Optoma HD39HDR vs HD28HDR: Which Popular Home Theater Projector Under $1000 is Right for You?
WWGHIAFTC
Optoma HD39HDR​
Optoma HD28HDR​
Price​
$978.9
$768
Home Cinema, Gaming​
Gaming​
Lamp Life: Up to 15,000 hours
Projector Type: Versatile HD projector
Ideal Environments: Family rooms, theater rooms, game rooms, outdoor spaces
Installation: Vertical keystone correction, 1.3X zoom
Response Time: 8.4ms with 120Hz refresh rate
Resolution: 1080p (1920×1080) with 4K input
Contrast Ratio: 50,000:1
HDR Compatibility: HDR10 technology with 4K input​
Resolution: 1080p (1920x1080) with 4K input
Noise Level: 26dB
Operating Temperature: 41–104°F (5–40°C)
Humidity: 85% max
Brightness: 3,600 lumens
Color Wheel: 6-segment (RYGCWB)
Color Profile: sRGB & REC.709
Response Time: 16ms
Refresh Rate: 120Hz
3D Support: True 3D content, requires 3D glasses​
Side-by-Side Comparison​
Optoma HD39HDR​
Optoma HD28HDR​
1080 Inches - 305 Inches​
28 Inch Pounds - 301 Inches​
3.3 Feet - 32.8 Feet​
3.2 Meters - 35.37 Meters​
16:9​
50000:1​
Display Resolution​
3840 x 2160 Pixels​
3840 x 2160 Pixels​
4000 Lumen​
3600 Lumen​
DLP​
DLP​
Picture Quality Enhancement​
HDR (High Dynamic Range)​
HDR10​
Optoma HD39HDR​
Optoma HD28HDR​
HEVC Main 10 or AVC​
HEVC​
125 Watts​
240 Watts​
Light Source Life​
15000 Hours​
15000 Hours​
Mount Type​
Wall Mount, Ceiling Mount, Tabletop Mount​
ceiling mount, table top​
Noteworthy Features​
Built-In Speaker, Digital Keystone Correction, 3d-Ready​
Portable​
Connectivity​
Optoma HD39HDR​
Optoma HD28HDR​
VGA, USB, HDMI​
HDMI​
Hardware Connectivity​
Lightning, HDMI​
Lightning, HDMI​
Gaming Console, Television​
Gaming Console​
Measurements​
Optoma HD39HDR​
Optoma HD28HDR​
Dimensions L x W x H​
12.4"L x 9.5"W x 4.5"H​
12.5"L x 9.75"W x 4.25"H​
Item Weight​
7.7 Pounds​
5.5 Pounds​
Product
PROS AND CONS​
Optoma HD39HDR​
• Mostly quiet operation
• Good picture quality, especially for gaming (compatible with PS5)
• Simple setup and control
• Inaccurate lamp life claim (lamp failed after about 9,000 hours)
• Limited warranty on the lamp (only 90 days)
• Basic screen adjustment features
• Occasional input connectivity issues
While this projector delivers impressive picture quality and ease of use, it falls short in terms of lamp longevity and warranty support. Consumers should be cautious of the lamp life claims and consider the basic features when making a decision. Despite some connectivity issues, it remains a recommendable option for those looking for performance at a reasonable price point.
Optoma HD28HDR​
Pros
• Bright picture even in well-lit environments
• Clear sound quality, especially when positioned nearby
• Lightweight and easy to handle
• Impressive HDR support, providing near 4K quality
• User-friendly menus with adjustable settings
Cons
• Limited ceiling mount options requiring adjustments
• Restricted keyhole adjustment capabilities
• Noticeable fan noise when no sound is playing
• Potential color wheel artifacts during quick eye movement
Overall Impression
This projector offers an excellent balance of brightness and picture quality, making it ideal for both bright and dark environments. While it has some limitations in terms of mounting options and slight visual artifacts, its impressive HDR capabilities and user-friendly features make it a strong choice for anyone seeking a budget-friendly alternative to true 4K projectors.
