loughborough
Zombies will be your main enemies in Resident Evil 2: slow but resistant, they will trap you more than once until you know their behavior perfectly to anticipate them. You have to know your enemy to defeat him, so learn in detail the behavior of the basic zombies that you will come across in the terrifying adventure of Capcom:
DANGEROUS BUT LIMITED ZOMBIES
The Crowbcat YouTuber has conducted numerous tests on Zombies in the 1-Shot demo of Resident Evil 2 , which deliver a good number of lessons on the most common enemies of Capcom's survival horror . Discover under the video (in English) the summary of the lessons most useful to your survival.
Resident Evil 2 zombies
- Can zombies enter the police station entrance hall? No, and it is surely one of the only places where you will be a little safe, because the Zombies will not be able to open the door to join you in the Hall.
- At times the ground where you move will collapse under your feet. Can the zombies follow you in your fall? No, the zombies are not suicidal and will not fall into the holes, just like your hero, because these are bordered by invisible walls.
- In the different rooms that you will visit, you will find modules in pallets which are scalable. But will they protect you from zombies if you play cat perched on these paddles? The answer is yes ... And no, because if you are too close to the edge the Zombies can catch your legs. Little advice, move away from the edge and you will be quiet.
- After an intensive gunfight, you create a heap of bodies on the ground, will this affect other Zombies? The answer is no, it will only trip them up but they will continue on their way to you, it will not block them.
- On certain passages, you will have to climb ladders, are we safe on these? Ladders are always safe! Indeed, as soon as the action of going up or down is triggered, the hero no longer risks anything.
- Can Zombies move if their legs are cut? Yes ! Zombies will slowly crawl on the ground moving with their only trunk, and can therefore reach you.
- To continue the questions about the crippled zombies, could they open an armless door? The answer is simple: no arms, no door! It will be impossible to open a door for a Zombie if these are missing their arms or legs.
- Can you block a Zombie behind a door? With a little technique, yes. By opening a door with his character as if to cross it, then going back, the zombie will be unable to open it.
- In Resident Evil 2, several passages will ask you to place C4, but will these explosions affect all these Zombies? Apart from a breath of fresh air on their rotten skins, this will have no impact. However, the shock wave will cause you to drop slightly.
- During the conversation phases, is Leon safe? Unlike QTEs, conversations won't protect you from Zombies' assaults.
- Can Zombies walk with one foot less? Even with one foot less, they remain Zombies and they will continue to pursue you.
- Can we crush the Zombies with the different movable cupboards in the game? Unfortunately no ! Zombie flattening by cabinets will not be possible in Resident Evil 2!
- Does your hit box get smaller when you kneel? Unfortunately no, the size of your hit box will not decrease and some invisible walls may block you.
- During the puzzle interaction sessions, are we protected from Zombie attacks? When you have to type a code or other puzzles, you enter another space-time where the actions of the Zombies around you are frozen.
