Supersonic SC-1511 vs Othoig 15.6 Inch TV: Which 1080p Model is More Popular for Your Viewing Needs?
Supersonic SC-1511​
othoig 15.6 inch Small TV​
Price​
$175.99
$139.49
Model Year​
2015​
2023​
Specific Uses​
Home viewing, dorm rooms, secondary TV placements​
[INF] portable entertainment, traveling, kitchen TV, secondary TV​
Resolution: 1080p
Connectivity: HDMI, USB, AC ports
Compatibility: Amazon Firestick, gaming consoles
PC Monitor Functionality: Yes, via HDMI
Value Proposition: Affordable big screen TV option
Screen Size: 15.6 inches
Resolution: 1080P
Picture Quality: High Definition, detailed and colorful
Design: Exquisite, compact, lightweight, portable
Connectivity: HDMI, USB, VGA
Audio Quality: High quality with built-in stereo speakers
Use Cases: Home, office, on-the-go entertainment
Side-by-Side Comparison​
System​
Supersonic SC-1511​
Operating System​
Android​
Android​
Internet Applications​
Google TV​
Google TV​
Infrared​
Iris​
Supersonic SC-1511​
Aspect Ratio​
16:9​
1.77:1​
Display Technology​
LED​
LED​
Screen Finish​
Glossy​
Flat​
Color Screen​
Yes​
Yes​
Resolution​
1080p​
1080p​
Refresh Rate​
60 Hz​
60 Hz​
Response Time​
16 Milliseconds​
Maximum Brightness​
180 Nit​
Backlight Technology​
LED​
LED​
Backlight Setting​
VA1, VA2, VA3, VA4, VA5​
[INF] Digital Noise Reduction, Picture Modes​
1080P, LED​
Audio​
Supersonic SC-1511​
Audio Channels​
2.0​
2.0​
Audio Output​
Stereo​
Audio Input​
HDMI
USB, HDMI
Speaker Description​
Audio output power: 2 x 3W; Picture mode: User, Standard, Dynamic & Soft; Sound mode: Standard, Music, Movie, User & Sport; Separate Bass, Treble & Balance Controls; Sleep Timer Function​
built-in stereo speakers​
Connectivity​
Supersonic SC-1511​
HDMI
HDMI
Screen Mirroring​
Google Cast (Chromecast)​
Miracast​
Total Usb Ports​
1​
1​
Total HDMI Ports​
2​
1​
Connector Type​
HDMI
USB​
Signal Format​
digital​
digital​
Supersonic SC-1511​
AVC​
Water Resistance​
Not Water Resistant​
Amazon Firestick, Gaming Consoles, Headphones​
[Multiple]​
Tuner Type​
ATSC​
ATSC​
Voltage​
240 Volts​
12 Volts (DC)​
HDMI Input Compatible​
TV​
Measurements​
Supersonic SC-1511​
D x W x H​
8.07"D x 28.81"W x 8.07"H​
1.6"D x 11.8"W x 11"H​
Item Weight​
2.64 Pounds​
16 Inches​
15.6 Inches​
Product
PROS AND CONS​
Supersonic SC-1511​
Pros
• Perfect size for small spaces (32" fits well in limited areas)
• Good picture quality at 1080p, an upgrade from older models
• Compatible with DVDs and computer connections
• Easy to set up with external speakers and DVD/Blu-ray players
• Non-smart TV option suits specific user needs
Cons
• Poor sound quality, especially at high volumes
• Awkward design for removing the stand for wall-mounting
HDMI port placement is poorly designed, requiring adapters for proper use
• Internal speakers are inadequate and not easily upgraded
• Overall build and hardware design could benefit from significant improvement
Overall Impression
While the SuperSonic 32" TV fulfills specific needs such as size and compatibility, its design flaws, particularly concerning the HDMI port and sound quality, significantly detract from its overall usability. It may work well for users who prioritize size over advanced features, but improvements in design and functionality are necessary for a better user experience.
Pros
• Perfect size for kitchen counter
• Clear picture quality
• Good sound quality for a small TV
• Receives many channels
• Handy for portable use (e.g., on a boat)
• Simple remote control
• Great price
Cons
• Occasional channel switching to Spanish
• Picture quality can be less sharp
• Some sound issues from speakers on the back
• One unit had no picture despite power
Overall Impression
This TV is an excellent choice for those needing a compact and versatile option for spaces like kitchens or boats. Its clear picture and good sound quality make it a standout for its size and price, though there are minor issues with channel switching and picture sharpness. Overall, it's a solid buy for casual viewing.
