Polocsh Mini Portable Projector vs YABER V2: Which 1080P Mini Projector Offers Better Features for Outdoor Use?
mufcroberts
In the realm of portable projectors, two contenders stand out: the Polocsh Mini Portable Projector and the YABER V2 Projector. While both promise convenience and quality, their approaches to portability and functionality may raise some eyebrows.
The Polocsh Mini Projector is all about ultra-compact design, weighing in at just 530g and fitting snugly in your palm. It boasts a built-in Android 11.0, high brightness, and 1080P support, making it a versatile choice for outdoor movie nights or indoor cinema experiences. The rotating projection feature and automatic keystone correction suggest a user-friendly design aimed at flexibility.
On the other hand, the YABER V2 Projector takes a different route with its wireless connectivity and innovative zoom function. This projector not only supports easy mirroring from smartphones but also offers an innovative SCT screen that enhances clarity by 25% when viewed from the front. With a native resolution of 1280x720p, it claims to be brighter and clearer than many competitors in its class.
So, which projector will truly deliver when it comes to ease of use, picture quality, and overall experience? Stick around as we dissect the strengths and weaknesses of each to see which one deserves a spot in your tech arsenal.
Specs Comparison​
Basic​
Polocsh Mini Portable Projector​
YABER V2 Projector​
$59.99​
$158.77​
Indoor/Outdoor, Home Cinema, Gaming​
Power Cord, Remote Control, Manual, Smart Projector, HD Cable​
Remote (Batteries not included), Power Cable, HDMI, Manual, 3-in-1 AV Cable, Support Base​
App​
【Ultra Compact & Built-in Android 11.0 Projector】Polocsh smart projector with the latest Android TV only 530g aand featuring a compact design that fits in the palm of your hand, the mini projector combines compactness, high brightness and high image quality, so you can enjoy high-quality cinema effects indoors or outdoors!
【180°Rotating Projection & 1080P Support】Portablprojector is equipped with a 210° rotatable bracket, which can be projected onto a white wall or ceiling in your home, and you can enjoy the wonderful content while lying daown, making free and flexible projection possible! Whether you're camping, travelling or on the patio, you can enjoy the ultimate immersive experience!
【Auto Keystone Correction & 1:0.9 Short Throw Projector】Movie Projector 4k also features automatic keystone correction, which automatically corrects skewed images whether placed horizontally or at an angle, quickly adjusting to the best picture. In addition, manual focusing is supported, making it easy to get a clear image in just a few seconds. Providing you with unrivalled convenience!
[Newest wireless connection & zoom function] Yaber v2 wifi projector supports wifi connection for both iOS/Android system, can mirror movies/videos/photos/games from your smartphone or other miracast-enabled devices to big screen freely. With zoom function, it can shrink the image size from 100% to 75% using the remote without moving the projector.
[Innovative sct projector screen] V2 projector comes with a sct screen. The sct screen adopted the latest innovative converging tech, if viewed from the front, the clarity and brightness of the projection screen will immediately increase by 25%.
[Native 1280*720p & wide compatibility] V2 wifi projector is native 1280x720p (1920x1080p supported), 5500 lumens, 6000:1 high contrast and 16:9/4:3 aspect ratio, which is 60% brighter and clearer than other equivalent projectors. With multiple ports: hdmi,usb,vga,av,audio,tf card, this phone projector compatible with tv box, fire stick tv, chromecast, pc, laptop, tablet, external speakers, usb stick, iPad, iPhone, android smartphone.
