What Samsung TV users asked about most often is why the TV Screen does not display properly. If you have this issue, this article will help you solve it.
If the issue persists, define exactly what is wrong with the display. For example, mosaics and blocks, multiple lines or white dots or fixed horizontal or vertical lines.
Press the HOME button on the remote, and select Connected Devices, then choose another input source.
If the same problem persists, run a diagnostic test. On the remote control, press the HOME button, and follow this path: Menu>Settings>Support>Device Care>Self Diagnosis>Picture Test
When a test message appears, select OK and follow the on-screen instructions to complete the test.
If the problem disappears during the test, check your TV signal strength: Menu>Settings>Support>Device Care>Self Diagnosis>Signal Information. Now you can check whether the signal strength is too weak or not.
1. Check the antenna and input cable connections
hdmi-cable-connections" >2. Check the antenna and HDMI cable connections
3. Try changing channels using the remote control
4. Check the picture test
5. Check the signal strength
