Skyworth 24P100 vs SYLVOX Portable TV vs Desobry Portable TV: Which is the Best Portable TV for Your Needs?
WWGHIAFTC
Skyworth 24P100​
SYLVOX Portable TV​
Desobry Portable TV​
Price​
$399.99
$399
$169.99
Model Year​
2024​
2024​
Specific Uses​
Multimedia​
Entertainment​
Entertainment, Gaming​
Google TV Integration: Stream movies, shows, and live TV in HD; personalized recommendations; explore free channels; suitable for home or camping.
Matte Screen with Wide Viewing Angle: Reduces glare; comfortable viewing from any angle; Dolby sound for immersive HD experience; effective in various lighting conditions.
Leather Carry Handle for Portability: Stylish and easy to carry; ideal for travel and camping.
Built-In Chromecast: Stream from phone, tablet, or laptop; supports Bluetooth devices for seamless entertainment.
High-Performance Lithium-Ion Battery: Over 3 hours of uninterrupted entertainment; perfect for camping and travel.​
IP66 Waterproof: Suitable for outdoor use, resistant to rain and splashes.
Smart 1080P TV: Access to streaming, live TV, music, and Google Assistant in 1080P.
Marathon Battery Life: 10,000mAh battery provides 4.5-6 hours of viewing; recharges in 4 hours.
Portable Theater: Dimensions 14.63 x 1.24 x 10.07 inches, weight 4.85 lbs.
Voice Assistant Remote: Control entertainment using voice commands for convenience.​
Battery Operated: Built-in rechargeable battery, USB compatible, portable for various locations. AC adapter included.
Display: 15.7” Widescreen, Full HD 1080P resolution, detachable antenna tuner for digital signals.
Input/Output: HDMI/RCA input for devices (smartphones, streaming sticks, game consoles), 3.5mm headphone jack.
Audio: Built-in dual speakers, superior sound quality, personal audio experience with headphones.
File Format Support: Compatible with multiple video, audio, and image formats (MP4, AVI, MP3, JPG, etc.), supports up to 32GB FAT32.
Usage Scenarios: Easy to install, suitable for camping, emergencies, outdoor travel, and home use.​
Side-by-Side Comparison​
System​
Skyworth 24P100​
SYLVOX Portable TV​
Operating System​
Google TV​
Google TV​
Android​
Internet Applications​
Disney Plus, Netflix, HBO Max, Prime Video, Hulu, YouTube​
Google TV​
Free View​
Bluetooth​
Bluetooth​
Infrared​
Voice Control​
Voice Control​
Skyworth 24P100​
SYLVOX Portable TV​
Aspect Ratio​
16:9​
16:9​
1.33:1​
Display Technology​
LED​
LED​
Screen Finish​
Matte​
Flat​
Flat​
Has Color Screen​
Yes​
Yes​
Yes​
Resolution​
1080p​
1080p​
1080p​
Refresh Rate​
60 Hz​
60 Hz​
60 Hz​
Response Time​
HDR Format Supported​
HDR10​
At least one HDR format is supported​
Maximum Display Brightness​
300 Candela Per Square Meter​
Display Backlight​
LED​
Display Backlight Setting​
Full Array Local Dimming​
Picture Quality Enhancement​
Motion Enhancement​
Audio​
Skyworth 24P100​
SYLVOX Portable TV​
Number of Audio Channels​
2.0​
2.0​
Audio Output Mode​
Surround​
Stereo​
Stereo​
Audio Input​
HDMI​
USB​
HDMI​
Speaker Description​
Dolby Audio, Built-in Stereo Speakers​
Built-in dual speakers, supports 3.5mm headphone jack with stereo sound​
Connectivity​
Skyworth 24P100​
SYLVOX Portable TV​
Wireless​
Bluetooth, Wi-Fi, USB​
HDMI​
Bluetooth Version​
Screen Mirroring​
Chromecast​
Android & IOS​
Total Usb Ports​
1​
Number of HDMI Ports​
1​
Connector Type​
Ethernet, HDMI​
USB​
HDMI​
Signal Format​
NTSC​
Skyworth 24P100​
SYLVOX Portable TV​
HEVC Main 10​
USB Ports, Bluetooth, Wi-Fi​
Amazon Firestick, Roku, Slingbox, game consoles, smartphones, DVD players​
Tuner Type​
ATSC​
ATSC​
NTSC​
Noteworthy Features​
Chromecast, Blue Light Filter, Wide Viewing Angle, Eye Comfort Mode, Browser​
Can float on the water, Fireproof casing​
Wide Viewing Angle​
Measurements​
Skyworth 24P100​
SYLVOX Portable TV​
Dimensions D x W x H​
2.9"D x 24.6"W x 14.4"H​
1.24"D x 14.63"W x 10.07"H​
1.38"D x 13.58"W x 10.83"H​
Item Weight​
11 Pounds​
500 Grams​
24 Inches​
15.6 Inches​
15.7 Inches​
Product
PROS AND CONS​
Skyworth 24P100​
Pros
• Lightweight and compact, making it easy to transport
• Excellent picture quality for a portable device
• Versatile use—suitable for indoor and outdoor settings
• Google OS provides access to a wide range of apps
• Battery lasts longer than the advertised 3 hours
• Fast charging capability (approximately 5 hours)
• Stylish design that doesn’t look cheap
• Ideal for various activities, including camping and presentations
• Optional carrying case enhances portability
Cons
• Sound quality is average and could be improved
• Performance can be sluggish at times
• Picture and sound quality may not meet high-end expectations
• Limited competition in the portable TV market
• Potential for higher-end versions with better components and features
• May not satisfy users looking for a home entertainment solution
SYLVOX Portable TV​
• Perfect size and smart features
• Bluetooth capability
• Good build quality
• Battery life lasts up to 6 hours on a full charge
• Great sound quality
• Compatible with popular streaming apps
• Easy to set up with a handle/stand
• No power cord needed for operation
• Crisp display
• User-friendly remote
• Stopped working correctly shortly after the return window
• Limited usage before malfunction (only used 4 times)
• Currently non-functional on battery
• Screen blinks when plugged in
• Considered a waste of money after malfunctioning (described as a "300 dollar paperweight")
Pros
• Right size for small spaces
• Good picture quality, both on and off axis
• Battery operation adds portability
• Receives over-the-air signals via supplied antenna
• Multiple HDMI inputs for versatile connectivity
• Compatible with devices like Firestick and Google Cast
• Easy setup for users of all ages
Cons
• Sound quality is tinny, despite adjustments
• Short battery life, lasting only around 2 hours and 42 minutes
• Occasional issues with pixel defects in the screen
