quality
• Difficult setup with cable services
• Picture quality can wash out from lower angles
• Inadequate customer support and manual instructions
Overall, the TV serves as a functional option for those needing a small screen for specific environments like kitchens or RVs. While it has its merits, particularly in picture quality and size, the issues with setup, sound quality, and customer support may deter some buyers. It can be a good choice if one is willing to navigate these challenges.
