Samsung QN85B and Samsung Q80B are both new 4K TV released in 2022 with a good reputation. What's the difference between Samsung QN85B and Samsung Q80B TV? Let's see the specs comparison.
The Samsung QN85B is the lowest-end model in Samsung's 2022 TV lineup with Neo QLED technology, while the Samsung Q80B is the mid-range model and has an additional 50-inch TV in the available size. Before choosing a TV, use the TV size calculator to select the best TV for your space.
It is easy to guess that QN85B has better performance than Q80B.
You can see from the specs comparison table above that the Samsung QN85B is an ADS TV with the best contrast ratio, and the use of the Neo QLED panel does allow the QN85B to deliver a brighter peak brightness than the Q80B.
But overall, the overall color reproduction of the Samsung QN85B and Q80B is good. They have a wide color gamut, so they can produce vivid and realistic HDR images. Both have good motion processing, so fast motion images look very smooth. Both have low input latency and are equipped with an excellent Tizen system.
Specs and Features | Samsung QN85B | Samsung Q80B |
Resolution | 4K (2160 x 3840) | 4K (2160 x 3840) |
Size Available | 55''65'' 75'' 85'' | 50''55''65'' 75'' 85'' |
Panel Type | ADS Panel (85” variants: VA Panel) | ADS Panel (85” and 50” variants: VA Panel) |
Local Dimming | Full Array Local Dimming | Full Array Local Dimming |
Backlight | Direct LED with Mini-LED backlight | Direct LED |
Picture Engine | Neo Quantum Processor 4K | Quantum Processor 4K |
HDR Performance Index | Quantum HDR 24x | Quantum HDR 14x |
HDR Format Supports | HDR10, HLG, HDR10+ | HDR10, HLG, HDR10+ |
Color Technology | Quantum Dot Technology | Quantum Dot Technology |
4K Up-scaling | AI 4K Up-scaling | AI 4K Up-scaling |
Native Refresh rate Panel | 120 Hz | 120 Hz (50” variant: 60 Hz) |
Variable Refresh Rate | Yes (FreeSync, GSync, HDMI Forum) | Yes (FreeSync, GSync, HDMI Forum VRR) |
Smart TV Platform | Tizen OS 2022 | Tizen OS 2022 |
Remote | TM2280E | TM2280E |
HDMI | 4 | 4 |
HDMI Supports | HDMI 2.0, HDMI 2.1, HDCP 2.2, CEC, ALLM | HDMI 2.0, HDMI 2.1, HDCP 2.2, CEC, ALLM |
USB | 2 | 2 |
RF (Terrestrial Cable) | 1 | 1 |
Digital Audio Out (Optical) | 1 | 1 |
Wi-Fi Built In | Yes | Yes |
Audio Setup | 2.2.2 | 2.2.2 |
Total Audio Output | 60 Watts | 60 Watts |
