windstri85
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 System
- 2.2 Display
- 2.3 Audio
- 2.4 Connectivity
- 2.5 Features
- 2.6 Measurements
- 3 Conclusion
Parameter | SAMSUNG The Frame | SAMSUNG Q60D |
Picture | SAMSUNGQ60D.jpg | |
Price | $612.99 | $507.94 |
Model Year | 2023 | 2024 |
Specific Uses | Home Viewing | Home Entertainment |
Highlight | ART MODE: Personal art display when TV is off; built-in motion sensor; supports personal photos and Samsung’s Art Store. CUSTOMIZABLE BEZEL AND MODERN FRAME DESIGN: Slim, sleek design; monochromatic back; magnetic bezel for easy customization to match home décor. QLED HD TV WITH 100% COLOR VOLUME: 100% Color Volume; displays a billion shades; vivid colors at any brightness using Quantum Dot technology. INCLUDED IN THE BOX: QN32LS03CB 32 inch The Frame QLED 4K UHD Quantum HDR Smart TV; Standard Smart Remote; batteries; power cable; user manual; e-manual; Samsung USA Warranty. BUNDLE INCLUDES: Monster Cables TV Full Motion Wall Mount for 32"-70"; 6 Piece Sound Reactive RGB Light Kit. | Mega Contrast: Automatic brightness adjustment Color Technology: 100% Color Volume with Quantum Dot Processing Power: Quantum Processor Lite with 4K Upscaling Motion Technology: Motion Xcelerator for clear motion and improved clarity Product Included: Samsung QN32Q60DAFXZA 32" Q60D QLED 4K Smart TV HDR Support: Quantum HDR (2024) Warranty: 2 Year Amber Protection + 1 Year Manufacturer Warranty Usage: Intended for residential use only |
System
Operating System | Tizen | Tizen |
Internet Applications | netflix, Amazon Instant Video | Netflix, Prime Video, Disney+, Hulu, Apple TV, YouTube, HBO Max, Peacock, Sling, and More |
Remote Control | Bluetooth | infrared |
Controller Type | Remote Control | Remote Control |
Aspect Ratio | 16:9 | 16:9 |
Display Technology | QLED | QLED |
Screen Finish | Matte | Glossy or Smooth |
Has Color Screen | - | Yes |
Resolution | 1080p | 4K |
Response Time | - | - |
HDR Format Supported | - | HDR10 |
Maximum Display Brightness | - | - |
Display Backlight | - | LED |
Display Backlight Setting | - | - |
Picture Quality Enhancement | - | Yes |
Motion Enhancement | Motion Xcelerator | Motion Xcelerator |
Audio
Number of Audio Channels | 2 | 2 |
Audio Output Mode | - | Surround |
Audio Input | - | HDMI, USB, Optical |
Speaker Description | - | 2 speakers |
Connectivity
Connectivity Technology | Wi-Fi | Wi-Fi |
Bluetooth Version | - | 5.2 |
Screen Mirroring | - | [POSSIBLE] Smart View |
Total Usb Ports | 2 | 2 |
Number of HDMI Ports | 2 | 3 |
Connector Type | USB, HDMI | HDMI, USB-A, LAN, IP Control Support, Optical |
Signal Format | - | HDMI, USB |
Video Encoding | - | HEVC |
Compatible Devices | - | [Laptops, Desktops, Gaming Consoles, Television, Tablets, Car Audio Systems, Cellphones, Smart Speaker] |
Tuner Type | ATSC | ATSC |
Noteworthy Features | Art Mode; Anti-Reflection with Matte Display; 100% Color Volume with Quantum Dot, Contrast Enhancer; Motion Xcelerator; Works with Google Assistant and Alexa | Pantone Validated, Supreme UHD Dimming, ALLM, AirSlim Design, Slim Feet, Samsung Tizen OS, Universal Guide, Built-in Voice Assistant, Samsung TV Plus, Samsung Smart Hub, Multi View, SmartThings Compatible, Samsung Health, ConnecTime, Samsung Gaming Hub, 3 HDMI, 2 USB-A, LAN, Wi-Fi, Bluetooth 5.2, IP Control Support, Optical, OTS Lite, Q-Symphony, Adaptive Sound, 20W 2 Channel, Dual Audio Support (Bluetooth), SolarCell Remote, Filmmaker Mode, VESA 100 x 100 |
Measurements
Dimensions D x W x H | 5.6"D x 28.6"W x 17.8"H | 6.1"D x 28.5"W x 18.8"H |
Item Weight | 18.5 Pounds | - |
Screen Size | 31.5 Inches | 32 Inches |
Product | PROS AND CONS |
SAMSUNG The Frame | Pros • Aesthetically pleasing design that resembles a traditional frame • Very thin profile, allowing for a flush mount to walls • Excellent glare resistance, suitable for bright rooms with natural light • Option to display personal photographs when the TV is off • The ability to change the frame color around the pictures Cons • High price compared to similar TVs without the frame feature • Limited compatibility with larger external drives • Photos displayed with an unattractive white border • No straightforward option to stretch images to fit the screen • Slow performance and unresponsive remote after account creation • Time-consuming process to adjust photo settings individually |
SAMSUNG Q60D | Pros: • Amazing picture quality • Very easy setup process • Lightweight and perfect size for smaller rooms • Excellent connectivity with streaming services • Picture viewable at any angle Cons: • Remote control is too small and difficult to operate • May require purchasing a universal remote for ease of use |
