Magcubic HY300PRO vs PONER SAUND vs ear&ear Mini Projectors: What’s the Difference in Auto Keystone Correction?
windstri85
Magcubic HY300PRO Mini Projector​
PONER SAUND Mini Projector​
ear&ear Mini Projector​
$86.99​
$45.88​
$59.99​
Education, Movie Night​
家庭影院,教育,游戏​
User Manual, Remote, Adapter​
remote control, GP16 Projector, Power Cable, HDMI Cable, 3 in 1 AV Cable​
System Update Requirement: Manual update to latest version for optimal performance
Built-in Apps: Access to 1,000,000 videos without external TV stick
Control Type: Air Mouse remote with traditional and mouse functionality, voice command support
Resolution: Native 720P with 4K support
Brightness: 200 ANSI lumens, 10000:1 contrast ratio
Use Case: Suitable for casual use, family entertainment, and short trips
Design: Versatile and portable; supports ceiling mounting, table placement, tripod installation, 180-degree rotation
Wireless Connection: Multi-screen interaction, compatible with iOS and Android, no extra cables or adapters needed.
Resolution & Brightness: 1280x720P native resolution (supports 1920x1080P), 5500 lumens, 5500:1 contrast ratio, 16:9/4:3 aspect ratio.
Screen Size: 40” to 210” projection size, recommended viewing distance of 6.5ft.
Portability: Size: 7.87 x 5.90 x 2.95 inches, Weight: 2.5 lbs.
Built-in Speaker: Delivers clear sound for movies, photos, and games.
Connectivity Options: HDMI, USB, AV, headphone, compatible with multiple devices (laptops, DVD players, gaming consoles, etc.).
Customer Service: Lifetime customer service provided.
Smart Projector: Android TV 13.0
App Ecosystem: Access to over 500,000 movies and TV shows, including N-F, Prime Video, YouTube
GPU: Mali-G31
Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G and 5G networks
Projection Flexibility: 180° rotational projection for wall, ceiling, or floor
Keystone Correction: Auto keystone correction and manual focus adjustment
Audio: 360-degree surround sound system
Video Resolution: Supports 1080P/4K
Contrast Ratio: 1500:1
Noise Level: Below 25 dB
Ports: HDMI, USB, audio for external device connectivity
Unboxing Experience​
Magcubic HY300PRO Mini Projector:​
The projector has an appealing design that is both lightweight and compact, making it easy to transport. Its sleek aesthetic fits well in various settings, from a cozy home environment to outdoor glamping trips. The overall build quality seems decent for the price point, although some users noted minor concerns, like the placement of the power supply cord which could have been better thought out.
PONER SAUND Mini Projector:​
The Poner Saund Model M8 projector has an attractive and well-constructed design that feels solid, especially considering its price point. It is slightly larger than my previous ViewSonic projector, giving it a more substantial presence. With a bulkier, square frame, it may not be the sleekest choice on the market, but its functional layout—with accessible mounting points and a sturdy build—provides reassurance of durability. The projector's aesthetic may not win any design awards, but it certainly doesn't detract from its functionality.
ear&ear Mini Projector:​
The HY300 PRO Portable Projector boasts a compact and stylish design that instantly appeals to me. Its lightweight build makes it incredibly portable, allowing me to easily fit it into a bag for travel or outdoor movie nights. The sleek profile is both aesthetic and functional, adding a modern touch to my setup without taking up too much space.
40 Inches - 150 Inches​
40 Inches - 100 Inches​
35 Inches - 130 Inches​
0.9 Meters - 4 Meters​
5 Feet - 15 Feet​
35 - 130​
10000:1​
5500:1​
1500:1​
1980 x 1080 Pixels​
1280 x 800​
4096 x 2160​
1280 x 720​
1280 x 800​
1280 x 720​
8000 Lumen​
5500 Lumen​
200 Lumen​
LED​
The viewing experience has its highs and lows. The video quality is commendable, especially for an entry-level projector, with a sizeable image that fills a significant portion of my wall even at the lowest setting. However, I did notice some lag when mirroring from my phone, which was disappointing, especially when words appeared several seconds behind. The picture quality does suffer in brighter conditions, necessitating a dark room for optimal results. Sound quality leaves much to be desired, but pairing it with external Bluetooth speakers can significantly enhance the audio experience.
The viewing experience has been impressive overall. The image quality is crisp and vibrant, especially in darkened environments, where it rivals a cinema-like experience. The X-Y zoom adjustment and four-point keystone correction have been particularly beneficial in adapting the projected image to fit my screen perfectly. While I did notice some brightness drop when projecting onto a white garage wall, this is likely due to the surface rather than the projector itself. In brighter conditions, the picture quality does diminish, but it still remains acceptable for casual viewing.
The viewing experience with the HY300 PRO has been nothing short of remarkable. The projector supports both 4K and 1080P resolutions, delivering sharp and vibrant images that hold up well even in moderately lit environments. I tested it on a 130” screen and was thrilled by the clarity and color reproduction. Whether I was watching movies, playing video games, or giving presentations, every detail was crisp and engaging, making it a versatile choice for all types of content.
Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi​
Wireless, Portable, Built In Wi Fi​
Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player​
AVC​
1080P​
AVC​
20000 Hours​
52000 Hours​
Bluetooth, Wi-Fi, USB, HDMI
wireless(Wi-Fi)/wired, HDMI, USB, AV, TF​
ios system, android system​
Laptop, Tablet, Smartphone, Speaker​
60 watts​
Mount Type​
Tabletop Mount​
table, tripod, ceiling (mount not included)​
Tabletop Mount​
12"L x 6"W x 10"H​
7.87"L x 5.9"W x 2.95"H​
Setup was remarkably straightforward, allowing me to get started in no time. The projector runs on Android, which is a plus for accessing various apps. However, navigating the pre-installed Netflix app proved to be a hassle; I often found myself resorting to a Bluetooth mouse just to get through its interface. While I was able to connect to Bluetooth speakers without much trouble, there were instances where the projector didn't respond to the remote, leading to frustration.
Setting up the Poner Saund Model M8 was relatively straightforward, allowing me to connect my devices with ease. The various legacy connections and HDMI options made it convenient to integrate my Roku box, maximizing the projector's capabilities. However, I found the menu system to be somewhat clunky, which might pose a challenge for new users. It was a bit of a hunt to figure out the mounting options, and I wish there had been clearer guidance about the dimensions and mounting points available. Luckily, I managed to adapt my existing mount with some minor modifications, which was a relief.
Setting up the projector was a breeze, thanks to its intuitive interface and user-friendly controls. With built-in Android 13, I could access my favorite streaming apps directly without needing additional devices. The dual-band Wi-Fi 6 and Bluetooth 5.2 ensured seamless connectivity, making it easy to stream content from my phone or laptop. I was particularly impressed with the 180° rotatable design and auto keystone correction, which allowed for flexible positioning and ensured that the image was perfectly aligned no matter where I set it up.
• Excellent video quality for the price.
• Easy setup and connectivity with Bluetooth devices.
• Lightweight and portable design.
• Satisfactory performance for casual viewing.
• Large projection size that fills wall space effectively.
• Lag in phone mirroring.
• Sound quality is subpar, requiring external speakers.
• Navigation issues with pre-installed apps like Netflix.
• Limited brightness that necessitates a dark viewing environment.
• Occasional remote response issues.
Overall, this projector is a solid choice for anyone looking for a budget-friendly option that performs well in dim conditions. While there are notable shortcomings, particularly with sound quality and app navigation, it ultimately delivers great value for the price. It's perfect for movie nights or casual viewing, especially for children, though I would recommend pairing it with better sound solutions for a fuller experience. If you're willing to work around its quirks, it can be a fun addition to your entertainment setup.
• Excellent image quality in dark environments.
• Easy setup and connection options.
• Good built-in speakers for casual use.
• Multiple adjustments for image correction.
• Clunky menu system.
• Brightness drops off significantly in well-lit rooms.
• Minor issues with lag during certain connections.
• Fan noise can be noticeable.
Overall, I'm quite satisfied with my purchase of the Poner Saund Model M8 projector. It provides an excellent balance of features for the price, making it a strong contender in the budget projector market. While it has some drawbacks—such as the brightness limitations and a somewhat noisy fan—the image quality and setup ease have made it a worthwhile investment for my movie nights and outdoor events. I appreciate the versatility it offers for various viewing situations, and despite a few quirks, it has exceeded my expectations, especially for such a budget-friendly option.
• Excellent image quality with 4K and 1080P support.
• Fast and stable connectivity with Wi-Fi 6 and Bluetooth 5.2.
• Highly portable and lightweight design.
• Easy setup with auto keystone correction.
• Flexible 180° rotation for various viewing angles.
• Performance is best in darker environments; brightness diminishes in daylight.
• Built-in speaker is decent but not optimal; external speakers are recommended for better audio.
Overall, I'm extremely satisfied with the HY300 PRO Portable Projector. It combines impressive functionality with portability, making it an excellent choice for anyone seeking a reliable projector for movies, gaming, or presentations. The value it offers at its price point is remarkable, and I would highly recommend it to anyone looking for an affordable yet high-quality projection solution.
Elfman72
The Magcubic HY300PRO Mini Projector is super cool! I shopped around for a solid projector that didn't break the bank, and this is it. The only downside? The sound quality isn't top-notch, but it's still pretty good!
Astro51450
The Magcubic HY300PRO Mini Projector is decent for the price, but don't expect 4K—it's only 1080p. It's pretty dim, so you'll need a dark room to use it. Honestly, my phone has better sound!
wilson-bentley
¡El proyector Magcubic HY300PRO está de lujo! La calidad de imagen es genial y el tamaño es ideal. Solo podría mejorar un poco el sonido, pero por el precio, ¡es una maravilla!
Happy7User
PONER SAUND Mini Projector: super easy to use and won't break the bank! I’ve been using it to project images for my woodworking projects, and it connects to my iPhone like a breeze.
The ear&ear Mini Projector is awesome! The picture is super clear and colorful. It’s small, easy to use, and perfect for movies or presentations. Feels sturdy and works like a charm. Totally worth the money! Highly recommend it if you need a good mini projector!
I got the ear&ear Mini Projector and it's way cooler than I expected! Super easy to set up and now movie nights are a blast projecting it on the ceiling. Totally worth the buy!
