Harry Williams
- 1 First Impressions
- 2 Introduce
- 3 System
- 4 Display
- 5 Audio
- 6 Features
- 7 Connectivity
- 8 User Feedback
First Impressions
The Samsung QN95D has a very premium design, although it looks very similar to theSamsung QN95C QLED. Nevertheless, it has a modern and sleek look, and the bezels are incredibly thin.The back of the TV looks great, with a nice textured design to the back panel. There are grooves along the back and through the stand to help withcable managementand a cover that hides the cables on the stand for a really clean setup. There's also aconnector near the top of the TVthat allows you to connect a Samsung camera add-on, sold separately.
The Samsung QN95D has excellent build quality. It's built with premium materials, including a solid metal stand and premium plastic on the back.
Parameter | Samsung QN95D |
Reference Price | $1897.99 |
Model Year | 2024 |
Specific Uses | Home Entertainment |
Built-In Media | User Manual, Power Cable, Remote |
Highlight | • Display Size: 55-inch • Display Type: OLED • Resolution: 4K • Refresh Rate: 144Hz • Audio Technology: Dolby Atmos, Object Tracking Sound+ • Operating System: Samsung Tizen OS • Smart Features: Streaming app access, voice control • Processor: AI-based processor for content upscaling and picture enhancement |
System
Operating System | Samsung Tizen |
Internet Applications | Netflix, HBO Max, Prime Video, Alexa, hulu, Google Assistant, Disney+, Apple TV, YouTube, Web Browser |
Remote Control | Bluetooth |
System Experience | The Samsung QN95D offers a user-friendly experience with its 2024 version of Tizen OS, featuring a smooth Smart Hub interface that provides access to a wide range of apps and content. While the presence of ads in the interface may be a drawback for some users, the ability to disable targeted ads partially mitigates this issue. Additionally, the TV allows for convenient content casting from mobile devices and supports USB video playback, enhancing its versatility for content consumption. Overall, the QN95D stands out for its performance and ease of use, making it a solid choice for users seeking a feature-rich smart TV experience. |
Aspect Ratio | 16:9 |
Display Technology | OLED |
Screen Finish | Flat |
Has Color Screen | Yes |
Resolution | 4K |
Refresh Rate | 144 Hz |
HDR Format | HDR Pro |
Backlight Technology | Self-Luminous |
Backlight Setting | Local Dimming |
Picture Enhancement | [complex] |
Motion Enhancement | Motion Xcelerator 144Hz |
Viewing Experience | The Samsung QN95D has fantastic contrast, and the TV does a fantastic job displaying deep blacks even in complicated scenes with bright highlights.Unfortunately, like theSamsung QN95C QLED, Samsung has removed the ability to fully disable the local dimming feature through the service menu. To calculate the native contrast ratio, we usedthis inverse contrast pattern. We took the average black levels of the four corners with the white area set to 200 cd/m². The TV has great blooming performance, but there's some noticeable blooming around bright objects and subtitles when displayed against a black background. The TV has decent lighting zone transitions. Unfortunately, the leading edge of bright highlights when they quickly move across the screen is visibly dimmer, and there's noticeable haloing. This TV has a great color gamut. It has truly fantastic coverage of the DCI-P3 color space, with impressive tone mapping; there are very few noticeable inaccuracies. It has decent coverage of the wider Rec. 2020 color space, though, as the tone mapping is noticeably off with saturated green and cyan. The Samsung QN95D has good gray uniformity. The screen is relatively uniform in scenes with bright uniform colors as well as in darker scenes, but there's minor, yet noticeable, dirty screen effect throughout. The TVs black uniformity is outstanding. Note that you cant turn local dimming completely off on this TV due to a more limited service menu, so the Native Black Uniformity picture is with local dimming set to Low. With that setting, the TVs black uniformity is still outstanding, with only a bit more blooming around bright highlights than with the local dimming set to High.' The Samsung QN95D has an okay viewing angle. The image is consistent when viewed from a slight angle, but there's color shifting, color washout, and brightness loss the more you move off-center. The TV has incredible reflection handling. Its semi-gloss screen finish significantly reduces the intensity of direct reflections, such as bright lights placed directly opposite the screen, and does a great job of reducing the intensity of indirect reflections, like from ambient lighting. This TV uses a BGR (Blue-Green-Red) subpixel layout instead of the traditional RGB layout. For video or gaming content, this doesnt cause any issues, but for PC monitor use, it can be a problem as it impacts thetext clarity, although not everyone notices this.The TV uses quantum dots to achieve high color peaks with excellent separation between blues, greens, and reds. This gives the TV great color purity and allows it to display a very wide color gamut, which can be seen in the TVs spectral power distribution (SPD)chart. |
