NEBULA Solar vs Mars 3 Air vs Capsule 3: Which 1080P Projector Should You Choose for Your Next Decision?
NEBULA Solar​
NEBULA Mars 3 Air​
NEBULA Capsule 3​
Price​
$299.99
$439.99
$499.99
Indoor/Outdoor​
Indoor/Outdoor​
Indoor/Outdoor​
Operating System: Android TV 9
App Availability: Over 5,000 apps
Audio Features: Dual 3W speakers, Dolby Digital Plus, portable Bluetooth speaker function
Projection Setup: Integrated stand with up to 13 degrees angle adjustment, wifi and Bluetooth
Portability: Lightweight, compact design
Connections: HDMI, VGA, AV, USB interfaces
Resolution: 1080p​
Portability: Google TV projector for on-the-go viewing
Display Quality: 1080P HDR, 400 ANSI Lumens brightness
Playback Duration: Up to 2.5 hours for video, 8 hours for music
Audio: Dual 8W Dolby Audio, portable speaker functionality
Setup Speed: Intelligent auto adjustments in 3 seconds​
Screen Size: Up to 120 inches
Portability: Ultra-portable design
Resolution: 1080p
Brightness: 200 Lumens
Battery Life: 2.5 hours of video, 8 hours of music
Setup Time: 3 seconds for auto adjustments​
Side-by-Side Comparison​
NEBULA Solar​
NEBULA Mars 3 Air​
NEBULA Capsule 3​
50 Inches - 200 Inches​
40 Inches - 150 Inches​
120 Inches - 120 Inches​
5 Feet - 5.2 Meters​
1.06 Meters - 3.9 Meters​
1 - 1​
Display Resolution​
3840 x 2160 pixels​
1920x1080 Pixels​
1920 x 1080 Pixels​
400 Lumen​
400 Lumen​
200 Lumen​
DLP​
DLP​
DLP​
Picture Quality Enhancement​
HDR​
NEBULA Solar​
NEBULA Mars 3 Air​
NEBULA Capsule 3​
H.264 or H.265​
VP9​
MPEG-2, MPEG-4, AVC, HEVC​
3 Watts​
8 Watts​
3 Watts​
Light Source Life​
30000 Hours​
2.5 Hours​
Button Control​
Button Control​
Button Control​
Mount Type​
Tabletop Mount​
Tripod Mount, Ceiling Mount, Table Mount​
Noteworthy Features​
Speakers, 3d Built-In, Internet Ready, 3d-Ready​
Pico​
1080p, Projector Mode, Bluetooth Speaker Mode, Auto (vertical ±40°), Auto (horizontal ±40°), Offcial Google TV, Built-in Netflix​
Connectivity​
NEBULA Solar​
NEBULA Mars 3 Air​
NEBULA Capsule 3​
Bluetooth​
HDMI,USB-A,AUX,DC-IN,BT,WiFi​
HDMI, potentially others​
Hardware Connectivity​
USB Type C, USB 2.0 Type A, HDMI, Bluetooth 5​
Bluetooth, HDMI​
HDMI​
Laptop, Smartphone, Tablet, Gaming Console, Television, Speaker​
Smartphone, Tablet, Laptop, Television​
Smartphone, Laptop​
Measurements​
NEBULA Solar​
NEBULA Mars 3 Air​
NEBULA Capsule 3​
Dimensions L x W x H​
6.33"L x 4.68"W x 4.25"H​
7"L x 4.8"W x 5.23"H​
3.15"L x 3.15"W x 6.3"H​
Item Weight​
3.7 Pounds​
1.83 Pounds​
Product
PROS AND CONS​
NEBULA Solar​
• Very colorful and produces a sharp image
• Versatile for both indoor and outdoor use
• Affordable native 1080p resolution
• Outstanding picture quality in dark settings
• Excellent autofocus feature
• Good performance for nature videos and movies when functional
• Compact size for portability
• Not bright enough for well-lit rooms
• Speakers are mediocre and may require external sound source for better audio
• Slow performance when switching between apps
• Issues with receiving used or refurbished units instead of new ones
• Problems with device functionality, including charging and turning on
• Lack of troubleshooting information in the manual
• High price point for inconsistent quality experience
NEBULA Mars 3 Air​
• Easy setup with a tripod
• Amazing clear and bright image
• Great sound quality for a compact projector
• Lightweight and user-friendly operation
• Fast auto-focus and auto-keystone adjustments
• Compact size and ability to operate on internal battery
• Good performance in low ambient lighting
• Can be paired with Bluetooth speakers for enhanced sound
• Lag issues with software
• Requires cache clearing for optimal performance
• Brightness may not be sufficient for daytime viewing without strong lumens
• Buffering can inhibit enjoyment
• Limited brightness for certain types of content
• No built-in front feet/flap for stability
• Some compatibility issues with streaming apps
• Not ideal for summer movie viewing due to brightness limitations
NEBULA Capsule 3​
Pros
• Excellent image quality, even better than OLED TV in low-light conditions
• Compact and portable design, battery-operated for outdoor use
• Versatile connectivity options, including HDMI and streaming capabilities
• Easy setup process
• Durable construction; can withstand accidental falls
• Auto-adjusting screen feature for angled surfaces
• Good sound quality for casual viewing; option to connect external speakers
• iPhone app available for remote control functionality
• Great value for the price
Cons
• Not suitable for use in well-lit environments; limited brightness (100 lumens)
• Sound quality may be lacking for serious audio experiences without external speakers
• Requires extension cables for outdoor use if power outlets are not nearby
• May not be optimal for daytime viewing or bright settings