YABER V2 Projector​
40 Inches - 150 Inches​
45 Inches - 200 Inches​
3.6 Feet - 12.6 Feet​
3 Feet - 15 Feet​
10000:1​
1024 x 720​
1280 x 720​
1980 x 1080 Pixels​
2000 Lumen​
8000 Lumen​
LED​
SCT projector screen technology​
100000 Hours​
H.264, H.265​
AVC​
YABER V2 Projector​
60 Watts​
android, vera, ios​
Bluetooth, Wi-Fi​
WiFi,VGA, USB, HDMI, AV, Phone, 1080P Supported​
Television, Laptop, Tablet, Speaker, Smartphone​
50 watts​
3 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Built-In Speaker, Portable​
Built-In Speaker, Lightweight, Built-In Wi-Fi​
3.97"L x 3.5"W x 6.69"H​
11.81"L x 7.09"W x 4.33"H​
Side-by-Side Comparison​
YABER V2 Projector​
System ExperienceSetting up the Polocsh Mini Portable Projector was surprisingly straightforward and hassle-free, which I really appreciated. I simply plugged it in, connected it to Wi-Fi, and was ready to go in no time. The included remote made navigating through the menus easy, and I was thrilled that I didn't have to struggle with a complicated manual. However, I did notice that the power cord could be a bit short, which might require an extension cord if you're not close to an outlet.Setting up the YABER V2 projector was surprisingly straightforward, which I truly appreciated. It arrived ahead of schedule, and I was able to get everything up and running in about half an hour. I used a camera tripod to position it just right, which made a big difference in achieving a good viewing angle. Following the instructions was largely smooth sailing, aside from a hiccup when trying to connect wirelessly at first. Ultimately, connecting via HDMI was my go-to method, which made the process feel more reliable and stress-free.
YABER V2 Projector​
Viewing ExperienceWhen it comes to picture quality, I found it to be pretty decent for casual use, especially considering the price. The brightness was adequate in dimmer settings, but I did notice that it struggled a bit in brighter rooms. While it’s advertised as supporting 1080P, I felt that the resolution didn’t quite live up to that claim, as the images appeared somewhat pixelated at larger sizes. That said, the colors were vibrant enough to keep me engaged during movie nights.When it comes to picture quality, I have to say I was pleasantly surprised for the price I paid. The brightness was adequate for my needs, especially when watching in a darkened room. I found the colors to be vibrant, and the size of the projection was impressive, easily filling up the wall I was using. Of course, I could see some focus issues toward the edges, but honestly, when I was engrossed in a movie, those minor imperfections faded into the background. The ability to adjust the focus and keystone correction was a nice touch, allowing me to fine-tune the image to my liking.
Other Experience​
YABER V2 Projector​
Other ExperienceUsing this projector for my various projects and casual viewing has been enjoyable overall. The auto-keystone feature was a game-changer for me, allowing for easy adjustments even when I couldn't position it perfectly. I also liked that I could connect to my Bluetooth speaker, which significantly improved the audio quality compared to the built-in speakers that felt a bit tinny. However, I did find the fan noise to be somewhat distracting at times, especially during quieter moments in movies.Despite my initial excitement, I did encounter some limitations when it came to streaming directly from my phone. I had hoped to easily watch my favorite shows on Netflix or Hulu, but I quickly learned that it required a Fire Stick for that functionality. While I found the audio quality to be decent, I realized that I needed to invest in external speakers for a more immersive experience. The fan noise was a bit louder than I expected, but it wasn’t a dealbreaker—just a small annoyance that I learned to tune out once the movie started.
Our Verdict​
Polocsh Mini Portable Projector:​
There are definitely a lot of positives to this projector. It’s compact and portable, making it easy to use in different locations, whether I’m projecting onto a wall or a ceiling. The setup process was quick, and I appreciated the inclusion of pre-installed apps for streaming. The ability to connect via HDMI or Bluetooth adds versatility, allowing me to use it with various devices without any major issues.
On the downside, the sound quality really could use some improvement. While I’m happy to use an external speaker for better audio, it would be nice if the projector could handle sound better on its own. Additionally, it can struggle with brightness, particularly in well-lit environments, and the picture quality isn’t as sharp as I’d hoped. I also experienced some minor connectivity issues with the internal apps, which can be frustrating when I’m just trying to relax and enjoy a show.
Overall, I’m quite satisfied with the Polocsh Mini Portable Projector for its price point. It’s not perfect, and there are certainly areas for improvement, particularly in sound and brightness, but it serves its purpose well for casual movie nights and creative projects. I would recommend it to anyone looking for an affordable and fun way to project content, as long as they’re aware of its limitations.
YABER V2 Projector:​
One of the biggest pros for me was definitely the affordability of the YABER V2 projector. For a budget-friendly option, it delivers a solid performance that exceeded my expectations. The portability is another significant advantage; it’s lightweight and easy to carry around, making it perfect for movie nights in various locations. The setup process was quick and hassle-free, and I loved that it came with an included screen, even if I opted to use my wall instead.
