Robert
The major 2021 SONY TV models have all been released, with the X90J(X91J) and X95J attracting the most attention. Let's see the comparative review.
The main difference between X90J and X91j is the appearance, if you want 85" large screen you can choose X91j. Now, let's check out SONY X90J and SONY X95J.
Sony X90J VS. X95J
In terms of appearance design, SONY X90J has abandoned the ultra-narrow frame of X9000H series, and turned to the current mainstream full screen design, using seamless splintered frame design. SONY X95J also uses bezel-less design, upgraded to aluminum alloy integrated edge like Z9J, with metal wire drawing process, when the TV is off the screen, you can only see a whole black panel, the overall visual effect is very strong.
The main difference between X90J and X95J is in brightness performance.
In the Dolby Vision movie, the difference in brightness between the SONY X90J and X95J is very small, but the picture is still different. The SKIN color of the X95J is more suitable for the human eye, while the SKIN color of the X90J is slightly redder. Not only that, SONY X95J in the film dark details performance, also significantly better control, closer to the TRANSPARENT OLED TV.
For Alita, SONY X95J is more yellow, and the picture of X90J tends to feel cold white. Although many people prefer the feeling of X90J, the color of X95J is closer to the original film, showing the sense of the director's color.
In the performance of facial details, not only can we see the difference in color, but also the SONY X95J has more facial details, and the complex facial lines are very clear.
model | X90J | X91J | X95J |
Screen Sizes | 50" / 55" / 65" / 75" | 85" | 65" / 75"/ 85" |
Display Technology | Full-Array LED | Full-Array LED | Full-Array LED |
Display Resolution | 4K HDR | 4K HDR | 4K HDR |
Picture Processor | Cognitive Processor XR | X1 4K HDR Processor | Cognitive Processor XR |
Color | XR TRILUMINOS PRO | TRILUMINOS | XR TRILUMINOS PRO |
Contrast | XR Contrast Booster 5 | X-tended Dynamic Range | XR Contrast Booster 10 |
Motion Technology | XR Motion Clarity (120Hz) | X-Motion Clarity (120Hz) | XR Motion Clarity (120Hz) |
Enhanced Viewing Angle | — | — | X-Wide Angle/X-Anti Reflection |
Google TV/Hey Google | Yes | Yes | Yes |
Works With Alexa | ✔ | ✔ | ✔ |
Apple Airplay | ✔ | ✔ | ✔ |
Sony X90J VS. X95J
