Magcubic HY300PRO vs PONER SAUND vs Thunrlge Mini Projector: A 180° Rotation Comparison for Portability and Performance
Magcubic HY300PRO Mini Projector​
PONER SAUND Mini Projector​
Thunrlge Mini Projector​
$86.99​
$45.88​
$83.99​
Education, Movie Night​
家庭影院,教育,游戏​
Home Cinema​
User Manual, Remote, Adapter​
remote control, GP16 Projector, Power Cable, HDMI Cable, 3 in 1 AV Cable​
User Manual, Remote​
System Update Requirement: Manual update to latest version recommended
Built-in Apps: Access to 1,000,000 videos without external TV stick
Control Method: Air Mouse remote with voice command support
Resolution: Native 720P with 4K support
Brightness: 200 ANSI lumens
Contrast Ratio: 10000:1
Use Cases: Casual movie watching, family entertainment, outdoor shows
Design Flexibility: Ceiling mount, table placement, tripod installation, 180-degree rotation
Wireless Connection: Multi-screen interaction, compatible with iOS and Android, no extra cables needed.
Resolution & Brightness: 1280x720P native resolution, supports 1920x1080P, 5500 lumens, 5500:1 contrast ratio, 16:9/4:3 aspect ratio.
Screen Size: Projects sizes from 40” to 210”, recommended viewing distance 6.5ft.
Portability: Dimensions 7.87*5.90*2.95 inches, weight 2.5 lbs.
Built-in Speaker: Delivers clear sound for movies, photos, and games.
Connectivity: Multiple interfaces: HDMI, USB, AV, headphone, compatible with various devices.
Customer Service: Lifetime customer service provided.
WIFI 6: Built-in WiFi 6 for fast transmission and low delay, connects within 5 seconds.
Bluetooth 5.0: Built-in Bluetooth 5.0 for audio device pairing.
Speaker: Integrated speakers for audio playback.
180° Rotable: 180° rotating stand for versatile positioning.
Projection Range: 40-130 inch screen size with optimal distance of 5.51 ft.
HD Support: Supports 4K and 1080P resolution.
Automatic Keystone Correction: For optimal screen alignment.
Connectivity: HDMI, USB, and 3.5mm headphone ports available.
Applications: Suitable for home theatre, parties, work, and more.
Unboxing Experience​
Magcubic HY300PRO Mini Projector:​
Upon first glance, this projector impresses with its compact design and lightweight build, making it a suitable choice for both home use and travel. The aesthetic is simple yet functional, allowing it to blend seamlessly into any room decor. The projection size is quite substantial, filling a majority of the wall space even when set to the lowest setting, which is a huge plus for viewing experiences. However, the placement of the power supply cord could be better thought out to avoid potential obstruction.
PONER SAUND Mini Projector:​
When I first laid eyes on the Poner Saund Model M8 projector, I was pleasantly surprised by its robust and attractive design. It has a bulky, square frame that feels well-constructed, giving it a more premium look than one might expect at this price point. The unit is larger than my previous ViewSonic, which I found interesting, and it features a clean layout with easy access to the ports. However, the rubberized pads covering the mounting points needed to be peeled off to access the screws, which was a minor annoyance but something I managed.
Thunrlge Mini Projector:​
The mini projector presents a sleek and compact design that is visually appealing and highly portable. Weighing just over a pound, it fits easily into a backpack, making it perfect for travel or outdoor movie nights. The build quality feels solid, and the neat packaging further enhances the overall impression of a well-crafted device. The projector's aesthetic is modern and unobtrusive, which allows it to blend seamlessly into any home entertainment setup.
40 Inches - 150 Inches​
40 Inches - 100 Inches​
40 Inches - 130 Inches​
0.9 Meters - 4 Meters​
5 Feet - 15 Feet​
3.94 Feet - 13.12 Feet​
10000:1​
5500:1​
1500:1​
1980 x 1080 Pixels​
1280 x 800​
1280 x 720 Pixels​
1280 x 720​
1280 x 800​
1280 x 720​
8000 Lumen​
5500 Lumen​
The viewing experience was generally good, with excellent video quality that far exceeds many other projectors in this price range. However, the sound quality left much to be desired, often described as tinny and lacking depth. While the projector performed well in a darkened room, it struggled slightly in brighter conditions, which is something to keep in mind if you plan to use it in various lighting situations. Users have noted occasional lag when mirroring from their phones, which can detract from the overall experience, especially during critical viewing moments.
The viewing experience with the Poner Saund Model M8 has been largely positive. Images projected onto my 100" screen were crisp and vibrant, especially in a darkened room. I was pleasantly surprised at how well the projector performed even in less-than-ideal lighting conditions. However, I did notice that projecting onto a white wall at 200" resulted in a drop in brightness and quality, indicating that the ideal setup is definitely a proper screen. The sound quality from the built-in speakers was surprisingly decent for casual viewing, but I opted to connect it to a soundbar for a more immersive experience, particularly for outdoor movie nights.
The viewing experience with this mini projector has been nothing short of fantastic. The 1080P resolution and 4K support deliver sharp and vibrant visuals, making movie nights feel like a genuine cinematic experience. The projector can display images up to 130 inches, which is perfect for creating a home theater ambiance. Even in dimly lit conditions, the brightness and color accuracy stand out. The additional 180° rotatable design allows for easy adjustment, while the auto keystone correction consistently maintains image alignment, enhancing the overall convenience.
Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi​
Wireless, Portable, Built In Wi Fi​
Built-In Speaker, Portable, Built-In Cooling System, Built-In Wi-Fi​
AVC​
1080P​
H.264, H.265​
60 Watts​
20000 Hours​
52000 Hours​
50000 Hours​
Bluetooth, Wi-Fi, USB, HDMI
wireless(Wi-Fi)/wired, HDMI, USB, AV, TF​
Bluetooth, Wi-Fi​
ios system, android system​
Laptop, Tablet, Smartphone, Speaker​
60 watts​
60 watts​
Mount Type​
Tabletop Mount​
table, tripod, ceiling (mount not included)​
Tabletop Mount​
12"L x 6"W x 10"H​
7.87"L x 5.9"W x 2.95"H​
3.94"L x 3.94"W x 7.48"H​
Setting up the projector was a breeze; I was able to get it running in no time. It comes with Android onboard, which is a nice touch for those looking to stream directly. There were some hiccups with app connectivity, especially with Netflix and other streaming services that required a bit of troubleshooting. The keystone correction worked effectively, even at a 25-degree angle, ensuring a straight and even picture. For users who are less tech-savvy, the initial setup might seem daunting, but most will find it straightforward.
Setting up the projector was mostly straightforward, especially for a first-time user like myself. I appreciated the variety of connections available, including HDMI for my ROKU box, which allowed me to fully utilize the projector's capabilities. The adjustments for the X-Y zoom and the four-point keystone correction were user-friendly, making it easy to get the image just right. However, I did find the settings menu a bit clunky and less intuitive than I would have liked, although it ultimately got the job done. An important point that I discovered was the projector's mounting screw dimensions, which I published to help others avoid similar confusion.
Setting up the projector was an incredibly straightforward process. Upon unpacking, I was able to plug it in and get started within minutes. The built-in Google TV interface offers easy access to a plethora of entertainment options and apps, making it feel like a smart device rather than just a simple projector. The multiple input options, including HDMI, USB, and Bluetooth, provide versatility for connecting various devices, and the auto keystone feature simplifies the alignment of the projected image, ensuring a hassle-free experience.
• Excellent video quality for the price
• Lightweight and easy to transport
• Simple setup process
• Large projection size even at low settings
• Effective keystone correction
• Sound quality is subpar, often requiring external speakers
• Connectivity issues with streaming apps
• Occasional lag when mirroring devices
• Brightness could be improved for well-lit rooms
In summary, this projector offers great value for money, particularly for casual viewing or family movie nights. While it does have some drawbacks, such as its sound quality and connectivity issues, the positives, like video quality and ease of use, significantly outweigh the negatives. It has proven to be a reliable choice for my needs, and I would recommend it to anyone looking for an affordable projector, keeping in mind that enhancements like a Bluetooth speaker could vastly improve the overall experience.
• Affordable price point for the features offered.
• Crisp image quality in dark rooms with good contrast.
• Variety of connection options including HDMI and legacy inputs.
• User-friendly adjustments for keystone and zoom.
• Built-in speakers are adequate for casual viewing.
• Clunky menu navigation can be frustrating.
• Brightness drops in well-lit environments.
• Some users report issues with internal dust and image quality inconsistencies.
• No Dolby support can complicate sound setups.
• Fan noise may be noticeable in quieter settings.
Overall, I am quite satisfied with my purchase of the Poner Saund Model M8 projector. It provides an impressive image quality for its price, making it an excellent entry-level projector for both indoor and outdoor settings. While there are a few quirks—like the somewhat noisy fans and the clunky menu system—these are relatively minor compared to the projector's performance and value. This projector has transformed my viewing experience, and I'm excited to continue using it for family movie nights and other gatherings. For anyone looking for an affordable yet capable projector, I would definitely recommend giving this one a shot.
• Excellent image quality with 1080P and 4K support
• Easy setup with auto keystone correction
• Portable and lightweight for travel
• Multiple connectivity options (WiFi 6, Bluetooth, HDMI, USB)
• Built-in Google TV for seamless streaming
• Built-in speakers are decent but not exceptional
• Requires manual focus adjustment when repositioned
• Short power cord may necessitate an extension
• Occasional fan noise can be distracting
This mini projector has exceeded my expectations in terms of performance, convenience, and value for money. It offers a comprehensive solution for both entertainment and presentations, making it a versatile addition to any setup. The combination of excellent picture quality, user-friendly connectivity, and portability makes it a solid choice for anyone looking to upgrade their viewing experience. I highly recommend this projector to anyone seeking a reliable, affordable, and high-quality option for home entertainment or on-the-go use.
Charger196904
El proyector Magcubic HY300PRO no deja instalar apps como Netflix, Disney o Max, solo puedo usar Spotify para escuchar música.
mvppaulo
The PONER SAUND Mini Projector is super easy to use and connects in a snap. The picture's clear once you focus the lens, and it works best in a dark room like most projectors. The sound's a bit low, but plug it into my boom box, and it gets pretty loud! Not a bad deal for the price!
DealsFishman
The PONER SAUND Mini Projector has some issues. WiFi and cable connections don't work with smartphones—tried it with three different ones. The sound quality is pretty bad too. I did manage to get WiFi working by using the password from the quick start guide (it's 12345678, not your home WiFi password). Overall, it's decent for the price, though.
NetworkingJesus
Got a Thunrlge Mini Projector for our vacation to binge-watch Netflix and YouTube. The picture's pretty decent for the price, but the sound could be louder.
OneTimeSE
Thunrlge Mini Projector is super easy to hook up to Roku. The picture looks great! It’s a bit quiet, but it works for me. Background noise isn’t a big deal. Overall, I think I got my money's worth. I just wish the mount had more space for wires, but I can fix that in my workshop. A little DIY, and it'll be perfect!
fosterzar
Got my bestie the Thunrlge Mini Projector and she loves it! Perfect for her shows, super easy to set up, and the picture quality is solid. Plus, it’s nice and small!
