Optoma GT1090HDR vs GT1080HDR: Which Short Throw Laser Projector is the Right Choice for You?
Optoma GT1090HDR​
Optoma GT1080HDR​
Price​
$1320
$904
Tv Stick, Home Cinema, Indoor Outdoor, Camping, Gaming​
Gaming​
Laser Light Source: DuraCore, 30,000 hours, low-cost, maintenance-free, IPX6 dust resistance
Home Automation: Network control, LAN & RS-232, Crestron compatibility
Brightness: 4,200 lumens, suitable for various indoor and outdoor settings
Picture Quality: 1080p (1920×1080) resolution, 300,000:1 contrast ratio
Image Setup: Auto keystone, four corner correction
Short Throw Lens: 120" image from 4'-4" away, ideal for small spaces​
Fast response time: 8.4ms with 120Hz refresh rate
3D capability: True 3D content support, 144Hz rapid-refresh rate, 3D glasses required
Image setup: Vertical keystone correction +/- 40 degrees
Short throw lens: 120" image from 4 feet away
Lamp life: Up to 15,000 hours
Brightness and clarity: 3,800 Lumens, 50,000:1 contrast ratio, Full HD 1080p (1920 x 1080)​
Side-by-Side Comparison​
Optoma GT1090HDR​
Optoma GT1080HDR​
36.43 Inches - 301.4 Inches​
36.2 Inches - 307 Inches​
3 Feet - 11 Feet​
1.3 Feet - 11.3 Feet​
300,000:1​
50000:1​
Display Resolution​
3840 x 2160​
1920 x 1080 pixels (Full HD)​
4,200 Lumen​
3,800 Lumen​
DLP​
DLP​
Picture Quality Enhancement​
HDR10 & HLG​
HDR10​
Optoma GT1090HDR​
Optoma GT1080HDR​
H.264 or H.265​
H.265​
380 Watts​
10 Watts​
Light Source Life​
30000 Hours​
10000 Hours​
Button Control​
Mount Type​
Ceiling Mount, Tabletop Mount​
ceiling mount, table top​
Noteworthy Features​
Built-In Speaker, Portable, Digital Keystone Correction, 3D-Ready, Built-In Media Player, Short Throw​
Short Throw​
Connectivity​
Optoma GT1090HDR​
Optoma GT1080HDR​
HDMI, 3.5mm Jack​
USB, HDMI​
Hardware Connectivity​
HDMI​
VGA, HDMI, 3.5mm Audio​
Television, Gaming Console, Laptop, Smartphone​
Gaming Console​
Measurements​
Optoma GT1090HDR​
Optoma GT1080HDR​
Dimensions L x W x H​
13.26"L x 10.5"W x 4.8"H​
12.4"L x 9.5"W x 4.5"H​
Item Weight​
10 Pounds​
6.61 Pounds​
Product
PROS AND CONS​
Optoma GT1090HDR​
• Excellent brightness, suitable for daytime use with open windows
• Quiet operation due to efficient fan design
• Long-life laser lamp outperforms traditional lamps
• Good image sharpness in dark environments
• Improved features compared to previous models (gt1080)
• Satisfactory color adjustments can enhance viewing experience
• Red color tint may require adjustment for accurate skin tones
• Limited geometry adjustments make installation challenging
• No optical zoom, only digital zoom available
• Color contrast reduces with ambient light
• Some features like Dynamic Black may hinder performance
The Optoma GT1090 projector presents a significant upgrade over its predecessor, offering impressive brightness and quieter operation. While it has some color calibration needs and installation challenges, it provides a sharp image and is a solid choice for those seeking a reliable projector for both gaming and cinema experiences. There are hopes for future models to include 4K resolution and improved color accuracy. Overall, it's a strong contender in its price range.
Optoma GT1080HDR​
• Compact and lightweight design (smaller than a letter size sheet, 6.6lbs)
• Excellent brightness with 4200 ANSI lumens, performs well in ambient light
• Affordable for a high-quality laser projector under $1,500
• Long lifespan of 30,000 hours for laser phosphorus
• Impressive dynamic contrast ratio of 300,000:1
• Supports 1080p with 4K compatibility
• Versatile features including 3D mode and keystone correction
• Power-efficient at only 173 watts
• Model number not visibly labeled on the unit, which may complicate support
• Remote control can be confusing due to unclear button labeling
• Manual is lengthy and may not provide clear guidance on all features
The Optoma GT2100HDR is an impressive laser projector that combines portability with high performance and affordability. Its brightness and clarity make it suitable for various lighting conditions, making it a great choice for home entertainment or specialized setups like a golf simulator. While there are some usability concerns, such as the lack of clear model identification and a potentially confusing remote, these issues do not significantly detract from the overall satisfaction with the product. For those seeking a reliable and powerful projector under $2,000, the GT2100HDR stands out as an excellent option.