However, I can't ignore the drawbacks. The wireless screen mirroring was quite frustrating at times, and the lack of compatibility with certain streaming apps led to some disappointment. I also found the audio volume insufficient for my liking, which prompted my search for additional speakers. Lastly, while the picture quality was good, it wasn’t perfect, particularly with focus issues at the edges—something that might deter more discerning viewers.
Overall, I have to say that my experience with the YABER V2 projector has been positive. It’s been a fantastic addition for movie nights, and I appreciate the value it offers for the price. While there are limitations, especially regarding audio and streaming capabilities, I find that it meets my needs well enough for casual use. I’d recommend it to anyone looking for an entry-level projector, as it provides a fun and enjoyable viewing experience without breaking the bank.
So, I got my hands on the YABER V2 Projector, and let me tell you, during the day, even with blackout curtains, the picture was pretty lackluster. Honestly, this thing really needs a dark room to shine. But once the sun went down? Wow, it totally transformed!
I did have to grab a screen and a Roku to really get the most out of it. And once I hooked up a speaker? That’s when it really came alive! I’d totally recommend this over any $300 TV out there. Seriously, if you pair it up with a Roku (which is about $40) and a decent speaker (anywhere from $50 to $150), you’ll be saying goodbye to your smart TV in no time!
DealsFishman
Yo, let me tell you about the YABER V2 Projector – it’s awesome! The first time I fired up a movie, I felt like I was at the theater! The screen is huge and super crisp! If I had to nitpick, I'd say I wish it was a bit brighter, but honestly, that’s a minor thing. The best part? It’s a breeze to use! I’m not exactly a tech whiz, so I was kinda worried when I got it that it’d be a pain to set up. But all I had to do was plug in my Fire Stick and connect the projector. So easy! I’m really stoked I chose this one. Seriously, it’s a total game-changer!
So, I just got my hands on the YABER V2 Projector, and let me tell you, it's a total game-changer for movie nights! I was on the hunt for something that wouldn’t break the bank, and this little guy did not disappoint.
First off, the picture quality? Seriously impressive for the price! It’s small enough to carry around without any hassle, so I can easily move it from my living room to the backyard. Plus, the brightness is on point—everything looks super clear, and the colors pop like crazy!
And can we talk about the sound? The speakers are pretty solid, way better than I expected. The setup was a breeze too; even the instructions are in Italian if that’s your jam. The remote worked like a charm, making it super easy to navigate.
There’s just something magical about throwing an HD movie up on a big wall, right? If you’re in the market for a powerful, portable projector, you’ve got to check out the YABER model. Honestly, it’s such a steal for the quality you get. Highly recommend!
fosterzar
Check out this Polocsh Mini Portable Projector! It’s a breeze to set up and connects to Wi-Fi in no time. Plus, it’s super light and feels sturdy, which is awesome. Focusing the screen is a piece of cake too. The only downside? The cord could definitely be a little longer. But overall, it’s a solid little gadget!
Elfman72
Yo, let me tell you about this Polocsh Mini Portable Projector – I’m obsessed! Setting it up is a breeze, and it works like a charm! The auto keystone feature is spot on, and honestly, the picture quality is pretty impressive for what you pay. Now, the sound could use a little boost, but no worries – just plug in some speakers, and you’re good to go! Focusing the lens is super easy and super precise, which is a huge plus. It even comes with Android TV built in, although I gotta warn you, the UI can be a bit laggy. But hey, just plug in an HDMI Roku stick or Apple TV, and you’ll be golden! All in all, this thing is a steal for the price!
Gizmoitus
So, let me tell you about this YABER V2 projector we got! My kids and I have been using it in the bedroom, just shining it on a plain white wall from my dresser, and honestly, we’re obsessed. We use it every single day, and the picture is super clear while the sound is pretty solid too.
If we were watching in the living room, I’d probably splurge on a fancy screen and some better speakers, but for kiddo movies in the bedroom? It’s just perfect as is. All you need is a cheap HDMI converter for whatever device you’re using, and you’re good to go. Seriously, it’s such a good deal for the price!
I’ve been using my phone to connect everything, and we’ve had it for over a month now. We do have the screen that came with it, which is nice, but we love projecting onto the wall because it makes everything feel extra big—like our own little movie theater! My 2-year-old and 4-year-old are in love with it, and even my husband, who’s a bit of a projector snob and was really skeptical at first, agrees that it was a great buy. We actually gave it to the girls as an early Christmas present.
So if you’re thinking about getting one, just do it! It’s a blast!
