PONER SAUND Mini Projector vs Alwtniet Smart Projector vs Thunrlge Mini Projector: Which Delivers Native 1080P Best?
KeyGood5298
PONER SAUND Mini Projector​
Alwtniet Smart Projector​
Thunrlge Mini Projector​
$45.88​
$84.99​
$83.99​
家庭影院,教育,游戏​
Home Cinema​
remote control, GP16 Projector, Power Cable, HDMI Cable, 3 in 1 AV Cable​
Adapter​
User Manual, Remote​
Wireless Connection: Multi-screen interaction, compatible with iOS and Android, no extra cables required
Resolution: 1280x720P native (1920x1080P supported)
Brightness: 5500 lumens
Contrast Ratio: 5500:1
Aspect Ratio: 16:9/4:3
Screen Size: 40” to 210”
Projection Distance: 5ft to 15ft (recommended 6.5ft)
Dimensions: 7.87*5.90*2.95 inches
Weight: 2.5 lbs
Built-in Speaker: Yes
Connectivity: HDMI, USB, AV, headphone
Customer Service: Lifetime customer service
Built-in Apps: Access to over 1,000,000 videos; supports Netflix, Prime Video, YouTube
Resolution: Native 1080P, 4K support
Brightness: 320 ANSI lumens
Contrast Ratio: 10,000:1
Image Alignment: Automatic vertical correction, 4-point keystone adjustment
Connectivity: WiFi 6, Bluetooth 5.2, HDMI, USB ports
Operating System: Whale OS with App Store access
WIFI 6 - Built-in, fast transmission, low delay, connects in 5 seconds
Bluetooth 5.0 - Built-in chip, connects to audio devices
180° Rotable Stand - Allows projection from various angles, 40 to 130 feet
HD Projection - Supports 4K 1080P, 40-130 inch screen, optimal distance 5.51 ft
Connectivity - HDMI, USB, 3.5mm headphone ports, suitable for multiple devices
Applications - Home theatre, parties, work, etc.
Unboxing Experience​
PONER SAUND Mini Projector:​
The Poner Saund Model M8 has a robust and attractive design that catches the eye. Its larger frame compared to my previous ViewSonic projector gives it a solid presence, and I appreciate the four mounting screw locations, which offer more flexibility for installation. While the projector has a somewhat bulky, square shape, it feels well-constructed and durable. The aesthetic is simple yet functional, blending in nicely with my home setup, especially when mounted to the ceiling.
Alwtniet Smart Projector:​
The HY320 NTV projector has an appealing design, slightly larger than some other models I've owned, but still lightweight and portable. Its aesthetic is modern and functional, making it easy to place on any surface or even attach to a tripod stand. The projector's build quality feels solid, and its compact size means I can easily transport it, whether I'm setting it up for a cozy indoor movie night or an outdoor gathering.
Thunrlge Mini Projector:​
I was immediately struck by the compact and lightweight design of this mini projector as soon as I unboxed it. The build quality feels solid, and it’s surprisingly portable, making it easy to carry anywhere. The sleek and modern aesthetic fits well with my home decor, and I particularly appreciate that it can be easily set up in various spaces, whether it’s a living room or outdoors for a movie night.
40 Inches - 100 Inches​
30 Inches - 150 Inches​
40 Inches - 130 Inches​
5 Feet - 15 Feet​
1 Meters - 4 Meters​
3.94 Feet - 13.12 Feet​
5500:1​
10000:1 Pixels​
1500:1​
1280 x 800​
4096 x 2160 Pixels​
1280 x 720 Pixels​
1280 x 800​
1280 x 720​
5500 Lumen​
320 Lumen​
The viewing experience with the Poner Saund Model M8 has been quite satisfying. The image quality is impressive, particularly in a dark room where the crispness rivals that of a cinema screen. While I can achieve a massive 200" projection size, the quality does diminish slightly on a wall compared to a proper screen. The projector performs best at around 12 feet for a 100" to 120" screen, delivering vibrant colors and clear details. I appreciate the brightness and contrast adjustments available, although the menu can feel a bit "clunky." Additionally, the built-in sound is surprisingly adequate for casual viewing, but I prefer to connect it to a soundbar for enhanced audio.
The viewing experience has been nothing short of fantastic. The 1080P resolution delivers sharp and clear images, and the brightness is impressive, especially in darker settings. I’ve used it for movies, gaming, and even presentations, and the audio quality is rich and clear, complementing the visuals perfectly. Whether I’m projecting onto a wall or a portable screen, the colors are vivid, and the picture quality remains consistent throughout the screen size.
The viewing experience has been nothing short of fantastic. With impressive 1080P resolution and support for 4K, the image quality is sharp, and the colors are vibrant, making every movie night feel like a cinematic event. I love that I can project a massive screen size of up to 130 inches, and the auto keystone feature ensures the image is always well-aligned, regardless of the projection angle. The projector performs excellently in dimly lit environments, enhancing the overall experience.
