Optoma GT3500HDR vs NexiGo Aurora Pro: Which Ultra Short Throw Projector is Best for Your Home Cinema?
Barend Ray
Active member
Optoma GT3500HDR​
NexiGo Aurora Pro​
Price​
$1499
$2699
Home Entertainment, Home Cinema, Gaming, Business​
Home Cinema​
Flexible Installation: Digital zoom, horizontal/vertical keystone correction, 4-corner adjustment
Enhanced Gaming Mode: 8ms input lag @ 1080p 120Hz
Versatile Connectivity: 2x HDMI 2.0, USB-A (power), 3.5mm audio out, RS232, RJ45
Airtight Optical Engine: Reliable for 24/7 operation
Compact and Portable: 28% smaller than previous generations, lightweight design
Ultra Short Throw: 100" screen from less than a foot away
TV Replacement: Align the image, play in the same spot as the TV​
Black Level - ALPD 4.0 RGB+ technology, native contrast ratio 3000:1, dynamic laser dimming, black level reduction >60%, energy savings >30%
Sound - Built-in 60W stereo speakers, 2x15W woofers, 2x15W tweeters, supports Active 3D, Dolby Atmos, eARC
Dolby Vision - Supports Dolby Vision, HDR10+, dynamic laser dimming, improved tone-mapping algorithm
Lowest Latency - 120Hz MEMC, 4K@120Hz input support, lowest input lag 8ms among UST projectors​
Side-by-Side Comparison​
Optoma GT3500HDR​
NexiGo Aurora Pro​
90 Inches - 120 Inches​
75 Inches - 150 Inches​
0.66 Feet - 1.31 Feet​
0.33 Feet - 53.5 Feet​
500000:1​
at least 3000:1​
Display Resolution​
1920 x 1080 Pixels​
3840 x 2160 pixels​
3840 x 2160​
3800 Lumen​
2400 Lumen​
Laser​
Laser​
Picture Quality Enhancement​
ALPD 4.0 RGB+ technology​
Optoma GT3500HDR​
NexiGo Aurora Pro​
HEVC Main 10​
H.265 (HEVC)​
54 Watts​
60 Watts​
Light Source Life​
30000 Hours​
20000 Hours​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Noteworthy Features​
4K HDR Input, DuraCore Laser Technology, Ultra Short Throw, Place and Play, Full HD 1080p​
①‎4K Tri-Color Laser Ultra-Short Throw②Out-of-the-box color accuracy③Dolby Vision & Atoms ④Active 3D ⑤Lowest input lag among all UST projectors⑥Cinematic Sound with 60W Speakers (2x15W Tweeters and 2x15W Woofers) ⑦107% Rec.2020 color gamut​
Connectivity​
Optoma GT3500HDR​
NexiGo Aurora Pro​
USB, HDMI, 3.5mm Audio​
HDMI​
Hardware Connectivity​
Bluetooth​
PC, Gaming Console, Television, Tablet, Smartphone​
PC, Gaming Console​
Measurements​
Optoma GT3500HDR​
NexiGo Aurora Pro​
Dimensions L x W x H​
Item Weight​
8.6 Pounds​
22 Pounds​
Product
PROS AND CONS​
Optoma GT3500HDR​
• Good video quality in low light conditions
• Low input lag, suitable for gaming
• Customization options available
• Reliable performance over extended use (3-5 hours)
• Acceptable brightness for daytime viewing
• No major issues after 6 months of use
• Picture quality diminishes in bright light, especially for dark scenes
• Requires a pro screen to avoid image distortion
• Occasional bulb flashes in Eco mode
• Built-in speaker is ineffective and unnecessary
• Heat management concerns, especially near exhaust port
• No air filter, necessitating manual cleaning after extended use
NexiGo Aurora Pro​
Pros
• Provides a beautiful image, especially when paired with an ALR screen
• Excellent performance in ambient light conditions
• Easy to use with a high-quality remote
• Good picture quality out of the box, with options for further tuning
• Crisp and clean image even with some light in the room
Cons
• Sound quality is decent but not powerful enough for larger rooms
• Setup can be slightly fiddly for image adjustment
• Performance can be affected by direct bright lights in the room
Overall Impression
The Nexigo Aurora Pro is a highly recommended projector for those looking to create a cinematic experience at home. With its impressive image quality and adaptability to various lighting conditions, it excels in delivering a great viewing experience for movies, games, and shows. While the sound could be improved, pairing it with a quality sound system enhances the overall experience.
