Samsung S90D OLED Review: Is This the Right Choice for Your Home Entertainment?
Ok_Camel
First Impressions​
The Samsung QN65S90DAFXZA looks and feels like a premium TV. It's heavy and sturdy and held in place well by its small metallic stand. The TV is thin and feels modern and classy.
The back of the Samsung S90D/S90DD is the same as theSamsung S90C OLEDbut with a matte finish. The central panel housing the inputs is made of smooth plastic, with included covers andclipsthat you can use to help withcable management. Like most TVs, the inputs are hard to reach if you have it wall-mounted with a fixed mount.
The Samsung S90D has good build quality overall. Theres some wobble on the stand when the TV is pushed forward or backward, but it quickly settles and wont cause any problems. There is a bit of flexing on the plastic central housing on the back, but this is normal and isnt concerning.Whats more concerning is themisaligned HDMI ports on our unitthat makes two of the HDMI ports unusable. Our panel is also slightly bent and bows outwards in the center, although its hard to notice when watching the TV head-on. These issues are likely isolated to our unit, but its a knock against the TV if these issues with build quality are more widespread.
Samsung S90D​
$1497.99​
Model Year​
2024​
Specific Uses​
Entertainment​
User Manual, Power Cable, Remote​
Highlight
Display Size: 65-inch
Resolution: 4K (3840 x 2160)
Display Technology: OLED
Refresh Rate: 120Hz (up to 144Hz)
Processor: NQ4 AI Gen2
Audio Technology: Dolby Atmos, Object Tracking Sound Lite
Operating System: Samsung Tizen OS
Smart Features: Access to streaming services, Samsung Gaming Hub, voice assistant compatibility (Google Assistant, Alexa)
System​
Samsung S90D​
Operating System​
Samsung Tizen​
Internet Applications​
Netflix, HBO Max, Prime Video, Alexa, hulu, Google Assistant, Disney+, Apple TV, YouTube, Web Browser​
Overall, the Samsung S90D/S90DD offers a fast and user-friendly experience with its 2024 version of Tizen OS and a wide selection of apps, making it easy to access favorite content. However, it suffers from a notable input switching issue where the TV remains stuck in PC mode despite changing the input label, which restricts access to certain features. Additionally, while targeted ads can be disabled, the presence of ads in the interface may detract from the user experience for some. Despite these drawbacks, the ability to cast content and play videos from USB enhances its versatility.
Samsung S90D​
Aspect Ratio​
16:9​
Display Technology​
OLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
120Hz (Up to 144Hz) Hz​
HDR Format​
HDR10+​
Backlight Technology​
Self-Luminous​
NQ4 AI Gen2 Processor​
Motion Enhancement​
Motion Xcelerator 144Hz​
Viewing Experience
The Samsung S90D/S90DD OLED delivers outstanding performance with its remarkable contrast and nearly infinite contrast ratio, thanks to its self-lit pixel technology. This allows for bright highlights against perfect inky blacks, making it particularly impressive in dark environments. The absence of local dimming eliminates blooming, enhancing the viewing experience with sharp and clear images.
The TV boasts an exceptionally wide color gamut, accurately covering the DCI-P3 color space and performing well in the increasingly popular Rec. 2020 space, although it shows slight discrepancies in highly saturated colors. The introduction of the Color Booster feature provides a more vibrant color experience while maintaining a good level of accuracy.
With excellent gray uniformity, minor imperfections are not noticeable in typical viewing scenarios. The black uniformity is remarkable, with no blooming or halo effects, and the wide viewing angle makes it ideal for group watching. The reflection handling is superb, effectively minimizing both direct and indirect reflections, though it does exhibit a pink tint under bright light due to the lack of a polarizer.
However, the unique subpixel structure of the QD-OLED panel can lead to color fringing and reduced text clarity when used as a PC monitor, especially noticeable with horizontal lines and bright windows. Additionally, variations in panel types across different sizes and regions may affect performance. Overall, the Samsung S90D/S90DD OLED stands out for its exceptional picture quality and viewing experience, despite some limitations in specific use cases.
