SLLEA AC/DC Adapter Projector: Is Your Optoma Pico Projector Ready for Power or Just a Disappointment in Charging?
promicoy
  1. 1 Spec
When it comes to powering portable projectors, the conversation often shifts to the importance of versatility and reliability. Enter the SLLEA AC/DC Adapter Charger designed for the Optoma Pico PK301 and PK320 projectors. On the surface, it seems like just another charger—lightweight, easy to carry, and CE certified. But is it really the dependable partner you need for your on-the-go presentations, or just another accessory that might leave you high and dry?
Today, we’ll dive into the nuances of this adapter, examining its build quality, safety features, and overall performance in real-world scenarios. Let's unpack whether this charger is truly fit for purpose or if it merely rides the coattails of its well-known projector counterparts. After all, when it comes to keeping your tech powered, can we really afford to settle for anything less than the best?
Spec​
SLLEA AC/DC Adapter Projector​
Input: 100 - 240 VAC 50/60Hz Worldwide Voltage Use Mains PSU; Cable Length: total 4FT, no worry about the distance between the device and socket.
Industry Quality: CE certified and tested by manufacture. Over Voltage Protection, Over Heat Protection.
Note: Please make sure the model of your device whether it is the same as the listing shows before purchasing.
Convenience: This lightweight and easy-to-carry adapter is the ideal portable power source for your device.
10 watts​
Powerline​
Tablets​
portable​
I’m considering purchasing the SLLEA AC/DC Adapter Charger for my Optoma Pico PK301 PK320 Pocket DLP Projector and would love some advice from those who might have experience with it.
First off, how does the picture quality hold up when using this charger? I want to ensure that I’m not compromising on image clarity or brightness.
Also, what about sound quality? I know it’s an adapter, but any insights on how it impacts audio performance would be helpful.
Lastly, I’m curious about the overall system compatibility and any potential downsides you’ve encountered. Is it reliable for long-term use or should I be cautious?
Thanks in advance for your help!
