Serena Anderson
- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The Optoma ML1080ST is a compact, low-cost laser projector that, when paired with its separate Wi-Fi dongle, has features that work for many types of business and education applications. It's also got an edge to it that makes it suitable for home use. To begin, it's a native 1080p-resolution (1920x1080) DLP projector with a 0.23-inch DMD chip. Its sealed light engine offers IP5X dust resistance and a lifespan of up to 30,000 hours in Eco Mode.Be advised, though, that the 1,200 lumen claim of brightness advertised on the projector's spec sheet, with no measurement technique specified, is not for ANSI lumens, but rather for "HK lumens" based on Optoma's claim of perceived brightness. The HK refers to the Helmholtz-Kohlrausch Effect, where the human eye perceives highly saturated colors to be brighter under some circumstances. This is basically the laser projector equivalent to "LED lumens," which some manufacturers have used to describe the brightness of LED projectors, often attributing a number that is double or more the ANSI reading. Optoma says the actual ANSI lumens spec for the ML1080ST and ML1080 is 550, and it measured on target for that number.
Parameter | Optoma ML1080ST |
Reference Price | $899.1 |
Recommended Uses | SMB and Work From Home, Road Warrior, Home Cinema, Gaming |
Built-In Media | Power Adapter, User Manual, Remote Control, Battery, Carrying Bag |
Highlight | • Type: Small RGB Laser Projector • Video Quality: 100% REC.709, 98% DCI-P3 • Input Lag: 23ms at 1080p60 and 4K60 • Streaming Options: EZC-USB Wireless adapter for apps • Resolution: 1080p with 4K input • Inputs: HDMI 2.1, two USB Type C, USB-A • Features: Built-in speaker, media player, 9 Display Modes, Bluetooth, casting, screen mirroring, file manager, signage mode • Included Accessories: Premium carry case |
Screen Size | 60 Inches - 100 Inches |
Throw Distance | 1.59 Meters - 2.66 Meters |
Contrast Ratio | 300000:1 |
Brightness | 1200 Lumen |
Display Type | Laser |
Viewing Experience | The Optoma ML1080ST portable projector offers a versatile range of eight color modes, allowing users to tailor their viewing experience to different environments and content types. The Vivid mode stands out for its high saturation and brightness, achieving a brightness of 547 ANSI lumens, making it suitable for well-lit rooms. Its RGB design contributes to an even balance of colors, while the option to adjust gamma settings enhances its performance in various lighting conditions. The projector's ability to maintain close proximity to industry-standard color temperatures and gamma values indicates a thoughtful design aimed at providing accurate color representation. Overall, the ML1080ST demonstrates impressive color accuracy and adaptability, making it a strong contender for users seeking quality performance in a portable format. |
Lamp Wattage | 33 Watts |
Wattage | 57 watts |
Connectivity Technology | USB, HDMI, 3.5mm Audio |
Hardware Connectivity | USB, HDMI, 3.5mm Audio |
Compatible Devices | Media Players, PC/Laptop, Tablet, Next Gen Gaming Console, Smartphone |
Other Features | Enhanced Game Mode w/ ALLM, Ultra-Portable Short Throw, RGB Laser Technology, Time-of-Flight (ToF) Technology, 100% REC.709 | 98% DCI-P3 |
System Experience | The ML1080ST is a short throw projector designed for flexibility and ease of use in various settings. With a fixed lens offering a 0.78:1 throw ratio, it allows for a range of image sizes from 60 to 100 inches, making it suitable for different room dimensions. Its proximity to the screen minimizes shadow interference, a significant advantage for active environments like classrooms or homes with children. Key features include an eye protection sensor that temporarily disables the laser when someone crosses in front, which is beneficial for safety but may be a nuisance during use. The projector includes a small kickstand for upward tilting, a tripod mount for stability, and digital zoom capabilities for adjusting image size. The Auto Focus feature simplifies setup by quickly adjusting the focus, with the option for manual fine-tuning via remote. Overall, the ML1080ST combines practicality with user-friendly features, making it a solid choice for those needing a versatile short throw projection solution. |
User Feedback
Pros:• Absolutely tiny; easily fits in a standard briefcase or carry-on.
• Extremely bright image quality, even in lit rooms.
• Can be mounted on a tripod, providing flexible setup options.
• Short throw capability allows placement close to the screen.
• Durable; survived a 3-foot drop without damage.
• Sufficient for 90% of presentation needs.
• Fans can be a bit "whiny," contributing to noise.
• No zoom feature; requires physical movement of the unit for adjustments.
• Short throw may necessitate close placement to the screen, which can be inconvenient.
• External power brick is large and cumbersome.
• Color accuracy may not be perfect, with a tendency towards a red cast.
• Focus can vary from top to bottom when placed near the screen.
The projector offers an impressive balance of portability and performance, making it an excellent choice for those who need a compact solution for presentations. Its bright image quality and durability stand out, though some limitations in zoom and color accuracy might be a consideration for more discerning users. Overall, it's a worthwhile investment for its size and capabilities.
