What kind of projector is the Optoma EL500H laser projector? This is an expensive laser projector, suitable for building theaters, conference offices and high-end education fields, so is this Optoma EL500H laser projector easy to use? Let's take a look at it below.
1. The overall use experience is not bad. In the case of light leakage on one side during the day, when using gray crystal cloth, the visual effect of not closing the curtains and only closing the screen windows is also good. The screen will turn white when the curtains are fully opened. The anti-light screen may be better, but in general, it is still very satisfactory, after all, the projector itself is not suitable for exposure to strong light.
2. The projection picture is very clear, the color is not dazzling, it is very soft, and the color is very bright. The projector is not very noisy, and the design of the heat dissipation holes is more suitable for the front. The model is also very small, and the color of the body is also very good.
3. The projection brightness is very high, the contrast is high, the projection font is clear, and the color is also very good. After adjusting the brightness, the picture quality is very delicate, and the wide and flat field of view is very large, and the visual effect is very good.
In summary, it is the feeling after using the Optoma EL500H laser projector. This projector is quite good in terms of image quality and adaptability to the environment. Generally speaking, it is a good projector. However, the price is relatively expensive, and it is still suitable for use in education, enterprises and other fields, and it is a bit extravagant for home use.
Optoma Projector Forum