Audio
Audio Channels | 5.1 |
Surround Sound | True |
Audio Output | Surround |
Audio Input | HDMI |
Speaker Description | Built-in speaker |
Speaker Output Power | 70 Watts |
Audio Experience | Overall, the product has a well-balanced sound profile with clear dialogue, making it suitable for general viewing. However, it lacks significant bass and volume, which may limit its effectiveness in louder environments. Distortion is minimal at higher volumes, contributing to a satisfactory listening experience. |
Video Encoding | AVC |
Tuner Type | ATSC/Clear QAM |
D x W x H | 10.5"D x 48.2"W x 30.4"H |
Mount Standard | 400 x 300 mm |
Voltage | 1.2E+2 Volts |
Power Consumption | 21.36 Watts |
Other Features | Built-In Speaker, Samsung Health, Multiple Voice Assistance, Wide Viewing Angle, Motion Xcelerator 144Hz, Works with Google Assistant and Alexa, OLED HDR Pro, Gaming Hub, NQ4 AI Gen2 Processor |
Motion Smoothing | The Samsung QN95D TV offers a mix of performance attributes that reflect its strengths and limitations. Its low-quality content smoothing feature preserves detail well but struggles with artifact smoothing, leading to visible macro blocking in low-bitrate content. The response time is commendable, minimizing blur for fast-moving objects; however, it experiences slower transitions from dark states, resulting in noticeable black smearing and inverse ghosting. The backlight system employs pulse width modulation (PWM) for dimming, resulting in a flicker that varies significantly depending on the picture mode and settings, which may be an issue for sensitive viewers. The optional motion interpolation feature provides some enhancement to motion clarity but falls short in faster scenes, introducing distracting artifacts and haloing. Overall, the Samsung QN95D presents a solid option for viewers who prioritize response time and detail preservation, although it may not fully satisfy those sensitive to flicker or looking for flawless motion handling. |
Connectivity
Bluetooth Version | 5.0 |
Screen Mirroring | AirPlay, Miracast |
Usb Ports | 4 |
USB2.0 Ports | 4 |
USB3.0 Ports | 4 |
HDMI Ports | 4 |
Connector Type | USB, HDMI |
Signal Format | digital |
Hardware Interface | HDMI |
Connecting TV | The Samsung QN95D TV offers an impressive gaming experience, highlighted by its incredibly low input lag in Game Mode, providing a responsive interaction that gamers will appreciate. Its full compatibility with PS5 features, including resolutions up to 4K at 120Hz and HDMI Forum VRR, ensures that it can handle the latest gaming demands effectively. The support for 48Gbps bandwidth across all four HDMI 2.1 ports allows for seamless connections with multiple high-bandwidth devices. Additionally, the eARC support enhances audio quality by enabling the transfer of uncompressed audio to external sound systems. However, the absence of Dolby Vision support and limited DTS format compatibility may be drawbacks for some users. Overall, the QN95D stands out for its gaming capabilities and robust connectivity options, making it a solid choice for gamers. |
User Feedback
Pros:• Fantastic setup process that guides users step by step
• Glare-free screen ideal for daytime viewing
• Amazing picture quality that is extremely clear and colorful
• Competitive pricing compared to other brands
• CEC control can be unreliable, affecting compatibility with external devices
• Detached electronics hub box can be cumbersome for wall mounting
• Some quirks that may detract from overall experience
The Samsung TV offers an impressive upgrade with its superior picture quality and user-friendly setup process, making it a strong choice for consumers. While it has a few quirks like unreliable CEC control and the challenging electronics hub placement, its standout features, particularly the glare-free screen, make it a worthwhile investment for those seeking an enhanced viewing experience.
