Optoma HZ40HDR vs ViewSonic PA503HD: A 1080p Education Projector Comparison for Learning Environments
windstri85
Optoma HZ40HDR​
ViewSonic PA503HD​
Price​
$899
$559.99
Light Source Type: DuraCore laser technology
Operation Time: Up to 30,000 hours
Durability Rating: IPX6 dust resistance
Projection Distance Range: Up to 32'9"
Image Size from 13'10": 120"
Resolution: 1080p (1920x1080)
Enhanced Game Mode Input Lag: 4ms @ 1080p240Hz, 16ms @ 4K60Hz, 16ms @ 1080p60Hz, 8ms @ 1080p120Hz
HDR Support: HDR10 and HLG
Contrast Ratio: 300,000:1​
Projector Type: 1080p FHD
Brightness: 4000 Lumens
Setup Features: 1.1x optical zoom, 40 degree vertical keystone
Contrast Ratio: High native contrast via 0.65" DMD chip
Lamp Life: Up to 15,000 hours in SuperEco Mode
Connectivity: Supports HDMI, USB Type A, compatible with media players, PCs, Macs, mobile devices​
Side-by-Side Comparison​
Optoma HZ40HDR​
ViewSonic PA503HD​
20 Inches - 300 Inches​
30 Inches - 300 Inches​
0.8 Meters - 10 Meters​
1 Meters - 10 Meters​
300000:1​
22000:1​
Display Resolution​
1920 x 1080 Pixels​
1920 x 1200 Pixels​
4000 Lumen​
4000 Lumen​
Laser​
Picture Quality Enhancement​
ViewSonic SuperColor​
Optoma HZ40HDR​
ViewSonic PA503HD​
240 Watts​
Light Source Life​
30000 Hours​
4000 Hours​
Mount Type​
Tabletop Mount​
Ceiling Mount​
Noteworthy Features​
360 Degree & Portrait Mode, Low Power Consumption, DuraCore Laser Technology, Compact Size, Full 3D​
High brightness, High native contrast ratio, Large Screen size, Easy multimedia access​
Connectivity​
Optoma HZ40HDR​
ViewSonic PA503HD​
USB, HDMI​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
USB, HDMI, 3.5mm Audio​
USB 2.0 Type A, HDMI, 3.5mm Audio​
Laptop, Television, Speaker​
Measurements​
Optoma HZ40HDR​
ViewSonic PA503HD​
Dimensions L x W x H​
10.79"L x 10.79"W x 8.5"H​
13.3"L x 12.2"W x 4.5"H​
Item Weight​
6.6 Pounds​
6 Pounds​
Product
PROS AND CONS​
Optoma HZ40HDR​
• Very bright even in well-lit environments
• Clear image quality and easy setup
• Good performance during motion images
• Satisfactory image quality after adjustments to color settings
• Eco Mode helps stabilize picture quality
• Very limited zoom functionality
• Factory color settings are excessively blue
• Firmware has issues with auto-adjustment during dimly lit scenes
• Internal speaker quality is subpar for larger events
This projector delivers bright and clear images suitable for various lighting conditions, making it a solid choice for casual viewing. However, users may need to invest time in adjusting the color settings and dealing with some firmware quirks. While it excels in brightness and clarity, the limited zoom and average sound quality may require additional considerations for optimal use. Ultimately, it represents a good value for those seeking a reliable projector for home entertainment.
ViewSonic PA503HD​
Pros
• Exceptionally bright performance, even in well-lit rooms
• Clear image quality at larger sizes
• Long throw distance allows for larger image without compromising brightness
• Effective cooling system with a well-functioning fan
• Easy setup for outdoor use
Cons
• Weak built-in speakers; external speakers are recommended
• Image size may be limited by throw distance in smaller rooms
• Lacks higher resolution options like 1080p native resolution found in other models
Overall Impression
This projector stands out for its impressive brightness and clarity, making it an excellent choice for use in ambient light conditions. While it may fall short in audio quality and resolution, its performance in bright settings and ease of setup make it a solid option for both indoor and outdoor uses, especially for events like parties or gaming.
