- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The Optoma HD146X projector impresses with its sleek design, though it feels somewhat bulky compared to previous models I've owned. The plastic housing has a glossy finish, which, while visually appealing, is prone to scratches and smudges. The remote control, although backlit and functional, is made of lightweight plastic, which adds to the overall impression of a cheaper build quality. However, the projector’s size does not detract significantly from its performance, and it appears well-suited for a home theater setup.Introduce
Parameter | Optoma HD146X Projector |
Reference Price | $599 |
Recommended Uses | Gaming |
Built-In Media | AC power cord / Remote control / 2x AAA batteries / Basic user manual |
Highlight | FULL 3D: The HD146X displays true 3D content from almost any 3D source, including 3D Blu-ray Disc players, 3D broadcasting, and the latest-generation game consoles. Support for 120Hz rapid-refresh rate provides ultra-smooth flicker-free images; 3D glasses required HDMI plus USB POWER: Support for HDMI extender and USB power supply; connect to Apple TV, Chromecast, Xbox, Switch, PS4 or set top box for a big-screen entertainment experience FAST RESPONSE TIME: Enhanced Gaming Mode enables lightning-fast response time; Game Display Mode boosts shadows and dark scenes for greater visibility of impending obstacles HDMI-CEC FOR SIMPLE ON/OFF: HDMI-CEC technology enables control of the projector and connected devices using a single remote, all via the HDMI connection with the projectors HDMI-Link feature PERFECT IMAGE ALIGNMENT: With the latest technology from Texas Instruments, the DLP DMD single-chip design ensures perfect image alignment combined with high-brightness for an incredible picture LONG LAMP LIFE: Enjoy up to 15, 000 hours of lamp life enabling an average of 4 hours of viewing time every day 10 plus years |
Screen Size | 305 Inches - 301 Inches |
Throw Distance | 3.2 Feet - 35.37 Feet |
Contrast Ratio | 25000:1 |
Maximum Resolution | 1080p |
Brightness | 3600 Lumen |
Display Type | DLP |
Viewing Experience | The viewing experience is where the HD146X truly shines. The picture quality is bright and crisp, even in moderately lit environments, which is impressive for a DLP projector. The 3D functionality is outstanding; I was pleasantly surprised by the depth and clarity when projecting onto a light gray wall. While the colors are vibrant and accurate, I did notice some minor issues like a slight red tint on black screens and occasional rainbow effects, but these did not significantly detract from the overall enjoyment of movies and sports. |
LightSource Life | 15000 Hours |
Lamp Wattage | 240 Watts |
Wattage | 325 watts |
Connectivity Technology | Inputs 1 x HDMI 1.4a 3D support / Outputs 1 x Audio 3.5mm, 1 x USB-A power 1.5A |
Hardware Connectivity | USB, HDMI |
Compatible Devices | Gaming Console |
Other Features | Speakers, 3d-Ready |
L x W x H | 12.4"L x 9.5"W x 4.3"H |
System Experience | Setting up the projector was straightforward, as I was able to use an existing universal mount. The projector features image flip and focus controls, making it easy to adjust the image to fit my screen. However, I found the requirement for precise alignment with the screen to be a drawback, as it limits where I can position the projector in the room. I encountered some frustration with the lack of a comprehensive user manual, which made it challenging to navigate the settings initially. |
User Feedback
Pros:• Excellent brightness and clarity in various lighting conditions
• Impressive 3D capabilities
• User-friendly setup with basic adjustments
• Quiet operation in eco mode
• Limited connectivity with only one HDMI port
• Requires precise alignment for optimal image quality
• Plastic housing feels less durable
• No Bluetooth audio support
Overall, I find the Optoma HD146X to be a solid projector, especially considering its price point. The image quality is commendable, with bright visuals that work well in both light and dark environments. While there are a few design flaws, such as limited connectivity and the need for precise positioning, these do not overshadow the projector's strengths. It serves as an excellent option for home theater enthusiasts looking for a budget-friendly, high-quality projection experience.