Wireless, Portable, Built In Wi Fi​
Built-In Speaker, Native 1080P with 4K support, 320ANSI, Built-in Official APPS​
Built-In Speaker, Portable, Built-In Cooling System, Built-In Wi-Fi​
1080P​
H.264, H.265​
H.264, H.265​
60 Watts​
52000 Hours​
50000 Hours​
50000 Hours​
wireless(Wi-Fi)/wired, HDMI, USB, AV, TF​
Bluetooth, Wi-Fi​
Bluetooth, Wi-Fi​
ios system, android system​
Laptop, Television, Smartphone, Speaker​
Laptop, Tablet, Smartphone, Speaker​
60 watts​
60 watts​
Mount Type​
table, tripod, ceiling (mount not included)​
Tabletop Mount​
Tabletop Mount​
7.87"L x 5.9"W x 2.95"H​
8.66"L x 4.72"W x 6.69"H​
3.94"L x 3.94"W x 7.48"H​
Setting up the projector was straightforward, although I encountered some minor hiccups. I was relieved to find that it supports both legacy connections and HDMI, making it compatible with my existing devices, including the ROKU box. The included instructions were somewhat sparse, but the intuitive nature of the menu allowed me to navigate through various settings easily. I found the X-Y zoom and four-point keystone adjustment features particularly helpful for achieving the right image alignment. However, I did wish the manufacturer had included the dimensions of the mounting points, which I had to discover through trial and error.
Setting up this projector was a breeze. The initial connection to WiFi and Bluetooth was intuitive, and it took no time at all to get everything running smoothly. The pre-installed apps, including Netflix, significantly enhance the usability, allowing me to dive straight into streaming without the hassle of additional installations. I appreciate how simple it is to adjust the projector screen size and focus, making it versatile for various viewing scenarios.
Setting up the projector was incredibly straightforward and hassle-free. I plugged it in, connected to WiFi in mere minutes, and was ready to go. The built-in Google TV functionality is a significant advantage, providing access to a plethora of entertainment options without the need for additional devices. The multiple input options, including HDMI and USB, add to its versatility, making it convenient to connect various devices like laptops, gaming consoles, and smartphones.
• Excellent image quality, especially in dark settings
• Multiple connectivity options including HDMI and legacy inputs
• User-friendly setup with easy adjustments for image correction
• Solid build quality with an attractive design
• Adequate built-in speaker and compatibility with external sound systems
• Some lag experienced with certain video inputs
• Brightness can be insufficient in well-lit environments
• Fan noise noticeable, though manageable
• Limited adjustable picture settings and clunky menu navigation
• Some users report issues with dust inside the lens
Overall, my experience with the Poner Saund Model M8 has been positive, especially considering its price point. It has proven to be a valuable addition to my home entertainment setup, providing a great viewing experience without breaking the bank. While it isn't without its shortcomings, such as some brightness issues and noticeable fan noise, the projector's features and performance make it a commendable choice for both indoor and outdoor use. I feel confident in recommending it as an excellent entry-level option for anyone looking to enjoy a cinematic experience at home.
• Built-in streaming apps like Netflix
• Simple setup and connectivity
• Excellent picture quality with sharp resolution
• Rich audio experience
• Supports voice commands for convenience
• Limited app options
• May require a dark room for optimal viewing
• Occasional freezing when navigating apps
Overall, I am highly impressed with the HY320 NTV projector. It has exceeded my expectations in terms of performance and usability. The combination of its lightweight design, excellent image and sound quality, and seamless streaming capability makes it an outstanding choice for anyone looking for a reliable projector without breaking the bank. Whether for indoor movie nights or outdoor festivities, this projector is a fantastic investment that checks all the boxes for quality and convenience.
• Compact and lightweight design for portability
• Easy setup and quick connectivity
• Excellent picture quality with 4K and 1080P support
• Large adjustable screen size up to 130 inches
• Built-in Google TV for direct access to streaming apps
• Bluetooth connectivity for enhanced audio options
• Built-in speaker quality could be improved
• Short power cord may require an extension
• Manual focus adjustment needed, not auto-focus
Overall, I am thoroughly impressed with this mini projector. It has exceeded my expectations in terms of performance, convenience, and value. The combination of excellent image quality, easy setup, and versatile connectivity makes it a fantastic addition to my home entertainment setup. Whether for casual movie nights, gaming sessions, or presentations, this projector has proven to be a reliable and enjoyable choice. Highly recommended for anyone looking for a portable and affordable projector!
Trollatopoulous
PONER SAUND Mini Projector: So, I tried connecting it to my phone with WiFi and cable, but it didn't work with any of the 3 phones I tried. The sound quality is pretty terrible too. I did get the WiFi to work by finding the password in the quick start guide – it’s 12345678, not my home network password. Overall, it's alright for the price!
NetworkingJesus
Just got the Alwtniet Smart Projector for my daughter! So glad I held off 'cause I almost bought one that didn't have Netflix. It makes a huge difference!
horizon936
Thunrlge Mini Projector hooked up to Roku in no time! Picture looks great. It’s a bit quiet, but not a big deal for me. Background noise isn't annoying. Overall, I think I got my money's worth. I just wish the mount had more space for wires, but as a woodworker, I’ll fix that in no time!
NetworkingJesus
The Thunrlge Mini Projector is super handy and user-friendly! It's tiny and lightweight, so you can take it wherever. The picture quality is awesome, especially in the dark, and it connects to all sorts of devices. The sound's solid, but hooking up some speakers makes it even better. Perfect for movie nights or sharing videos!
jcwillia1
Got the Thunrlge Mini Projector for vacation to binge-watch Netflix and YouTube. Picture quality is solid for what you pay, but the sound could be louder.
