Optoma ML1080ST Review: A Full-Feature Portable Projector for Home and Travel?
First Impressions​
The Optoma ML1080ST is a compact, low-cost laser projector that, when paired with its separate Wi-Fi dongle, has features that work for many types of business and education applications. It's also got an edge to it that makes it suitable for home use. To begin, it's a native 1080p-resolution (1920x1080) DLP projector with a 0.23-inch DMD chip. Its sealed light engine offers IP5X dust resistance and a lifespan of up to 30,000 hours in Eco Mode.
Be advised, though, that the 1,200 lumen claim of brightness advertised on the projector's spec sheet, with no measurement technique specified, is not for ANSI lumens, but rather for "HK lumens" based on Optoma's claim of perceived brightness. The HK refers to the Helmholtz-Kohlrausch Effect, where the human eye perceives highly saturated colors to be brighter under some circumstances. This is basically the laser projector equivalent to "LED lumens," which some manufacturers have used to describe the brightness of LED projectors, often attributing a number that is double or more the ANSI reading. Optoma says the actual ANSI lumens spec for the ML1080ST and ML1080 is 550, and it measured on target for that number.
Optoma ML1080ST​
$899.1​
SMB and Work From Home, Road Warrior, Home Cinema, Gaming​
Power Adapter, User Manual, Remote Control, Battery, Carrying Bag​
Highlight
Type: Small RGB Laser Projector
Video Quality: 100% REC.709, 98% DCI-P3
Input Lag: 23ms at 1080p60 and 4K60
Streaming Capability: Downloadable apps with EZC-USB Wireless adapter
Resolution: 1080p with 4K input
Inputs: HDMI 2.1, two USB Type C, USB-A
Features: Media player, built-in speaker
Display Modes: 9 modes
Connectivity: Bluetooth, casting, screen mirroring
Additional Features: File manager, signage mode, premium carry case
Optoma ML1080ST​
60 Inches - 100 Inches​
1.59 Meters - 2.66 Meters​
300000:1​
1920 x 1080 Pixels​
1200 Lumen​
Laser​
Viewing Experience
The Optoma ML1080ST is a compact portable projector that offers a versatile range of eight color modes, catering to various viewing environments and content types. Its Vivid mode stands out with impressive brightness and saturation, making it suitable for well-lit rooms. The projector’s RGB design allows for an even balance of color elements, which is further enhanced when gamma settings are adjusted. The ability to achieve accurate color temperature and gamma tracking demonstrates its potential for delivering quality visuals. Overall, the Optoma ML1080ST is designed to provide a customizable viewing experience, with strong performance in color accuracy and brightness.
Optoma ML1080ST​
30000 Hours​
33 Watts​
57 watts​
USB, HDMI, 3.5mm Audio​
Hardware Connectivity​
Media Players, PC/Laptop, Tablet, Next Gen Gaming Console, Smartphone​
Enhanced Game Mode w/ ALLM, Ultra-Portable Short Throw, RGB Laser Technology, Time-of-Flight (ToF) Technology, 100% REC.709 | 98% DCI-P3​
The ML1080ST is a versatile short throw projector designed for various environments, featuring a fixed lens with a 0.78:1 throw ratio that allows for image sizes ranging from 60 to 100 inches. Its placement flexibility is enhanced by a small kickstand for upward tilting and a tripod mounting thread. The projector includes an eye protection sensor that temporarily shuts off the laser when obstructed, making it suitable for settings with potential interruptions. While the fixed zoom limits some adjustments, the digital zoom and convenient Auto Focus feature provide ease of use, especially for mobile applications. Overall, the ML1080ST combines practicality and user-friendly features, making it a solid choice for classrooms, retail spaces, and home use.
User Feedback​
• Compact and portable design
• Exceptionally bright image quality
• HDMI capable for easy video source connectivity
• Good workaround options for audio using Bluetooth
• Minimal fan noise during operation
• Only audio out available is via composite cable
• Built-in speaker is inadequate for movies
• Focusing can be finicky, with blurriness at the edges
• Requires refocusing 10-15 minutes after startup
This projector is a solid choice for those seeking a bright, portable option for movie-watching. While it has some audio limitations and a few quirks with focusing, its performance and image quality make it a worthwhile investment, especially if you can accommodate a Bluetooth audio solution. However, for those who can afford it, the upgraded model (ML1000P) may offer even better features and convenience.
