Samsung S85D OLED Review: Is This 4K TV the Right Choice for You?
Amanda Brown
Active member
First Impressions​
The Samsung S85D has a very basic design that looks good overall. It's a thin TV, but its bezels are a bit thicker than most other OLEDs.
The back of the TV is made entirely of plastic. It feels a bit loose against the panel, and the entire back of the TV flexes when pressed on. The inputs are located in two recessed cutouts on the bottom right of the TV when facing the front, which makes them hard to access if you have the TV mounted flush to the wall. The comes withtwo clipsthat can be attached to the TV's feet forcable management.
The Samsung S85D has good build quality overall. The TV is light, and the two plastic feet dont help much with weighing it down, so theres some wobble when the TV is pushed on. It's mostly made of cheap-feeling plastic, but outside of one dead pixel on the top left of our unit, there are no big concerns with the overall build quality.
Samsung S85D​
SamsungS85D.jpg​
$947.99​
Model Year​
2024​
Specific Uses​
Entertainment​
User Manual, Power Cable​
• Display Size: 55 inches
• Resolution: 4K Ultra HD (3840 x 2160)
• Refresh Rate: 120Hz
• Audio Technology: Dolby Atmos, Object Tracking Sound Lite
• Smart TV Platform: Tizen
• Connectivity: Multiple HDMI and USB ports
System​
Samsung S85D​
Operating System​
Samsung Tizen​
Internet Applications​
Netflix​
Bluetooth​
The Samsung S85D offers a user-friendly experience with its 2024 version of the Tizen OS, providing fast navigation and a wide selection of apps for easy content access. However, it suffers from a notable bug affecting brightness adjustment, requiring a reboot to resolve. The presence of ads in the interface may be a drawback for some users, although targeted ads can be disabled. Overall, while the S85D has solid features and functionality, the brightness issue and advertising limitations could detract from the overall viewing experience.
Samsung S85D​
Aspect Ratio​
16:9​
Display Technology​
OLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
120 Hz​
HDR Format​
HDR10+​
Backlight Technology​
LED​
Backlight Setting​
Local Dimming​
NQ4 AI Gen2 Processor​
Motion Enhancement​
Motion Xcelerator 120Hz​
The Samsung S85D delivers an impressive viewing experience with remarkable contrast and nearly infinite contrast ratio, thanks to its OLED technology and self-lit pixels. The TV excels in dark environments, displaying bright highlights alongside deep blacks without any blooming, making it visually captivating. While it covers a wide color gamut, colors are generally undersaturated and inaccurate, particularly in the magentas, greens, and cyans, which could detract from the overall experience for some viewers.
Gray uniformity is strong, with only faint vertical lines that are hardly noticeable from a typical distance. The viewing angle is outstanding, maintaining consistency with only minor color shifting, making it suitable for group viewing. Reflection handling is exceptional, effectively minimizing both direct and indirect glare, enhancing usability in varied lighting conditions.
However, the WOLED panel's RWBG pixel structure may lead to minor issues with displaying text due to suboptimal ClearType optimization, though this is unlikely to be a significant concern for most users. Overall, the Samsung S85D stands out for its impressive display characteristics and is particularly well-suited for immersive viewing experiences.
Audio​
Samsung S85D​
Audio Channels​
5.1.2 or 7.1.2​
Surround Sound​
Dolby Atmos​
Audio Output​
Dolby Atmos​
Audio Input​
HDMI​
Speaker Description​
2CH​
Audio Experience​
Overall Impression: The TV offers a decent frequency response with a well-balanced sound profile at moderate listening levels, ensuring clear dialogue. However, it struggles with unbalanced sound and limited volume capacity, leading to audible distortion at both lower and higher volumes. Additionally, the lack of meaningful bass suggests that external audio solutions, like a soundbar or surround sound system, are necessary for an enhanced audio experience.
Samsung S85D​
Smartphone​
Water Resistance​
Not Water Resistant​
Tuner Type​
ATSC/ClearQAM​
D x W x H​
9.3"D x 48.2"W x 30.1"H​
Mount Standard​
300 x 200 mm​
Power Consumption​
114 Watts​
Line Voltage​
110 VAC 60 Hz​
Built-In Speaker​
Motion Smoothing​
The Samsung S85D TV delivers strong performance with its nearly instantaneous response time, providing clear motion and minimal blur for fast-moving objects. While it excels in detail preservation with low-quality content smoothing, macro blocking can be an issue in darker scenes. The TV's lack of traditional backlighting and its non-PWM dimming method result in slight flickering that may affect sensitive viewers, although it's generally not noticeable to most. The optional motion interpolation feature enhances clarity in slower scenes but struggles with faster action, introducing artifacts and haloing. Overall, the S85D offers impressive motion handling but has some limitations in certain content scenarios.
Connectivity​
Samsung S85D​
Bluetooth, Wi-Fi, HDMI​
Bluetooth Version​
5.2​
Screen Mirroring​
Miracast​
Wireless Technology​
Wi-Fi​
Usb Ports​
2​
HDMI Ports​
4​
Connector Type​
HDMI​
Sharing Direction​
Mobile to TV​
Connecting TV​
The Samsung S85D TV delivers an exceptional gaming experience, particularly with its low input lag in Game Mode, making it highly responsive for gamers. It fully supports advanced gaming features such as 1440p @ 120Hz and 4K @ 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode, ensuring minimal hassle for users switching settings. The TV's HDMI 2.1 ports provide robust bandwidth, accommodating multiple high-bandwidth devices seamlessly. However, it lacks support for Dolby Vision and ATSC 3.0, which may limit its appeal for some users. While it supports a range of audio formats, the absence of DTS support is a notable drawback. Overall, the Samsung S85D is a strong choice for gaming but has some limitations in video and audio format compatibility.
User Feedback​
Pros
• Easy unboxing and setup
• QR code feature for quick account login
• AI auto-configuration for picture and sound settings
• Vivid colors and great picture quality
• Sturdy wide stance stand included
Cons
• Initial unit received had no picture
• Some consumers experienced defects (e.g., cracked screen)
• Customer service issues reported by some users
Overall Impression
The television offers impressive features, including ease of setup and vivid picture quality, making it a solid choice for those looking to upgrade their viewing experience. However, there are concerns regarding product reliability and customer service, which potential buyers should consider before making a purchase.
sasamomo
Curious if anyone with this panel gets the faint horizontal banding on dark gray slides, because mine showed it out of the box. Firmware's moved on since, and the S90F is dropping soon, so I've been holding off on a return.
