Samsung QN85D Neo QLED Review: Is It the Right Fit for Your Home Entertainment?
ApaHualpa
First Impressions​
The Samsung QN85D has a nice design, although it looks like a much thicker version of last yearsSamsung QN85C/QN85CD QLED. From the front, it has thin bezels and a sleek look thatll fit in any room.
The back of the TV looks good, with a nice textured design. There are slots on each side of the TV for alternate feet, but no alternate feet are included in the box. There are cable channels on the back to help withcable management. There are alsocable grooves in the stand, hidden with a cover, to further channel cables towards the stands bottom and out of the TV. Note that the TVs inputs are in a recessed inlet on its back panel. They're hard to access if you wall-mount the TV with a fixed bracket.
The build quality of the Samsung QN85D is great. The TV wobbles from front to back and from side to side due to its small stand, but its not concerning. However, theres a large amount of flex near the TVs VESA holes and its inputs; its pretty typical, but it's something to note. Aside from that, the TV feels sleek and is made from premium plastic.
Samsung QN85D​
$1697.99​
Model Year​
2024​
Specific Uses​
home entertainment, gaming​
User Manual, Power Cable, Remote​
Highlight
Display Type: Quantum Matrix with Mini LEDs
Resolution: 4K
HDR Support: Yes
Audio Technology: Dolby Atmos with Object Tracking Sound Lite
Refresh Rate: 120Hz
Motion Enhancement: Motion Xcelerator Turbo, Real Depth Enhancer
Processor: NQ4 AI Gen2
Upscaling Technology: 4K AI Upscaling
Picture Optimization: Auto HDR Remastering, HDR Brightness Optimizer
System​
Samsung QN85D​
Operating System​
Samsung Tizen​
Internet Applications​
Netflix, HBO Max, Prime Video, Alexa, hulu, Google Assistant, Disney+, Apple TV, YouTube, Web Browser​
Bluetooth​
Voice Control​
The Samsung QN85D offers a user-friendly experience with its 2024 version of Tizen OS, featuring a wide array of apps that simplify content access. However, the interface can be sluggish at times, and input label changes may not always register, leading to some frustration. While targeted ads can be disabled to an extent, the presence of ads within the interface remains a drawback. Overall, the TV provides solid functionality and connectivity options, despite some usability hiccups.
Samsung QN85D​
Display Technology​
QLED​
Screen Finish​
Flat​
Resolution​
4K​
Refresh Rate​
120 Hz​
HDR Format​
HDR10​
Backlight Technology​
Mini-LED​
Backlight Setting​
[Auto, Min, Medium, Medium-High, Max]​
Combination of Advanced Technologies​
Motion Enhancement​
Motion Xcelerator 120Hz​
Viewing Experience
The Samsung QN85D delivers an impressive viewing experience with its exceptional contrast ratio and ability to produce deep blacks, particularly when local dimming is enabled. The TV excels in color reproduction, showcasing a wide gamut that enhances HDR content, although some colors appear slightly undersaturated, with notable inaccuracies in greens and cyans. While its gray uniformity is commendable, issues like vignetting and vertical banding can detract from the experience during specific content. The black uniformity is a strong point, maintaining pitch-black imagery outside of bright highlights. However, the viewing angle is significantly limited compared to previous models, resulting in noticeable color washout and brightness loss when viewed from the side. Reflection handling is adequate, but for those needing superior performance in bright environments, other options may be better suited. The switch to a VA panel improves contrast but compromises viewing angles. Overall, the Samsung QN85D is a capable TV for those prioritizing contrast and color performance, but potential buyers should consider its limitations in viewing angle and text clarity for PC use.
Audio​
Samsung QN85D​
Audio Channels​
Dolby Atmos​
Surround Sound​
Dolby Atmos​
Audio Output​
Surround​
Audio Input​
HDMI
Speaker Description​
Built-in speakers, specifications not detailed​
Audio Experience
Overall Impression: The TV delivers satisfactory sound quality at moderate volume levels, characterized by clear and sharp audio with a decent bass response. However, it struggles with sound reproduction at maximum volume, leading to noticeable compression and a decline in dialogue clarity. Additionally, distortion becomes more apparent at higher volumes, indicating limitations in its audio performance when pushed to the limits.
Samsung QN85D​
H.265 (HEVC)​
Laptops, Desktops, Gaming Consoles, Tablets, Smart Speaker, Smart Watch, Car Audio Systems, Cellphones​
Tuner Type​
ATSC​
D x W x H​
10.8"D x 65.8"W x 40"H​
Mount Standard​
400 x 400 mm​
Built-In Speaker, Film Mode, Wide Viewing Angle, Works with Google Assistant and Alexa, Motion Xcelerator 120Hz, Quantum Matrix Technology, Gaming Hub​
Motion Smoothing
The Samsung QN85D TV offers a mixed performance overall. While it excels in response time and can deliver smooth transitions in most scenarios, it struggles significantly with dark scene transitions, exhibiting noticeable overshoot and inverse ghosting. The content smoothing feature does a commendable job of preserving details, but its effectiveness in mitigating macro-blocking in dark scenes is only average. Additionally, the use of pulse width modulation for backlight dimming introduces flicker at various frequencies, which may affect viewing comfort, especially in lower brightness settings. The frame rate enhancement feature can improve the experience for slow scenes but is prone to artifacts during fast-action sequences. Overall, while the QN85D has strengths in certain areas, its shortcomings in dark scene handling and flicker may detract from the viewing experience for some users.
Connectivity​
Samsung QN85D​
Screen Mirroring​
[POSSIBLE]​
Wireless Technology​
Bluetooth, Wi-Fi​
Usb Ports​
2​
HDMI Ports​
4​
Connector Type​
USB, HDMI
Signal Format​
digital​
Hardware Interface​
Ethernet​
Connecting TV
The Samsung QN85D TV delivers an impressive gaming experience with extremely low input lag in Game Mode, ensuring immediate responsiveness to player inputs. It fully supports next-gen gaming features, such as 1440p @ 120Hz and 4k @ 120Hz, along with HDMI Forum VRR and Auto Low Latency Mode for optimal performance. The inclusion of full HDMI 2.1 bandwidth across all four HDMI ports enhances versatility for users with multiple devices. However, the lack of Dolby Vision support and DTS audio format compatibility may be drawbacks for some users seeking a more comprehensive HDR and audio experience. Overall, the QN85D is a strong choice for gamers, but it has limitations in video and audio format support.
User Feedback​
• Excellent picture quality with 4K content
• Good viewing angles and performance in various light levels
• Strong performance on most channels
• Generally well-rated for clarity
• Blurry motion during fast-paced sports, particularly football
• Graininess with older TV shows
• Difficulty in adjusting picture settings to resolve motion issues
• May not perform as well as older Samsung models in specific scenarios
The TV offers impressive picture quality and is suitable for most viewing experiences, especially with 4K content. However, it falls short for sports enthusiasts due to blurriness during fast motion. While it excels in general performance, those specifically seeking a clear sports viewing experience may want to consider alternatives.
