Amanda Brown
Active member
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | Optoma HD27HDR | ViewSonic PA503HD |
Price | $449 | $559.99 |
Recommended Uses | Education, Home Cinema, Gaming, Business | Education, Home Cinema, Business |
Highlight | Installation: Easy installation with vertical keystone correction and 1.1x zoom Resolution: 1080p (1920×1080) HDR Support: 1080p HDR and 4K HDR with HDR10 and DCI-P3 wide color gamut 3D Support: Full 3D 1080p support, compatible with various 3D sources Brightness: 3,400 lumens Connectivity: HDMI 2.0 with HDCP 2.2 and HDMI 1.4a compatibility | Brightness: 4000 Lumens Resolution: 1080p FHD Optical Zoom: 1.1x Vertical Keystone Adjustment: 40 degrees Contrast Ratio: High native DMD Chip Size: 0.65" Lamp Life: Up to 15,000 hours (SuperEco Mode) Connectivity: HDMI, USB Type A, compatible with most media players, PCs, Macs, mobile devices |
Screen Size | 60 Inches - 150 Inches | 30 Inches - 300 Inches |
Throw Distance | 1 Meters - 4 Meters | 1 Meters - 10 Meters |
Contrast Ratio | 400:1 | 22000:1 |
Display Resolution | 1920 x 1080 Pixels | 1920 x 1200 Pixels |
Brightness | 420 Lumen | 4000 Lumen |
Display Type | DLP | LCD |
Picture Quality Enhancement | HDR10 | ViewSonic SuperColor |
Video Encoding | H.264 or H.265 | - |
Lamp Wattage | - | 240 Watts |
Light Source Life | - | 4000 Hours |
Controller Type | Button Control, Voice Control | Remote Control, Button Control |
Control Method | App, Remote, Voice | Remote |
Mount Type | Tabletop Mount | Ceiling Mount |
Noteworthy Features | Gimbal Auto Real-time Image Correction : Auto Focus / Auto Keystone Correction, 𝐆𝐨𝐭 𝐪𝐮𝐞𝐬𝐭𝐢𝐨𝐧𝐬 𝐚𝐛𝐨𝐮𝐭 𝐩𝐫𝐢𝐜𝐢𝐧𝐠? 𝐏𝐥𝐞𝐚𝐬𝐞 𝐜𝐨𝐧𝐭𝐚𝐜𝐭 𝗝𝗠𝗚𝗢 𝗖𝐮𝐬𝐭𝐨𝐦𝐞𝐫 𝗦𝐮𝐩𝐩𝐨𝐫𝐭., 10000mAh Built-in Battery with 4.5H of Playtime (ECO Mode) / Type-C / Portable Mini / Outdoor, DLP / 1080P FHD / 420 ISO Lumens / 150 Inch Big Screen / HDR10 / Blu-ray 3D / 10W Dual Speakers / DD+, Google TV / Netflix (Official Licensed) / Wifi and Bluetooth / Smart | High brightness, High native contrast ratio, Large Screen size, Easy multimedia access |
Connectivity
Connectivity Technology | Wi-Fi | USB, HDMI, 3.5mm Jack |
Hardware Connectivity | USB, USB Type C, HDMI | HDMI, USB 2.0 Type A, 3.5mm Audio |
Compatible Devices | Laptop, Smartphone, Gaming Console, Media Player | Laptop, Television, Speaker |
Measurements
Dimensions L x W x H | 9.15"L x 3.15"W x 3.15"H | 13.3"L x 12.2"W x 4.5"H |
Item Weight | 3.3 Pounds | 6 Pounds |
Product | PROS AND CONS |
Optoma HD27HDR | Pros • Portable size and built-in battery • Battery lasts around 180 minutes • Works well with gaming systems, especially with Game Mode • Vibrant colors and decent sound quality from dual speakers • Brightness of 450 lumens suitable for darker spaces • Seamless Google Cast integration • Remote includes Netflix and YouTube shortcuts • Easy setup for both indoor and outdoor use • Sharp image quality even in darker scenes • Compact design allows for easy relocation Cons • Brightness may not be sufficient for well-lit environments • Sound quality may not satisfy audiophiles • Limited battery life for extended use Overall Impression The PicoFlix projector is a highly convenient and portable option for those looking to enjoy movies and gaming on the go. Its vibrant image quality and decent sound make it a solid choice for both indoor and outdoor settings, particularly in darker environments. While it has some limitations, such as brightness in well-lit areas and sound quality, its long battery life and ease of use make it a fantastic addition for movie nights, gaming sessions, or creating unique atmospheres for events like Halloween. Overall, it's a fun and effective gadget that enhances the home entertainment experience. |
ViewSonic PA503HD | Pros: • Excellent brightness, ideal for rooms with a lot of ambient light • Very sharp and clean picture quality • Good build quality with secure packaging • Longer throw distance allows for bright images even at smaller sizes Cons: • Limited image size, not suitable for those wanting larger projections • Difficulty adjusting settings to optimize performance • Weak built-in speakers, necessitating external audio solutions • Lack of comprehensive manual support for setup and adjustments Overall Impression: This projector excels in brightness and clarity, making it a solid choice for well-lit environments. However, its limited image size and weak audio output may deter users looking for more versatility. If you prioritize brightness and are willing to invest in external audio, this projector could be a worthwhile option. |
