Harry Williams
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | RCA RPJ136 | Bewinner Portable Mini |
Price | $29.99 | $32.22 |
Recommended Uses | Home Cinema, Gaming | - |
Highlight | Projection Technology: 3.97" Projection LCD Image Quality: Razor-sharp images, true-to-life colors Picture Size Range: 30" to 130" (Optimal: 37" to 100") Fan Noise Reduction: 5db quieter cooling fan Supported Resolutions: 1080p, 1080i, 720p, 576i, 480p, 480i Native Resolution: 800 x 480 Projection Surface Compatibility: Any flat surface (screen, wall, ceiling, etc.) Lamp Life: 50,000 hours (22.8 years at 6 hours/day or 5.7 years at 24 hours/day) | Screen Size: 24-60 inches Resolution: 1920x1080 Display Technology: Digital light processing Heat Dissipation: Super heat dissipation for stable operation Audio: Built-in speakers with clear sound Portability: Compact design for easy carrying Imaging Technology: Diffuse reflection imaging to reduce visual fatigue Connectivity: Rich interface for various devices (notebooks, game consoles, TF cards, set-top boxes, cameras, U disks) |
Screen Size | 30 Inches - 150 Inches | - |
Throw Distance | - | N/A - 6.5 Feet |
Contrast Ratio | - | 800:1 |
Display Resolution | via HDMI connection: 1920 x 1080 | 1920 x 1080 |
Native Resolution | 800 x 480 | 1920 x 1080 |
Brightness | 33 Lumen | - |
Display Type | - | LCD |
Picture Enhancement | - | DLP |
Light Source Life | 50000 Hours | 30000 Hours |
Controller Type | Button Control | Remote Control |
Mount Type | Wall Mount | Tabletop Mount |
Other Features | Portable | Portable |
Connectivity
Connectivity Technology | HDMI | [MO] |
Hardware Connectivity | VGA, HDMI, USB 2.0 | - |
Compatible Devices | Blue ray, DVD , Streaming | Laptop, Gaming Console, Speaker, Smartphone, Tablet |
Measurements
L x W x H | 12.5"L x 7.5"W x 4"H | - |
Item Weight | - | 1.2 Pounds |
Product | PROS AND CONS |
RCA RPJ136 | Pros: • Excellent low-cost option for casual use • Compact and lightweight, easy to transport • Brighter than expected in dark environments • Vivid colors and fluid motion • Multiple input options (HDMI, USB, MicroSD) • Can be used for presentations like PowerPoint Cons: • Reliability issues; may stop working after a month • Limited playtime; may not last longer than an hour • Not suitable as a replacement for high-end projectors • Sound quality is average, may require external speakers for better audio • Fan noise can be distracting if sitting close to the unit • Difficulty achieving sharp focus across the entire image Overall Impression: The projector offers a decent entry-level solution for casual viewing, particularly in dark settings. Its portability and affordability make it appealing, but potential buyers should manage their expectations regarding performance and reliability. While it serves well for light use, it is not designed for high-end home theater experiences. |
Bewinner Portable Mini | Pros: • Lightweight and durable • Easy to use and set up • Clear, crisp, and clean picture quality • Good value for the money • Functions well after extended use (2 years reported) Cons: • Not Wi-Fi compatible, requires wires • Inconsistent button responsiveness • No sound output reported Overall Impression: The Bewinner Projector is a budget-friendly option that offers good picture quality and ease of use, making it suitable for casual viewing and entertaining children indoors. However, its lack of Wi-Fi compatibility and sound output may deter some users, especially those looking for a more modern and versatile device. |
