Elena
Before, Realme launched 4K SLED TV in India, claiming to be the world's first. According to Realme, the NTSC color gamut of A TV SLED is better than that of a regular LCD TV or a QLED TV, resulting in better color performance. It also has better eye care and has been certified as a German Rhine low Blue light.
Many of you may be confused, what is SLED?
SLED TV =RGB backlight
A TV with a backlight, like Samsung's QLED, doesn't glow as brightly as an OLED TV, so it can still count as an LCD. The only difference between A SLED, QLED, and a normal LCD TV is the backlight.
Ordinary LCD TV uses WLED backlight technology, blue LED LED light emitting diode excites yellow phosphor to produce white light, then through the RGB filter to generate red, green, blue three colors. Samsung's QLED replaces the LCD TV's white backlight with a blue backlight and uses a quantum dot film that absorbs blue light and emits red or green.
Realme SLED changes the backlight directly into three colors, red, green, and blue, known as RGB backlight. So TV SLED is, at the end of the day, an LCD TV with AN RGB-LED backlight.
