Amnesia
Sony XBR-55X800G has a low cost performance, and the configuration and picture quality are relatively mediocre. Ordinary mid-end machine grades are not recommended. Sony XBR-55X800G, although with "8" and "G", but without the 8 series' SonyX1 image quality processing chip, 120HZ screen refresh rate.
In Sony TVs "G" means a new model in 2019, in general, a new "G" model often run with Android 8.0 system, new remote control , new voice assistant, support Dolby Vision, performance upgrade (A73 quad core 1.5GHZ, 3GB running memory ), However, Sony XBR-55X800G came up with the configuration of last year, Android 7.0, the old remote control, the old version of the voice assistant, does not support Dolby Vision, and the performance is also the configuration of last year (A53 quad-core 1.5GHZ, 2GB running memory).
Sony XBR-55X800G Pros:
Sony XBR-55X800G Cons:
In a word, Sony XBR-55X800G is a tv being sold as new with an outdated OS - Android TV 8 (10 was released Jan 2020) and Sony has no plans to update it further. That means it's integration with Google assistant is MINIMAL, you can play content from a small handful of services. Power and volume are flaky. Now you can use the remote to talk to the tv and get more done, but IMO that's not the point of a service integration.
- good picture quality due to 4K X-Reality PRO
- Pretty light for a tv this size.
- Nice remote that has everything and more.
- Easily set up
- Well priced considering the features.
- sound quality is not good enough, still needs a sound bar
- picture from iPad ,iPhone can not mirror
- Android system can be so slow. Changing channels can take several seconds to happen.
- Doesn’t work unless it’s plugged in.
- Bluetooth module is not fully support all Bluetooth devices.
- there is no browsers like others TV to surf on the internet.
