BladeW
After entering the game Sea of Thieves, the shells, bananas and wooden boards on the ship are all the initial quantity. If you exit the game and then enter again, the basic materials will be reset. Click F to open the task you received. After selecting a task, the task will appear on the table, R is to cancel the task, F is to vote to start the task, when more people need to vote to start the task (single person does not need). After pressing F to take over the task. The treasure map will appear in your inventory, press E to open the inventory. According to the look of the island, look for it on the big map, find the right mouse button mark, and then you can go.
Sea of Thieves weapon recommendation
You can switch between your two weapons in the weapon bin on the ship, try all the weapons and find the one that suits you best.
Short sword + pistol
Suitable for most situations, especially in mid-range combat. The power is relatively weak.
Short sword + shotgun
The performance is extraordinary, especially during boarding battles, if you are used to close combat, you can choose this combination.
Shotgun + sniper rifle
If you are used to shooting enemy players first in ship battles, you can choose a combination with a sniper rifle, but when your bullets are exhausted and there are no daggers, you can only run!
Sea of Thieves: how to invites friends
Cannot invite through Steam friends, because the game is essentially using Microsoft’s Xbox account to play. Steam and Xbox friend data are not interlinked, and players can only invite friends from Xbox. Therefore, it is necessary to bind and associate the Steam account and the Xbox account. The default will be the first time you enter the game. The first time you enter the game, a website will automatically pop up in Steam's browser. If you connect to Steam, it will automatically filter out Steam friends who are connected to XboxLive, and follow him directly here. So you can invite him to play the game. If the player skipped the binding step for some reason, go directly to the Xbox console helper in the start menu, where you can re-bind.
