MXQ Pro vs TX3 Mini Pro vs TX3 Mini: What’s the Difference Between These Android TV Boxes?
Harry Williams
MXQ Pro​
TX3 Mini Pro​
TX3 Mini​
Price​
$29.99
$33.99
$33.99
Operating System: Android 13.1
Memory: 2GB RAM / 16GB ROM
Processor: Quad-Core 64-bit CPU
WiFi: Dual Band 2.4G/5.8GHz
Video Support: 3D and 4K (60Hz)
Video Decode: H.265
Performance Features: Fast operation, stable performance, reduced energy consumption
Additional Features: Smooth app performance, rapid loading and boot up, high-quality video playback​
Operating System: Android 10.0
RAM/Storage: 2GB RAM, 16GB ROM (expandable via micro SD up to 64GB)
Network Connectivity: 2.4GHz & 5.8GHz WiFi, Ethernet (10/100M), Bluetooth 4.2
Video Support: 4K video decoding, HDR media profile
Processor: Amlogic Quad core A53, 2.0 GHz
GPU: Mali 450MP3
Features: H.265 hardware decoding for better efficiency and image quality​
RAM: 2GB DDR
ROM: 16GB eMMC (expandable via micro SD up to 64GB)
Network Connectivity: 2.4GHz Wifi, LAN: 10/100M (RJ-45)
GPU: Mali 450MP3
Decoding Efficiency: H.265 (saves 50% bandwidth)​
Side-by-Side Comparison​
Performance​
MXQ Pro​
TX3 Mini Pro​
TX3 Mini​
RAM Memory​
2 GB​
2 GB​
2 GB​
Storage Capacity​
16 GB​
16 GB​
16 GB​
Resolution​
4k​
4k​
4k​
Internet Applications​
Browser, Netflix, Google Play Store, Hulu Plus, YouTube etc​
Skype, Google Play Store, YouTube, Browser,Netflix etc​
MXQ Pro​
TX3 Mini Pro​
TX3 Mini​
Video Codec​
H.265​
H.264, H.265​
H.264, H.265​
Dual Band WIFI 2.4G+5G / HDMI/Ethernet/USB​
Bluetooth, Wi-Fi, USB, Ethernet​
USB, Ethernet​
Normal TV,LCD TV,Smart TV​
Television​
Television​
Connector Type​
HDMI​
HDMI​
HDMI​
Noteworthy Features​
Miracast​
Miracast​
Miracast​
Measurements​
MXQ Pro​
TX3 Mini Pro​
TX3 Mini​
Dimensions D x W x H​
Item Weight​
0.3 Kilograms​
0.3 Kilograms​
0.65 Pounds​
Product
PROS AND CONS​
MXQ Pro​
Pros
• Affordable price for an Android box
• Some units function well without issues
• Recommended by other users
Cons
• Lack of physical controls on the box
• Audio jack compatibility issues causing noise
• Slow performance with noticeable lag
• Unresponsive remote control
• HDMI port failure in multiple units
• Quality inconsistencies among different units
TX3 Mini Pro​
Pros
• Great price for the performance offered.
• Supports both Bluetooth and Wi-Fi effectively.
• Compatible with various Linux distributions, including Debian-based kernels.
• Can customize boot splash animations and set up web kiosks.
• Plays a wide range of file types, including HEVC/x265.
• Superior remote control compared to many other budget Android TV devices.
• Reliable for personal media use and Kodi.
Cons
• Limited support for popular streaming apps like Hulu, Netflix, and others.
• Not Google certified, affecting app availability and streaming quality.
• Only streams in standard resolution, regardless of internet speed.
• Some users reported reliability issues after a short period of use.
TX3 Mini​
• Permite ver videos de manera más cómoda en una pantalla grande.
• Mejora la experiencia visual al compartir contenido con amigos y familiares.
• Ideal para entretenimiento en grupo.
• Puede requerir cables o adaptadores adicionales para conectarse a la pantalla.
• La calidad de la transmisión puede depender de la compatibilidad del dispositivo.
• Algunas aplicaciones pueden no ser compatibles con la proyección en pantalla grande.
