Samsung DU7200 Review: Is This 4K 60Hz TV the Right Fit for Your Home?
Amanda Brown
Active member
First Impressions​
The Samsung 65DU7200D looks pretty good for a cheaper model. Its bezels are thin enough that they dont stand out when watching the TV, but they arent as thin as what you get from more premium models.
The back of the TV is made from plastic. All of the inputs are on the right side of the TV when facing the front, but they're in a recessed cutout that makes them quite hard to access if you have it wall-mounted. The back has grooves and a clip that can be attached to one of the feet to help withcable management.
The TV has alright build quality overall. It wobbles a bit when youre cleaning the screen, but it settles quickly and doesnt cause any issues. Theres quite a bit of flex on the back panel that becomes more pronounced near the VESA mounting points, but it doesnt prevent you from wall-mounting it.Unfortunately, our unit has astuck pixelon the left side of the screen towards the middle.
Samsung DU7200​
Model Year​
2024​
Specific Uses​
Home​
User Manual, Power Cable​
Highlight
Resolution: 3840 x 2160 (4K Ultra HD)
Display Type: LED
Smart TV Platform: Samsung Tizen
Audio Features: Object Tracking Sound Lite, Q-Symphony
Upscaling: 4K upscaling
Connectivity Options: Multiple HDMI ports, USB ports, Bluetooth, Wi-Fi
System​
Samsung DU7200​
Operating System​
Samsung Tizen​
Internet Applications​
Netflix​
Bluetooth​
Overall Impression: The TV offers a solid performance with the 2024 version of Samsung's Tizen OS, providing access to a wide range of streaming services and additional apps. While it lacks some advanced features found in higher-end models, it still delivers a functional user experience. The presence of ads on the home screen may be a drawback for some users, but the ability to disable targeted ads offers a slight reprieve. Additionally, the capability to cast content from mobile devices and play videos from USB sticks enhances its versatility for content consumption.
Samsung DU7200​
Aspect Ratio​
16:9​
Display Technology​
LED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K​
Refresh Rate​
60 Hz​
HDR Format​
HDR10​
Backlight Technology​
LED​
PurCOLOR​
Motion Enhancement​
Motion Xcelerator​
Viewing Experience
The Samsung DU7200 presents a mixed overall impression. While it boasts a commendable native contrast ratio that allows for somewhat deep blacks in dark scenes, the lack of local dimming leads to a washed-out appearance in mixed content, diminishing the viewing experience. Its color performance is hindered by a narrow color gamut, with both the DCI-P3 and Rec.2020 spaces showing undersaturation and inaccuracies.
The TV does offer decent gray uniformity, although some darkening at the edges can be noticed, and it excels in black uniformity despite minor cloudiness. However, its inadequate viewing angles significantly limit its usability in wider seating arrangements, as gamma and color shifts become prominent from side views. Reflection handling is satisfactory for indirect light but less effective against direct reflections, which can be distracting.
Additionally, the BGR subpixel layout may pose challenges for PC use, affecting text clarity. Overall, the Samsung DU7200 is best suited for specific viewing conditions but falls short in versatile performance across various scenarios.
Audio​
Samsung DU7200​
Audio Channels​
5.1​
Surround Sound​
Object Tracking Sound Lite, Q-Symphony​
Audio Output​
[POSSIBLE_VALUES] Object Tracking Sound Lite, Q-Symphony​
Audio Input​
HDMI​
Speaker Description​
Built-In Speaker​
Audio Experience
Overall Impression: The TV offers a balanced sound profile at moderate volume levels, making it suitable for general viewing, particularly for dialogue clarity. However, it struggles with deep bass and lacks sufficient loudness, leading to noticeable distortion at higher volumes. Listening at lower levels is advisable for optimal sound quality.
Samsung DU7200​
Multiple​
Water Resistance​
Not Water Resistant​
Tuner Type​
ATSC​
D x W x H​
9.3"D x 48.6"W x 29.8"H​
Line Voltage​
110 VAC 60 Hz​
Built-In Speaker​
Motion Smoothing
The Samsung DU7200 offers impressive detail preservation but falls short in effectively smoothing low-quality content, leading to visible macro-blocking. Its response time is commendable, resulting in minimal blur during fast motion; however, it struggles with black smearing and notable inverse ghosting in darker scenes. The reliance on pulse-width modulation for backlight dimming introduces varying levels of flicker, which may be problematic for sensitive users. While it provides motion interpolation for low-frame-rate content, its performance is inconsistent, particularly in fast scenes, resulting in noticeable artifacts and occasional halting of the interpolation process. Overall, the TV presents a mixed performance, excelling in detail but facing challenges in motion handling and low-quality content playback.
Connectivity​
Samsung DU7200​
Bluetooth, Wi-Fi, HDMI​
Bluetooth Version​
5.0​
Screen Mirroring​
[POSSIBLE_VALUES]​
Wireless Technology​
Wi-Fi​
Usb Ports​
1​
USB2.0 Ports​
1​
Audio Out Ports​
3​
HDMI Ports​
3​
Connector Type​
HDMI​
Connecting TV
The Samsung DU7200 TV offers a solid performance for gaming, particularly with its incredibly low input lag in Game Mode, making it responsive for fast-paced gaming experiences. However, it is limited by its inability to support 1440p @ 60Hz in this mode, which may disappoint some users looking for higher resolution gaming without added lag. The TV's support for HDR10 and HLG enhances the visual experience, though it lacks Dolby Vision support, which could limit HDR performance for certain content. Additionally, eARC support provides an advantage for high-quality audio output, but the absence of DTS format support may hinder audio flexibility for some users. Overall, while the TV excels in specific gaming scenarios, its limitations in resolution and audio formats may be a drawback for a more comprehensive multimedia experience.
User Feedback​
Pros
• Excellent 4K picture quality with vibrant colors and fantastic clarity
• Smooth framerate and effective upscaling for HD devices
• Lightweight design (only 16.3 lbs)
• Adjustable legs for versatile placement on various stands
• Easy setup process
• Tizen OS offers a good user experience if properly navigated
• Great value for the price at $427
Cons
• Limited A/V receiver options, pushing consumers towards Samsung’s own sound devices
• Requires a 4K HDMI cable for optimal performance
• Some users may find the picture settings complex to configure for the best results
Overall Impression
This Samsung 4K TV stands out as an exceptional value for its price, delivering impressive picture quality and user-friendly features. While it has some limitations regarding audio options and setup complexity, the overall performance, lightweight design, and adjustable legs make it a worthwhile investment for any home entertainment setup.
