Significant_Rate
- 1 First Impressions
- 2 Introduce
- 3 System
- 4 Display
- 5 Audio
- 6 Features
- 7 Connectivity
- 8 User Feedback
First Impressions
The Samsung Terrace has an outstanding design that looks very similar to theSamsung The Frame 2020, but its thicker and more robust. This TV is meant to be wall-mounted and doesnt come with a stand. The feet in the picture above were purchased separately from a third party.The back of the TV is all metal, except for the plastic panel covering the inputs. There are small cable routes at the bottom of the panel to allow the cables to pass through forcable management. The panel is held by screws to protect the inputs from any potential water damage.
Exceptional build quality. Its almost entirely made out of metal, and it feels incredibly well-built. Theres no flex or noticeable gaps. Its advertised to have IP55 water resistance; however, it isnt something that we test.
Parameter | Samsung The Terrace |
Reference Price | $2497.99 |
Model Year | 2020 |
Specific Uses | Home Viewing |
Built-In Media | User Manual, E - Manual, Samsung OneRemote (TM-2095A) with Batteries, Power Cable |
Highlight | • Contrast Range: Direct Full Array 16X • Voltage: 120 volts • Viewing Angle: Wide; anti-glare screen • Outdoor Optimization: Designed for daylight viewing • Connectivity: Wi-Fi and Bluetooth • Smart TV Platform: Tizen |
System
Operating System | Tizen |
Internet Applications | Apple TV,Netflix,Browser,Hulu,Prime Video,YouTube |
Remote Control | Bluetooth |
Controller Type | vera, amazon_alexa |
Control Method | Voice |
System Experience | Overall Impression: The product features Samsung's Tizen OS, which offers a user-friendly interface and smooth performance. While there is a minor issue with Dolby Digital over HDMI-ARC, it appears to be related to the receiver rather than the TV itself. However, the presence of ads and suggested content on the home screen and app store is a drawback, as there is no option to disable them. On the positive side, the extensive app selection on Samsung's app store provides users with a wide range of options to enhance their viewing experience. |
Display Technology | QLED |
Screen Finish | Flat |
Has Color Screen | Yes |
Resolution | 4K |
Refresh Rate | 120 Hz |
HDR Format | HDR10, HDR10+ |
Picture Enhancement | High Dynamic Range |
Motion Enhancement | Motion Rate 240 |
Viewing Experience | The Samsung Terrace delivers an impressive viewing experience, particularly with its outstanding contrast ratio and full-array local dimming feature, resulting in deep blacks and a vibrant HDR color gamut. While it excels in color coverage for DCI P3 and demonstrates decent performance for Rec. 2020, some scenes may appear overly bright, necessitating manual adjustments for optimal settings. The black uniformity is superb with minimal clouding, although gray uniformity varies and can be distracting in certain scenarios. Reflection handling is exceptional, making it suitable for outdoor use, while the sub-par viewing angles may limit its effectiveness in wide seating arrangements. Overall, the Samsung Terrace stands out for its brightness and contrast capabilities, though users should be mindful of its potential uniformity issues and viewing angles. |
Audio
Audio Output | Surround |
Audio Input | HDMI |
Speaker Description | 2-channel speaker system |
Audio Experience | Overall, the Samsung Terrace offers decent audio performance with clear dialogue delivery, making it suitable for outdoor use, particularly at high volumes. However, it lacks bass extension, limiting the depth of sound for those seeking a richer audio experience. The distortion is minimal, ensuring that sound remains relatively clean even at higher volumes. While it can effectively serve outdoor gatherings, those desiring enhanced sound quality may consider the optional Terrace Soundbar for a more immersive experience. |
Video Encoding | HEVC or VP9 |
Compatible Devices | Speaker, Gaming Console, Smartphone, Headphone, Tablet, Laptop |
Water Resistance | Water Repellent |
Tuner Type | ATSC |
D x W x H | 2.4"D x 49.1"W x 28.7"H |
Voltage | 120 Volts (AC) |
Other Features | Outdoor-Optimized QLED Picture, Wide Viewing Angle with Anti-Glare, Direct Full Array 16X, Quantum HDR 32X, Quantum Processor 4K, 100% Color Volume with Quantum Dot, Real Game Enhancer+, Motion Rate 240, Adaptive Picture, Solid Metal Design, Weather-Resistant Durability IP55 Rated, Smart TV Powered by Tizen, Universal Guide, Ambient Mode+, Multiple Voice Assistants, TV Plus, Mobile View, Samsung OneRemote, SmartThings Compatible, CTA 4K Ultra HD Connected, HDR10+ |
Motion Smoothing | The Samsung Terrace offers a commendable response time, effectively minimizing blur trails behind fast-moving objects. However, it experiences notable overshoot in low transition ranges, which can lead to motion artifacts, particularly in darker scenes. The TV employs PWM for backlight dimming, resulting in noticeable flickering at certain settings, although it is generally imperceptible in Movie or Game modes. Additionally, while the device can interpolate lower frame rate content up to 120fps for smoother motion, this feature is marred by significant artifacts during fast-moving scenes. Overall, the Samsung Terrace presents a mixed performance, excelling in response time but suffering from motion-related issues that may affect viewing quality in certain scenarios. |
Connectivity
Connectivity Technology | Bluetooth, Wi-Fi, RF, USB, Ethernet, HDMI |
Bluetooth Version | 4.2 |
Screen Mirroring | QLED |
Usb Ports | 1 |
USB2.0 Ports | 1 |
Audio Out Ports | 1 |
HDMI Ports | 3 |
Connector Type | HDMI, USB, RF, RS-232C, Optical |
Signal Format | digital, analog |
Hardware Interface | Bluetooth |
Connecting TV | The Samsung Terrace TV offers an impressive performance tailored for gamers and those seeking high-resolution content. With robust HDMI 2.1 support, it seamlessly handles 4K at 120Hz, ensuring a smooth and responsive gaming experience with exceptionally low input lag. The Auto Low Latency Mode enhances usability by automatically switching to Game mode when a game is launched, further optimizing performance. Additionally, the inclusion of features like Game Motion Plus for motion interpolation adds versatility, although it's important to manage settings to minimize any added input lag. The TV is also equipped with eARC support, allowing for high-quality audio transmission, which enhances the overall viewing experience. Overall, the Samsung Terrace stands out for its gaming capabilities and audio features, making it a strong contender for both entertainment and gaming setups. |
User Feedback
Pros:• Stunning picture quality with no visible pixels, even up close
• Great sound quality without the need for a sound bar
• Easy installation and setup
• Sleek remote with user-friendly navigation
• Specifically designed for outdoor use, making it a solid choice for patios or bars
• Reports of screen issues like cracks and faded images after a year of use
• Limited warranty coverage for outdoor installations, which may not protect from environmental damage
• Some users experienced fraud issues related to registering the TV
• High price point with concerns about durability over time
The Samsung Terrace LST7T is an impressive outdoor television with exceptional picture and sound quality, making it a strong contender for those looking to enhance their outdoor entertainment experience. However, potential buyers should be aware of warranty limitations and durability concerns based on user experiences. If you prioritize a stunning display and sound for outdoor settings, this TV could be a worthwhile investment, but be cautious of the long-term reliability based on mixed reviews.
