Magcubic HY300PRO vs Thunrlge vs Magcubic Mini Projector: Which Offers Better Value with Built-In Apps?
Magcubic HY300PRO Mini Projector​
Thunrlge Mini Projector​
Magcubic Mini Projector​
$86.99​
$83.99​
$86.99​
Education, Movie Night​
Home Cinema​
User Manual, Remote, Adapter​
User Manual, Remote​
System Updates: Manual update required for optimal app performance
Built-in Apps: Access to 1,000,000 videos, no external TV stick needed
Remote Control: Air Mouse remote with traditional functions and voice command support
Resolution: Native 720P with 4K support
Brightness: 200 ANSI lumens, 10000:1 contrast ratio
Usage Scenarios: Suitable for casual viewing in various settings (bedroom, outdoor, living room)
Design: Versatile and portable; options for ceiling mounting, table placement, tripod installation, and 180-degree rotation
Product Type: Smart Projector
Connectivity: WiFi 6, Bluetooth 5.0
Projection Quality: Supports 4K 1080P
Projection Size: 40-130 inches
Optimal Projection Distance: 5.51 ft
Rotation Capability: 180° rotating stand
Audio Features: Built-in speakers, Bluetooth audio pairing
Ports: HDMI, USB, 3.5mm headphone jack
Use Cases: Home theatre, parties, work
Compatibility: Smartphones, laptops, game consoles, TV Stick/Box, DVD players, etc.
System Update Requirement: Manual update to the latest version for optimal performance
Remote Control: Air Mouse remote combining traditional remote and mouse, supports voice commands
Use Cases: Suitable for casual use in various settings (bedroom, outdoor, living room)
Design: Versatile and portable, supports ceiling mounting, table placement, tripod installation, and 180-degree rotation
Unboxing Experience​
Magcubic HY300PRO Mini Projector:​
Upon first glance, this projector is surprisingly compact and lightweight, making it a great option for those looking to travel with it. The design is practical, although the placement of the power supply could have been improved for better accessibility. The overall aesthetic is appealing, fitting well in a home environment, particularly in a darkened room, which is essential for optimal viewing.
Thunrlge Mini Projector:​
I am genuinely impressed with the design of this mini projector. Its compact and lightweight build makes it incredibly portable, fitting easily into my backpack, which is perfect for on-the-go use. The overall aesthetic is sleek and modern, and the well-packaged delivery ensures it arrives in pristine condition. The quality of the materials feels solid, which gives me confidence in its durability.
Magcubic Mini Projector:​
Upon first glance, the projector has a sleek and compact design, making it lightweight and easy to transport. Its size is just right for a casual home setup or for taking along on trips, and it fits seamlessly in a variety of spaces. The overall aesthetic is unassuming yet modern, making it blend well with most home decor. However, the placement of the power supply could be improved as it sits close to the arm, which may cause minor inconveniences during setup.
40 Inches - 150 Inches​
40 Inches - 130 Inches​
0.9 Meters - 4 Meters​
3.94 Feet - 13.12 Feet​
10000:1​
1500:1​
10000:1​
1980 x 1080 Pixels​
1280 x 720 Pixels​
1980 x 1080 Pixels​
1280 x 720​
1280 x 720​
1280 x 720​
8000 Lumen​
8000 Lumen​
The video quality is commendable, especially given the price point. It projects a sizable image that fills much of my bedroom wall, even at the lowest setting. The keystone correction works effectively, allowing for a straight and even picture despite some angular projection. However, the brightness could be improved, particularly around the edges, and I found that it performed best in a completely darkened room.
The viewing experience has truly exceeded my expectations. The projector delivers stunning images with sharp 1080P resolution and 4K support, creating vibrant colors that make movie nights feel immersive. I appreciate the 130-inch maximum screen size, which transforms my living room into a mini theater. The auto keystone feature works flawlessly, ensuring that the image is always aligned regardless of where I place the projector. The 180° rotatable design is a game-changer, allowing for easy adjustments to the angle for optimal viewing.
The viewing experience was generally pleasant, with good video quality that filled a large area of my wall even at the lowest setting. The keystone correction feature worked well, enabling me to achieve a straight and even picture even when projecting at a sideways angle. However, the projection could be brighter and sharper around the edges, and a fully darkened room is necessary for optimal viewing. The sound quality, while serviceable, left much to be desired, requiring an external Bluetooth speaker for an improved auditory experience.
Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi​
Built-In Speaker, Portable, Built-In Cooling System, Built-In Wi-Fi​
AVC​
H.264, H.265​
AVC​
60 Watts​
20000 Hours​
50000 Hours​
20000 Hours​
Bluetooth, Wi-Fi, USB, HDMI
Bluetooth, Wi-Fi​
Laptop, Tablet, Smartphone, Speaker​
60 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Tabletop Mount​
12"L x 6"W x 10"H​
3.94"L x 3.94"W x 7.48"H​
12"L x 6"W x 10"H​
Setting up the projector was a breeze; the Android onboard features made navigation simple. However, I encountered some challenges, particularly with connecting to various Bluetooth devices and apps. While I was able to successfully pair some devices, others proved more difficult. The remote navigation for pre-installed apps like Netflix was frustrating, often requiring me to rely on a Bluetooth mouse for smooth operation.
Setting up this projector was a breeze. I simply unpacked it, plugged it in, and within minutes, I was ready to go. The built-in Google TV interface adds convenience, allowing me to access a plethora of streaming options and apps without needing additional devices. The multiple input options—HDMI, USB, and Bluetooth—make it versatile for connecting to various devices like laptops, smartphones, and gaming consoles.
Setting up the projector was a breeze. I found the onboard Android system intuitive, allowing for straightforward navigation through menus. Most functions were easy to access, though I encountered some hiccups with connecting Bluetooth devices and navigating pre-installed apps like Netflix, where I had to resort to using a Bluetooth mouse for functionality. While the initial setup process was smooth, a few quirks in app performance left me feeling a bit frustrated, particularly with lag and connectivity issues.
• Excellent video quality for the price.
• Easy to set up and lightweight for travel.
• Good size and projection capability.
• Bluetooth connectivity for speakers improves sound.
• Great for casual movie nights and kids' use.
• Sound quality is lacking; tin can effect.
• Lag experienced with phone mirroring.
• Issues with app connectivity and navigation.
• Brightness could be improved for better viewing in less dark settings.
• Remote functionality can be inconsistent.
Overall, I find this projector to be a solid choice for casual home use, especially for family movie nights or for my daughter's activities. While it does have its shortcomings, particularly with sound quality and app connectivity, it offers excellent value for the price. The experience has been mostly positive, and I appreciate the large projection size and decent video quality despite the need for a darker environment for optimal viewing.
• Excellent picture quality with sharp 1080P and 4K support
• Compact and lightweight for portability
• Easy setup with multiple connectivity options
• Built-in Google TV for seamless streaming
• Auto keystone correction for easy image alignment
• 180° rotatable design for versatile placement
• Built-in speaker quality is decent but not exceptional
• Fan noise can be noticeable but becomes less distracting over time
• Short power cord may require an extension for flexible placement
This mini projector is an incredible value for its price, delivering impressive performance and features that cater to various entertainment needs. Whether I'm enjoying movies, presentations, or gaming, it has proven to be a reliable companion. The combination of portability, easy setup, and stunning viewing quality makes it a must-have for anyone looking to elevate their home entertainment experience. I highly recommend this projector for both casual users and those seeking a budget-friendly option without compromising quality.
• Easy setup and navigation.
• Good size; projects a large image.
• Lightweight and portable design.
• Bluetooth connectivity for external speakers.
• Lag when mirroring from a phone and inconsistent app performance.
• Sound quality is subpar; requires external speakers.
• Limited functionality with streaming apps.
• Brightness could be improved for better performance in well-lit rooms.
Overall, I find this projector to be a fantastic value for the money, especially for casual movie nights or as a fun tool for activities like sewing. While it does have its shortcomings, particularly with sound and app connectivity, the positives outweigh the negatives. I appreciate its ease of use and decent video quality, but I do wish for a bit more reliability with app performance. For someone looking for an affordable projector that delivers solid performance in a home setting, this one comes highly recommended, just be prepared to address some of its quirks.
Magcubic HY300PRO Mini Projector is pretty awesome! The sound's not the best, but you can easily hook it up to a Bluetooth speaker. Totally recommend it!
Got my bestie a Thunrlge Mini Projector and she loves it! Perfect for binge-watching her shows. Super easy to set up and the picture quality is awesome. Plus, it’s nice and compact!
Wwalmarts
Check out the Thunrlge Mini Projector! It's super handy and lightweight, so you can take it anywhere. The picture is awesome, especially in the dark, and it connects to all sorts of devices. The sound is decent, but hook it up to some speakers for an even better vibe. Perfect for movie nights or sharing videos!