Audio​
Samsung S90D​
Audio Channels​
2.1​
Surround Sound​
Dolby Atmos​
Audio Output​
Stereo, Surround Sound, Dolby Atmos​
Audio Input​
HDMI
Speaker Description​
Built-In Speaker​
Audio Experience
Overall Impression: The TV offers a well-balanced sound profile with decent frequency response, delivering clear dialogue and a touch of bass. While it maintains satisfactory distortion performance, it does not achieve high volume levels, which may limit its impact in larger spaces.
Samsung S90D​
Smartphone​
Tuner Type​
ATSC/ClearQAM​
D x W x H​
10.4"D x 56.9"W x 35.3"H​
Mount Standard​
300 x 200 mm​
Line Voltage​
100-240 VAC 50-60 Hz​
Built-In Speaker, Samsung Health, Multiple Voice Assistance, Super Ultra Wide Game View, OLED HDR +, Motion Xcelerator 144Hz, Works with Google Assistant and Alexa, Gaming Hub, NQ4 AI Gen2 Processor​
Motion Smoothing
The Samsung S90D delivers impressive performance with its nearly-instantaneous response time, resulting in clear motion and minimal blur during fast-moving scenes. While it excels in preserving detail during content smoothing, there are some downsides, such as noticeable macro blocking in darker scenes and occasional artifacts when using the motion interpolation feature. Although it is not entirely flicker-free, the display's refresh cycle does not produce noticeable flicker like traditional LED backlights. Overall, the S90D offers a solid viewing experience, particularly for fast-paced content, despite some minor imperfections.
Connectivity​
Samsung S90D​
Bluetooth Version​
5.2​
Screen Mirroring​
Smart View​
Wireless Technology​
Wi-Fi​
Usb Ports​
2​
HDMI Ports​
4​
Connector Type​
USB, HDMI
Sharing Direction​
TV to Mobile, Mobile to TV​
Hardware Interface​
HDMI
Connecting TV
The Samsung S90D/S90DD TV delivers an impressive gaming experience with its incredibly low input lag in Game Mode, ensuring quick responsiveness for gamers. It fully supports the advanced capabilities of the PS5, including 1440p @ 120Hz and 4K @ 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode, making it convenient for users to enjoy optimal performance without manual adjustments. With all four HDMI ports capable of handling the full 48Gbps bandwidth of HDMI 2.1, it accommodates multiple high-bandwidth devices seamlessly.
However, the TV lacks support for Dolby Vision, opting for HDR10+ instead, which may limit compatibility with some content. Additionally, while it features variable analog audio out for connected devices, it does not support DTS formats, potentially disappointing users who rely on this audio technology for Blu-ray playback. The absence of ATSC 3.0 for 4K over-the-air broadcasting is another drawback. Overall, the Samsung S90D offers strong gaming features and connectivity options, but there are notable limitations in audio format support and certain advanced HDR capabilities.
User Feedback​
Pros
• Incredible picture quality, especially compared to other OLEDs
• Excellent color gamut
• Brightness levels can be impressive once settings are adjusted
• Good value compared to higher-priced competitors like LG
• Quantum dot OLED technology offers advantages over traditional OLED
Cons
• Out of the box settings require significant tweaking
• Auto eco mode can diminish brightness and needs to be disabled
• Best performance may be hindered if connected to the internet due to potential firmware limitations
• Not ideal for well-lit rooms compared to alternatives like TCL mini LED
Overall Impression
This TV offers outstanding picture quality and value, particularly for those who are willing to invest time in adjusting settings. While it may have some drawbacks, such as needing manual adjustments and potential issues with internet connectivity, it stands out as a superior choice over traditional OLEDs. Just be mindful of your viewing environment and settings to fully appreciate its capabilities.
