Dramaqueen
Everyone is familiar with the Panasonic brand, and many friends are also concerned about Panasonic TV products. However, many friends are still troubled by how to install third-party applications on Panasonic TV. As an old user of Panasonic TV, here are some common questions about Panasonic TV. I hope to help you.
It takes several seconds to display the image after turning the TV on
●When turning the TV on, the panel adjustment is performed. It is not a malfunction.
The TV does not switch on
●Check the mains lead is plugged into the TV and the mains socket.
The TV goes into Standby mode
●Auto power standby function is activated.
The remote control does not work or is intermittent
●Are the batteries installed correctly?
●Has the TV been switched on?
●The batteries may be running low. Replace them with new ones.
●Point the remote control directly at the TV's remote control signal receiver (within about 7 m and a 30 degree angle of the signal receiver).
●Situate the TV away from sunshine or other sources of bright light so they do not shine on the TV's remote control signal receiver.
No image is displayed
●Check the TV is turned on.
●Check the correct input mode is selected.
●Check the setting of [AV] ([COMPONENT]/ [VIDEO]) in [Input Selection] to match the signal being output by the extermal equipment.
●Is [Luminance Level], [Contrast], [Brightness] or [Colour] in the Picture Menu set to the minimum?
●Check all required cables and connections are firmly in place.
An unusual image is displayed
●This TV has a built-in Self Test. Makes a diagnosis of picture or sound problems.
◆[TV Self Test] (Help Menu)
●Tur the TV off with Mains power On / Off switch, then turn it on again.
●If the problem persists, initialise all settings.
十[Shipping Condition] in [System Menu] (Setup Menu)
