- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The projector presents a sleek, minimalist design that fits easily into a backpack, making it a practical choice for travel. Its compact size and understated elegance give it an appealing look, while the retractable lens cap adds to its functionality. Despite its aesthetic charm, the overall build quality feels a bit lacking in robustness, especially when compared to other projectors in the market.Introduce
Parameter | Miroir M631 Ultra Pro Projector |
Reference Price | $299.99 |
Recommended Uses | Gaming |
Built-In Media | User Manual, Power Cord, Remote, HDMI Cable, Carrying Bag |
Highlight | LIGHTWEIGHT AND PORTABLE: 9.5” x 5.39” x 1.5” 1.98lbs, LONG BATTERY LIFE:, Built in li-polymer battery for up to 1.5 hours of projecting time. 4K maximum input resolution, 700 LED lumens LARGE DISPLAY: Works for at home movies, streaming and backyard parties, or for streaming in bedroom. 25” to 120” (10 ft from the wall or screen) screen size. Great for WORK Presentations, or VIDEO CONFERENCING All digital HDMI or USB Type C connectivity - easily connect your cable/satellite box, Blu-ray player, gaming device, or streaming stick Easy setup - motorized focus with remote control, auto vertical keystone correction for image control CLEAR PICTURE AND SOUND: Cinema quality with Instrument's DLP Technology, 1920 x 1080p, LED LAMP 20,000 hours, ASPECT RATIO 16:9 |
Screen Size | 24 Inches - 120 Inches |
Throw Distance | 3 Feet - 10 Feet |
Contrast Ratio | 400:1 |
Maximum Resolution | 1920 x 1080p Pixels |
Native Resolution | 1920 x 1080p |
Brightness | 700 Lumen |
Display Type | DLP |
Picture Enhancement | DLP (Digital Light Processing) |
Viewing Experience | The viewing experience is where this projector shines, delivering a native 1080p resolution with good brightness levels, though the claimed 700 ANSI lumens may not fully translate to the projected image. The image quality is commendable, showcasing good detail and clarity, particularly in well-lit environments. However, the inability to modify image settings beyond brightness levels limits customization for various viewing preferences, and the lack of automatic focus and trapezoidal correction can be somewhat frustrating. |
Video Encoding | AVC |
Lamp Wattage | 8 Watts |
Wattage | 3 watts |
Hardware Connectivity | USB Type C, HDMI, 3.5mm Audio |
Compatible Devices | iPhone, Laptop, Gaming Device, Tablet, Android |
Other Features | Auto Screen Alignment |
L x W x H | 9.5"L x 5.4"W x 1.5"H |
System Experience | Setting up the projector is relatively straightforward, primarily requiring connection to external devices via its HDMI and USB-C ports. However, the absence of wireless connectivity options like Bluetooth or Wi-Fi is a significant drawback, as it complicates connectivity with Apple devices, requiring additional cables that are not included. The remote control has limited functionality, with dedicated buttons for each input port, but the lack of a comprehensive menu navigation system makes adjusting settings less intuitive. |
User Feedback
Pros:• Compact and travel-friendly design
• Good image quality with bright resolution
• Easy setup with basic connectivity options
• Reasonably good built-in speakers for small spaces
• No wireless connectivity (Bluetooth or Wi-Fi)
• Limited image customization options
• Additional cables required for Apple device connection
• Battery life diminishes over time with regular use
Overall, this projector serves well for basic use, particularly in professional settings or for educational purposes, where a simple plug-and-play setup is desired. However, for those seeking versatility and advanced features, it falls short compared to competitors. Its strengths lie in portability and decent image quality, but the absence of modern connectivity options and customization capabilities may lead potential buyers to consider other models that offer more flexibility and better value for money.
