Amanda Brown
Active member
- 1 Specs
- 2 Which to get
In the world of portable projectors, two models are vying for your attention: the Philips PicoPix Max One and the InFocus Genesis IN118BB. On one hand, we have the Philips PicoPix Max One, boasting an impressive capability to project images up to 120 inches, making it a compelling choice for those who prioritize size and brightness. Its ultra-portable design and versatile connectivity with USB-C video and HDMI cater to modern needs for easy setup and mobility.
Conversely, the InFocus Genesis IN118BB presents itself as a lightweight contender, tipping the scales at just 1 kg. While it may not flaunt the same projection size capabilities, its portability could appeal to those who value ease of transport over sheer output.
So, which projector truly deserves the title of the best portable option? Is it the Philips with its larger projection and brightness, or does the lightweight InFocus offer a more practical solution for on-the-go presentations? Let’s dive into a side-by-side comparison to see which one holds up under scrutiny.
First up, we've got the Philips PicoPix Max One Portable Projector. It promises up to a 120'' display, which sounds super exciting for movie nights. Plus, it’s ultra bright and portable—perfect for taking around. It also has USB-C video and HDMI options, which is a nice touch for connecting devices easily. But I’m curious about the picture quality and sound. Do you think it holds up?
Then there's the InFocus Genesis IN118BB Projector. It’s lightweight at just 1 kg, which is great for portability too. But I’m wondering how it stacks up in terms of picture and sound quality compared to the Philips. Any potential downsides to consider with this one?
Would love to hear your experiences or insights on which one might be the better buy! Thanks!
Specs
Parameter | Philips PicoPix Max One Portable Projector | InFocus Genesis IN118BB Projector |
Reference Price | $199.99 | - |
Recommended Uses | - | Gaming |
Built-In Media | - | DLP Projector |
Highlight | Up to 120'' Ultra bright and portable USB-C video and HDMI | IN118BB Delivery weight: 1 kg |
Screen Size | 30 Inches - 100 Inches | N/A - 300 Inches |
Throw Distance | N/A - 0.96 Meters | 9.8 Meters - 1 Meters |
Contrast Ratio | 10000:1 | 30000:1 |
Maximum Resolution | 1920 x 1080 | 1920 x 1080 |
Brightness | 30000 lumen | 3800 Lumen |
Display Type | DLP, LED | DLP |
Picture Enhancement | Digital Light Processing and Multi-LED technology | - |
Other Features | - | Built-in 3D |
Video Encoding | H.264 or H.265 (HEVC) | H.264, H.265 |
Lamp Wattage | 5E+1 Watts | 203 Watts |
LightSource Life | 20000 Hours | 8000 Hours |
Controller Type | Button Control | Remote Control |
Control Method | - | Remote |
Connectivity Technology | USB, HDMI | USB, HDMI |
Compatible Devices | Laptop, Smartphone, Gaming Console | Laptop |
Wattage | 50 watts | 267 watts |
L x W x H | 4.88"L x 4.72"W x 1.67"H | - |
Which to get
I'm torn between two projectors and could really use your thoughts!First up, we've got the Philips PicoPix Max One Portable Projector. It promises up to a 120'' display, which sounds super exciting for movie nights. Plus, it’s ultra bright and portable—perfect for taking around. It also has USB-C video and HDMI options, which is a nice touch for connecting devices easily. But I’m curious about the picture quality and sound. Do you think it holds up?
